Researching a question from a club member, I read in the FAR's:
§**23.207 *Stall warning. [...] (b) The stall warning may be furnished either through the inherent aerodynamic qualities of the airplane or by a device that will give clearly distinguishable indications under expected conditions of flight. Every plane I've ever flown has a mechanical stall warning device (some visual, some aural), but apparantly it's possible to certify a plane without one. Does anybody know of any real life examples of planes certified without stall warning devices? |
Roy Smith wrote:
Researching a question from a club member, I read in the FAR's: § 23.207 Stall warning. [...] (b) The stall warning may be furnished either through the inherent aerodynamic qualities of the airplane or by a device that will give clearly distinguishable indications under expected conditions of flight. Every plane I've ever flown has a mechanical stall warning device (some visual, some aural), but apparantly it's possible to certify a plane without one. Does anybody know of any real life examples of planes certified without stall warning devices? Roy, I own a Piper Pacer (PA22/20, Tripacer converted to Tailwheel configuration) It was originally built by Piper in 1958 (fairly late model as TriPacers go). It has no stall warning vane/switch/horn/light, and never had one. None of the PA12/14/20/22 series do. Dunno about PA18. This one has STCed add-on very droopy wingtips (inverted winglet). The stall is very benign. Prestall indication is a slight buffet, followed by the nose dropping (assuming you keep the yoke full back, i.e. you are not proactively helping it recover), followed by self recovery as a slight dive, followed by the nose going back up again for another mini-stall... Sort of a "nodding" motion. btw- the stall occurs at an indicated airspeed of ~45mph... MikeM PA22/20 Pacer '00Z see http://home.utah.edu/~mgm17160/Island/flying.jpg |
![]() "Roy Smith" wrote in message ... Every plane I've ever flown has a mechanical stall warning device (some visual, some aural), but apparantly it's possible to certify a plane without one. Does anybody know of any real life examples of planes certified without stall warning devices? Navions don't have one. I believe it's optional on Maules. |
"Ron Natalie" wrote: Navions don't have one. I believe it's optional on Maules. Are these CAR-3 or a FAR-23? Now that I think about it, I've flown a Decathlon. I honestly don't remember if it had a stall warning or not. My recollection is you knew you were stalled when you saw the ground going round-and-round :-) |
![]() "Roy Smith" wrote in message ... In article , "Ron Natalie" wrote: Navions don't have one. I believe it's optional on Maules. Are these CAR-3 or a FAR-23? Now that I think about it, I've flown a Decathlon. I honestly don't remember if it had a stall warning or not. My recollection is you knew you were stalled when you saw the ground going round-and-round :-) The Navion is CAR 3. Dunno about the Maule. |
... Researching a question from a club member, I read in the FAR's: § 23.207 Stall warning. [...] (b) The stall warning may be furnished either through the inherent aerodynamic qualities of the airplane or by a device that will give clearly distinguishable indications under expected conditions of flight. Every plane I've ever flown has a mechanical stall warning device (some visual, some aural), but apparantly it's possible to certify a plane without one. Does anybody know of any real life examples of planes certified without stall warning devices? Planes I've flown without stall warning devices: Bellanca 7ECA Citabria Piper J3 Cub Piper PA11 Cub Piper PA12 Super Cruiser Piper PA18 Super Cub Many older aircraft do not have them, heck, the stall horn in a C172 startled me for a second after flying rag wing Pipers for a few hundred hours... -- Mike |
Add my Taylorcraft BC12D. But most of these were CAA.
Don |
Roy Smith wrote: Researching a question from a club member, I read in the FAR's: §**23.207 *Stall warning. [...] (b) The stall warning may be furnished either through the inherent aerodynamic qualities of the airplane or by a device that will give clearly distinguishable indications under expected conditions of flight. Every plane I've ever flown has a mechanical stall warning device (some visual, some aural), but apparantly it's possible to certify a plane without one. Does anybody know of any real life examples of planes certified without stall warning devices? My Johnson Rocket has no stall warning devise, nor stall strips, yet it gives a nice, straight-ahead stall, with plenty of warning, and was a real hot rod by 1946 standards. |
On Fri, 16 Jan 2004 03:49:16 -0000, Marty Shapiro
wrote: The SOCATA Rallye does NOT have a stall warning device! It has automatic leading edge slats which will pop out at larger angels of attack, but you are still well above stall. A power off stall is very interesting in this aircraft. You start to get stall buffett and, if you simply hold the yoke all the way back, you descend a little over 1000 fpm with the nose level on the horizon. You can turn with just the ailerons as you are descending. What happens if you yank the sitck back? Or if you start to apply rudder to accelerate a turn and then apply opposite aileron to keep from banking too steeply and just keep on crossing the controls while you bleed off airspeed? Just curious. I'm sure the results in the Socata are benign. Don |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | March 1st 04 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | February 1st 04 07:27 AM |
Conspiracy Theorists (amusing) | Grantland | Military Aviation | 1 | October 2nd 03 12:17 AM |
Wing Extensions | Jay | Home Built | 22 | July 27th 03 12:23 PM |
