I've got some .035 4130 that I have to cut elevon ribs from. 2 inch on
one end, 3/8ths on the other and about 16" long (each one is a different length). The small end fits against a run of tube, the thick end against the elevon spar. Both ends have to be shaped appropriately. The sides of the long runs need to be perfectly straight. I've seen a lot of options on how to cut aluminum, but the info on steel seems to be more limited. Here's where I'm at so far. A shear big and strong enough to handle the job is currently out of my budget. (though, I keep hearing that the economy is coming back around) Harbor Freight has a $35 cutting tool that can handle the job according to the advertised specs. It sorta, kinda looks like an angle grinder, except that it has a short arm and a reciprocating tooth out one side. I figure I can drill a 3/8" hole, clamp a 2x4 to each side of the sheet as guides, and just make a run with the cutter. Anyone have experience with these things? Do they leave a clean edge? Another option is to pay a machine shop. If I can find a good shop, I'm sure to get quality work, but I can't say that I did it and I won't have a tool afterward. I'm saving that as a last resort. Are there any better options? -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
..035 isn't that thick and 'perfectly straight' is relative but the average
nibbler will be close to its limit. One of the most commonly used tools in my shop is the throatless shear. First thing I would do is make up an accurate pattern showing the centers of any holes plus at least two tooling holes. I'd lay that out with at least a sixteenth outside the finish line and do all the drilling in the flat. Then whack them into APPROXIMATE size with the throatless shear, phasor (ie, plasma cutter), bandsaw or abrasive disk. Once cut the edges have to be treated so the pieces will lie flat against each other. They they get bolted together using the tooling holes. Now I've got a steel BAR about three-eights thick by 16" long, which should be pretty easy to bring to finished size using a file, disk grinder, belt sander or whatever.. I think you'll find that uniformity will have a higher priority than absolute dimensional accuracy. -R.S.Hoover |
Ernest Christley wrote: I've got some .035 4130 that I have to cut elevon ribs from. 2 inch on one end, 3/8ths on the other and about 16" long (each one is a different length). The small end fits against a run of tube, the thick end against the elevon spar. Both ends have to be shaped appropriately. The sides of the long runs need to be perfectly straight. I've seen a lot of options on how to cut aluminum, but the info on steel seems to be more limited. Here's where I'm at so far. A shear big and strong enough to handle the job is currently out of my budget. (though, I keep hearing that the economy is coming back around) Harbor Freight has a $35 cutting tool that can handle the job according to the advertised specs. It sorta, kinda looks like an angle grinder, except that it has a short arm and a reciprocating tooth out one side. I figure I can drill a 3/8" hole, clamp a 2x4 to each side of the sheet as guides, and just make a run with the cutter. Anyone have experience with these things? Do they leave a clean edge? Another option is to pay a machine shop. If I can find a good shop, I'm sure to get quality work, but I can't say that I did it and I won't have a tool afterward. I'm saving that as a last resort. Are there any better options? I have a very large pair of sheet metal shears thet I have use to cut ..032 4130. It takes a lot of effort, but is doable. |
Save yourself a lot of aggravation. Do not buy anything from "Harbor
Fright". All they sell is junk and it never works like they say. You would have a lot more fun throwing the money in your toilet and watching it swirl around as you flush. Harbor Freight has a $35 cutting tool that can handle the job according to the advertised specs. It sorta, kinda looks like an angle grinder, except that it has a short arm and a reciprocating tooth out one side. I figure I can drill a 3/8" hole, clamp a 2x4 to each side of the sheet as guides, and just make a run with the cutter. Anyone have experience with these things? Do they leave a clean edge? |
If this is a one time project and you do not see the need for a proper shear in
your future, find someone near you with a shear, pay them to cut the ribs for you. Or, if they will allow, use their shear to cut the ribs. We let locals use our shear now and then. Kevin |
Since most builders only need to cut a batch of sheet steel occasionally,
why not try a water jet cutting service. A friend here in Perth was rebuilding a car and had a new steel firewall made up from a CAD drawing at very reasonable cost. There are plenty of service providers in the USA - have a look at http://www.precisioncuttingservice.com/ in Savanna GA for example. One local company here in Perth has done many instrument panels out of sheet aluminum. Phil Maley Perth Australia |
For lists of waterjet job shops in the USA or International visit the
following link: http://www.waterjets.org/waterjet_jobshops.html http://www.waterjets.org/internation..._jobshops.html Or, call OMAX Corporation to ask for specific shops in your area: http://www.omax.com (or 253 872 2300 or 800 838 0343) - Carl "Phil" philatwotechdotcomdotau wrote in message ... Since most builders only need to cut a batch of sheet steel occasionally, why not try a water jet cutting service. A friend here in Perth was rebuilding a car and had a new steel firewall made up from a CAD drawing at very reasonable cost. There are plenty of service providers in the USA - have a look at http://www.precisioncuttingservice.com/ in Savanna GA for example. One local company here in Perth has done many instrument panels out of sheet aluminum. Phil Maley Perth Australia |
"Jimmy Galvin" wrote in message ... Save yourself a lot of aggravation. Do not buy anything from "Harbor Fright". All they sell is junk and it never works like they say. You would have a lot more fun throwing the money in your toilet and watching it swirl around as you flush. Harbor Freight has a $35 cutting tool that can handle the job according to the advertised specs. It sorta, kinda looks like an angle grinder, except that it has a short arm and a reciprocating tooth out one side. I figure I can drill a 3/8" hole, clamp a 2x4 to each side of the sheet as guides, and just make a run with the cutter. Anyone have experience with these things? Do they leave a clean edge? I think it is pretty obvious from the prices that the stuff you get from Harbor Freight is not "top of the line". That said, I have bought a lot of stuff from them that works just fine. My air powered pop rivet gun has built 3 airplanes so far. I only paid $39.00 for it. My band saw has cut anything I have need to cut on 3 airplanes. The snowmobile casters that I bought from them hold my Pulsar just fine and allow me to put it in the T hangar, behind the pole, and still fit my Waco in too. It is a bit of an overstatement to say that nothing Harbor Freight sells works. Rick Pellicciotti |
You have stated a valid view point. I have been in construction all of my life. I made a living using tools. I am not satisfied with less than top of the line tools because they make life soooooo much easier. An example would be I use Milwaukee drills. I would not walk across the hall to get a free Master Mechanic drill. I don't care for their quality but if you are satisfied with their products then that's fine. I think it is pretty obvious from the prices that the stuff you get from Harbor Freight is not "top of the line". That said, I have bought a lot of stuff from them that works just fine. My air powered pop rivet gun has built 3 airplanes so far. I only paid $39.00 for it. My band saw has cut anything I have need to cut on 3 airplanes. The snowmobile casters that I bought from them hold my Pulsar just fine and allow me to put it in the T hangar, behind the pole, and still fit my Waco in too. It is a bit of an overstatement to say that nothing Harbor Freight sells works. Rick Pellicciotti |
| air drill question | Ded Dog | Home Built | 24 | November 24th 03 11:43 PM |
| blue foam & cutting it | Richard Riley | Home Built | 6 | November 24th 03 02:53 PM |
| Pitts Special Steel Tube Fuse Mod. | Martin Morgan | Home Built | 0 | November 24th 03 12:08 AM |
| steel 4130 | Philippe Vessaire | Home Built | 4 | October 19th 03 08:19 AM |
| Sheet metal shear/press brake | VideoFlyer | Home Built | 7 | October 7th 03 08:08 PM |
