I had a wierd thing happen a week or so ago.
We were VFR, and called up POU tower (class D satellite of NY Approach), 10 southwest landing with blah, blah. The tower controller told us to squawk standby. After confirming that instruction, we did so and a little while later he told us to squawk vfr. When we asked what that was all about, he said it was for radar identification. A little while later, he did the same thing to another incomming flight. Any idea what might have been going on? The only thing I can think of is some sort of equipment malfuction which let him see that there was a secondary return, but not read the code or see idents. Is that possible? |
The Only time I have ever had a controler tell me to squawk standby
was when I was in a flight of 2 bringing a plane back after we had an engine overhauled. He did not want 2 transponders next to each other because the computer would go nuts having two so close to each other. He then communticated with the lead pilot and I was to follow the same directions. Scott On Mon, 22 Mar 2004 09:40:27 -0500, Roy Smith wrote: I had a wierd thing happen a week or so ago. We were VFR, and called up POU tower (class D satellite of NY Approach), 10 southwest landing with blah, blah. The tower controller told us to squawk standby. After confirming that instruction, we did so and a little while later he told us to squawk vfr. When we asked what that was all about, he said it was for radar identification. A little while later, he did the same thing to another incomming flight. Any idea what might have been going on? The only thing I can think of is some sort of equipment malfuction which let him see that there was a secondary return, but not read the code or see idents. Is that possible? |
![]() "Roy Smith" wrote in message ... I had a wierd thing happen a week or so ago. We were VFR, and called up POU tower (class D satellite of NY Approach), 10 southwest landing with blah, blah. The tower controller told us to squawk standby. After confirming that instruction, we did so and a little while later he told us to squawk vfr. When we asked what that was all about, he said it was for radar identification. A little while later, he did the same thing to another incomming flight. Any idea what might have been going on? The only thing I can think of is some sort of equipment malfuction which let him see that there was a secondary return, but not read the code or see idents. Is that possible? What code were you on when you initially called? |
In article et,
"Steven P. McNicoll" wrote: "Roy Smith" wrote in message ... I had a wierd thing happen a week or so ago. We were VFR, and called up POU tower (class D satellite of NY Approach), 10 southwest landing with blah, blah. The tower controller told us to squawk standby. After confirming that instruction, we did so and a little while later he told us to squawk vfr. When we asked what that was all about, he said it was for radar identification. A little while later, he did the same thing to another incomming flight. Any idea what might have been going on? The only thing I can think of is some sort of equipment malfuction which let him see that there was a secondary return, but not read the code or see idents. Is that possible? What code were you on when you initially called? 1200. |
![]() "Roy Smith" wrote in message ... In article et, "Steven P. McNicoll" wrote: "Roy Smith" wrote in message ... I had a wierd thing happen a week or so ago. We were VFR, and called up POU tower (class D satellite of NY Approach), 10 southwest landing with blah, blah. The tower controller told us to squawk standby. After confirming that instruction, we did so and a little while later he told us to squawk vfr. When we asked what that was all about, he said it was for radar identification. A little while later, he did the same thing to another incomming flight. Any idea what might have been going on? The only thing I can think of is some sort of equipment malfuction which let him see that there was a secondary return, but not read the code or see idents. Is that possible? What code were you on when you initially called? 1200. Happens 'round here all the time. He sees a 1200 squawk and thinks it is you. You go to stand-by and you disappear from radar. He now knows it is you when you squawk 1200 again. Seems to always happen at Class D airports. Can they assign unique Xponder codes? Seems to me they can't. |
Why don't they simply ask you to ident? I'm thinking maybe the mode C
wasn't working and they wanted him to recycle is transponder. "Dave Stadt" writes: Happens 'round here all the time. He sees a 1200 squawk and thinks it is you. You go to stand-by and you disappear from radar. He now knows it is you when you squawk 1200 again. Seems to always happen at Class D airports. Can they assign unique Xponder codes? Seems to me they can't. |
![]() "Bob Fry" wrote in message ... Why don't they simply ask you to ident? Depends on the equipment and how it's set up. He may not be able to see an ident on a 1200 code. I'm thinking maybe the mode C wasn't working and they wanted him to recycle is transponder. The Mode C would have no effect on the target itself. |
Dave Stadt wrote:
Happens 'round here all the time. He sees a 1200 squawk and thinks it is you. You go to stand-by and you disappear from radar. He now knows it is you when you squawk 1200 again. But isn't that what 'ident' is for? jue |
On Mon, 22 Mar 2004 23:56:29 GMT, "Dave Stadt" wrote:
Happens 'round here all the time. He sees a 1200 squawk and thinks it is you. You go to stand-by and you disappear from radar. He now knows it is you when you squawk 1200 again. Seems to always happen at Class D airports. Can they assign unique Xponder codes? Seems to me they can't. I guess it depends on the ATC equipment. The Class D airport I fly out of (VNY) can assign unique squawk codes and does all the time when it gets busy. Ron Kelley |
![]() "Roy Smith" wrote in message ... 1200. I suspect he saw multiple targets squawking 1200 in the same general location. He had you squawk standby to see which one you were. Depending on the equipment in use and how it's set up, he may or may not see an ident on a 1200 code. |
When does IFR begin in VFR? | Wizard of Draws | Instrument Flight Rules | 62 | February 13th 05 11:19 PM |
Radar contact before squawk | David Brooks | Instrument Flight Rules | 20 | March 25th 04 01:34 AM |
Non-radar transponder codes | Michael | Instrument Flight Rules | 16 | February 13th 04 01:15 PM |
Lost comms after radar vector | Mike Ciholas | Instrument Flight Rules | 119 | January 31st 04 11:39 PM |
