For the past few weeks, I've been obsessed with manipulating the newly-
available (from the FAA) raster sectional images. This is all new to me so I've just been banging out code trying to get something reasonable. The code is *horrible* and I don't recommend it as anything beyond an example of something CS graduates should know better than to generate. However, I've been asked for details about it, so here goes... I subscribed to the Sectional Raster Aeronautical Chart Eastern Set (SRACE) and Western Set (SRACW) from the FAA. http://www.naco.faa.gov/index.asp?xm...ctional_Raster There's also an Alaska Set (SRACA) but I wanted to get comfortable with these before trying to justify the cost of it. These DVDs are supposed to come every 28 days. I've only received one set so far and it expired on November 27. Gotta call about that. I uploaded the data to a server I got in Chicago primarily for this purpose. I'm not sure how the layout will evolve, but for now the data is here. http://aviationtoolbox.org/raw_data/FAA_sectionals/ I cropped the cover image from the St. Louis chart so that I could easily get a handle on which regions are where. http://aviationtoolbox.org/raw_data/...al_regions.png (I have copies of this marked up all over the house.) In the FAA_sectionals/ directory there are East and West compilations (zip files), and the data is available in the original (uncompressed) format in the current/ directory. The images are fairly compressible so if you want a bunch, get the compilations. With compression you can easily fit everything on a single DVD. Seems like a sales opportunity... Now that the data is on the server, I announce that it's available and the server is flooded with requests. I'm on a low bandwidth plan, so I can only push about 6Mbps. For several days, that's exactly what the machine did. Now it's fairly idle. You're welcome to peek at what it's doing. http://aviationtoolbox.org/server-status (Note that there's apparently a bug in Apache2 - the request and idle counts are always zero. Just look for the _W_aiting children.) O.k., so now everyone has the GeoTIFFs. What happens? Well, lots of people are already familiar with this data and have applications to handle it and don't need anything more from me. Great! I want to make the data more accessible to everyone to build their own tools though. To me that means combining all of the maps and geting rid of the non-map data (legends, etc.). That's what I've been doing recently. The first step was to decide how to determine where the map part of the image is. I wrote some programs to use white space to find the map data, but there are enough inconsistencies that I decided to hand- code the lower left corner locations (longitude, latitude). I used my automation to do this but then I checked it against the cover map. I found that some corners couldn't be determined from that map, so I made thumbnail images of all the corners and checked those. http://aviationtoolbox.org/munge/corners From this, I generated the list of corner locations. http://aviationtoolbox.org/munge/sectional_corners The next step is to mask off everything that's not part of the map image. Given the lower left corners, it's not too bad. (I'm still tweaking it though.) I create a mask that has zeros for everywhere around the map image and then scales from 1 to 255 from each edge. I'm tentatively calling this the "quality" of the pixel, because things get complicated near the edges. When I write the image, I convert all of the pixels from the 8-bit palette to 24-bit RGB. Any pixel with a zero mask value becomes white (255, 255, 255). http://aviationtoolbox.org/munge/mas...quality_py.txt http://aviationtoolbox.org/munge/masked/ Now that I have just the map image, I need to rotate (warp) the image so that it lines up squarely with all of the others. To understand why you need to do this, look at the map on the cover. http://aviationtoolbox.org/raw_data/...al_regions.png If you physically tried to align all of the printed sectional maps, you'd end up with them bowing down toward the middle. That's too complex for me to handle, so I picked a common reference sectional. Everything is warped to the geotransform (slope) of Wichita North. To the west, sectionals are rotated a bit clockwise, and to the east, they're rotated counterclockwise. This warping takes a long time - and I do it twice. The first warp is for the RGB image data. It uses a cubic spline resampling algorithm. This returns a great- looking image by weighting a large block of source pixels to determine what each destination pixel will be. The cubic spline resampling doesn't work well with a fourth band (the mask), so I handle it on its own. I execute the same warp, but with the much-simpler "nearest neighbor" method of determining the destination pixel. http://aviationtoolbox.org/munge/warped/ Note that the GDAL library doesn't include Python bindings for warp operations. I had to resort to C++. http://aviationtoolbox.org/munge/warp.cc The warp operation also handles the *slight* difference of pixel sizes of the various images. They're all close to 64 meters/pixel, but in the warp I force them to be exactly that. We almost have a continuous data set now. The last step is to combine the warped images. They go together easily now that they're all warped to the reference image. Except...there's overlap. The overlap is why I originally set up the mask channel to have the "quality" values. I was thinking that whenever there's overlap I'd just pick the pixel with the highest quality (furthest from the edge in its original image). This gives a nice sharp image, but it's possible to lose data because some text could be *only* on the edges of both images. http://aviationtoolbox.org/tmp/chunk_furthest.jpg I didn't feel good about that approach so I tried blending instead. This sounded too difficult at first, but because GDAL uses Python's Numeric extensions (arrays) for the image data, it was amazingly straightforward. The blending algorithm multiplies each pixel's value (for each band - RGB) by the pixel's weight. It then adds this to the existing weighted pixel and then divides by the total weight (or one if there's no good pixel there). (Yes, if there's more than two images that overlap on an image (like in the Denver/Wichita/Albuquerque/Dallas area), the subsequent images are weighted more just because the earlier images have already been averaged. There are ways around that, but I don't yet think it's worth fixing.) The result is a much more gradual transition between images. http://aviationtoolbox.org/tmp/chunk-blended.jpg Info on the edges can still be seen. Often the same information appears twice. Sometimes it looks "jittery." More work to do on that. This blending all occurs as part of the "chunking" process. Because TIFFs are limited to 4GB total size, I can't just throw everything into one big uncompressed file. I could resort to using an ERDAS Imagine (.img) file, but I decided smaller files would be easier to manipulate for now. Another constraint is that GDAL doesn't seem to like to create small GeoTIFF files. The answer was to make the images 5000x5000 pixels. (That's 320Km x 320Km.) I "chunk" each masked image by moving across the masked image, getting the chunk that corresponds to the current point, copying everything in the masked image that fits into that chunk, and then moving past the edge of the chunk in the masked image to repeat the process with a new chunk. Each chunk is named by how far it is from the Wichita reference point. The first chunk to the left is "chunk_-1_0.tif" and the one above that is "chunk_-1_-1.tif". So...that's it! It's amazing that I could spend so much energey on something so simple, but it's been quite an education. various notes... I could not have accomplished this without GDAL. http://www.remotesensing.org/gdal/ Writing this in anything but Python using a well-crafted library like GDAL would have been unbearable. Frank Warmerdam gave me crucial insight and example code. Along the way I build a lot of JPEG and PNG files. These are usually so that I can easily check on the process without loading a huge TIFF file. The PNGs will show the mask/quality value as the transparency. This means that the edges show up well and the middle portions of the images disappear. That makes it easier to spot problems. Sometimes I build tools to display these small images. http://aviationtoolbox.org/munge/mosaic These images are just for reference. Each sectional (North and South sides) takes from 40 to 60 minutes to process on this machine (2.4GHz Xeon). There are 37 sectionals. (I don't deal with Hawaii now.) It takes awhile to try something new. Right now I'm regenerating everything using additional masking operations to trim the right and bottom edges. It won't finish for a couple days - and that's if I don't change my mind and try something different. Everything could change. Don't count on these URLs remaining the same. I'm still getting comfortable with this data. There are lots of places where processing efficiency could be improved greatly. I'm just trying to get something that works now. It might be that the chunked data isn't what you want. It could be better, for example, to use the warped data and make your application decide which sectional to use on edges. The chunks are for ease of use, but they're not perfect. I prefer that comments/questions/extensions/etc. that might benefit others go to the newsgroup(s). Please use "AVIATIONTOOLBOX:" in the subject to help those who want to follow this and those who want to skip it. Please enjoy the data! --kyler |
Hm. I don't know if you noticed or not, but the terminal area charts
inside the current-east and current-west zip files have at least some duplicates -- one I noticed in both was the DFW TAC. You may want to fix this for future updates -- I know you probably won't change the files now -- it might be a pain for some people who are currently d/ling or resuming their d/l off your website -- but you can fix this for future updates. Matthew F. G. |
"Matthew F. G." writes:
Hm. I don't know if you noticed or not, but the terminal area charts inside the current-east and current-west zip files have at least some duplicates Yup, there are several. I was trying to leave those collections just as I received them from the FAA (duplicates and all). I'm hoping to do a *much* better job at distributing the files once I see how the next set (due last week) looks. I'm thinking that I'll probably have an rsync interface at least. --kyler |
WAC vs Sectional | [email protected] | Instrument Flight Rules | 60 | February 8th 05 12:22 AM |
AVIATIONTOOLBOX: How do you like your maps stitched? | Kyler Laird | General Aviation | 24 | December 10th 03 04:10 AM |
source for edges of FAA sectional maps? | Kyler Laird | General Aviation | 2 | November 29th 03 03:09 PM |
