Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Would you cycle the gear?
Old March 30th 04, 06:25 PM
Roy Smith
Default Would you cycle the gear?
I had an interesting experience the other day.
I was with a student in one of our club Arrows. We put the gear down
and got green lights for the 2 mains, but not for the nose.
The nose green light was flashing, as was the yellow "gear in transit"
light. Both were flashing about twice per second, and in opposition
(i.e. as the green went on, the yellow went off, and vice versa).
We ran the checklists in the POH, but did not try to cycle the gear. My
theory at the time was that since we had indication of both mains down
and locked, we should probably not mess with things any more.
On the one hand, cycling it might have fixed whatever was wrong.
On the other hand, what we had now (both mains down and locked) was not
only a survivable configuration, but one which would result in
relatively minor damage if the nose gear was indeed not locked (prop
strike). If something was jammed mechanically, cycling it could have
possibly resulted in no gear at all, or (worse) asymmetric extension).
We told the tower what was going on and requested a low pass so they
could look under the plane to see what was there. Tower reported all
three gear appeared to be down, so I just landed as gently as I could.
I was relieved when everything held together.
The maintenance people were unable to reproduce the problem and the
plane was returned to service. Best guess is a slight misalignment of
one of the limit switches.
What would you have done? Would you have cycled the gear hoping to fix
the problem, or would you have accepted the possible unlocked nosegear
in exchange for the known locked mains?
For those that are worried about such things, the outfall of our
declaring an emergency was about 2 minutes worth of paperwork. The fire
truck followed us to the ramp and the crew asked us a couple of
questions for their report. The tower also shut the runway until the
airport operations folks did a FOD inspection and declared it open again
(which must have taken all of about a minute).
Old March 30th 04, 07:23 PM
David Cartwright
"Roy Smith" wrote in message
I'd have made the same decision as you - stick with what seems to be a
pretty good situation (instead of risking cycling the gear and ending up
worse off), get the tower to have a shufti at your dangly bits, and on
receiving a promising report from them, attempt a gentle approach, holding
the nose off for as long as is practical.
The only thing I'd be tempted to do in addition, assuming your airfield is
big enough, you're experienced enough, and there's enough time to make it a
reasonably safe manoeuvre, is to make a power-off, glide landing, and to get
the second pair of hands in the cockpit (in this case your student) to crank
the propeller with the starter so it's roughly horizontal and thus won't
bash the runway. A prop strike will generally shock-load the engine and
necessitate a complete strip down.
This said, the usual rules apply: if in doubt, take the approach that is
most likely to get you walk away from the "landing", and if that means
shock-loading the engine, so be it.
First rule of declaring an emergency: never, ever be afraid to do it. The
ATC people would rather you promptly report something that turns out to be a
false alarm, as it gives them more time to figure out what to do with that
line of 767s that's coming up fast behind you than would be the case if you
landed with a nasty splat on only 66.67% of your wheels. And even if the
fire crew's talents aren't needed, they get a bit of training value out of
the exercise. Of course, if you do it three times a week because of poor
maintenance, they have the right to be peeved :-)
D.
Old March 30th 04, 08:09 PM
MikeM
Have you ever actually attempted to stop the prop while in flight?
Old March 31st 04, 03:56 AM
Yup. Was the proud holder of a student certificate at the time.
Did it a 2 1/2-year-old Malibu Mirage at an altitude of approx. 5 feet
AGL at the approach end of a 4000 ft runway. While I secured the
engine, and then held the nose off, the guy in the right seat reached
between my knees and bumped the prop.
Engine had a little over 6 hours SNEW. Wouldn't have attempted it by
myself (moot point, at that time, I wasn't insurable in it by myself).
No nose indication on downwind. Guys on the ground reported that it
looked like it was down and was pointing in the proper direction (nose
wheel rotates about 90 degrees during extension/retraction) Retracted
landing gear, right seater verified pump operation sounded "normal".
Made one extra circuit around the pattern with the emergency checklist
in my lap. Emergency extension per the checklist netted no nose
indication. Retracted landing gear, tried one more normal extension,
right seater again verified pump cycled on and off normally. Did a
pre-final approach briefing discussing precisely who was doing what
and when.
Had three green when the airplane coasted to a stop. Have absolutely
no idea when in the sequence of events during touchdown when the light
lit and the gear horn stopped blowing. CFII/ATP-rated pilot in the
right seat didn't either. While not legally PIC, I remained the
PilotOperatingTheControlsAndMakingAllTheDecisions.
If I would have been without experienced help in the other front seat,
there is no way I would have screwed around with trying to "save" the
engine/prop.
FWIW, in the Arrow scenario, if the nose gear looked good from the
ground, and the green light/in transit light was cycling as described,
I would have landed with no attempt to "cycle the gear", holding the
nose off.
If the three green lights aren't lit in an Arrow, the pump will be
running (accompanied by the in transit/pump light). Worn bushings in
the nose trunnion pivot/retract/extend/downlock assembly will often
first cause the "cycling" effect when turning a corner on the ground.
First time it happened to me (Fall of 1989 in a Turbo 'Toga SP) I'm
pretty sure I pee-ed a little.
When the pump light is lit, hydraulic pressure will indeed assist in
helping the nose gear stay extended.
TC
Old April 3rd 04, 02:37 PM
Richard Kaplan
"David Cartwright" wrote in message
a
get
crank
And if you do this, you might very appropriately find the FAA filing an
enforcement action against you for careless and reckless operation.
Stopping the engine for economic reasons converts a situation with 100%
survivability potential to a situation where you have no ability to do a go
around or cushion a landing with power or add power if you are landing
short.
Richard Kaplan, CFII
www.flyimc.com
Old April 3rd 04, 04:29 PM
Dale
In article m,
short.
Not to mention that the propellor probably won't stop turning to begin
with.
Dale L. Falk
Old April 15th 04, 03:11 PM
Michael Houghton
Howdy!
....so you'd voluntarily turn a routine landing into a dead-stick landing?
Including the fun part of getting the prop to stop?
As long as the fan is keeping the pilot cool, why give it up?
The big doubt above is getting the prop actually stopped while leaving
yourself in a position to make a reasonalbe approach and landing.
yours,
Michael
Michael and MJ Houghton | Herveus d'Ormonde and Megan O'Donnelly
| White Wolf and the Phoenix
Bowie, MD, USA | Tablet and Inkle bands, and other stuff
http://www.radix.net/~herveus/
Old April 15th 04, 05:38 PM
Richard Kaplan
"Michael Houghton" wrote in message
Don't do it. Sacrifice the prop/engine.
www.flyimc.com
Old March 30th 04, 08:52 PM
Ben Jackson
There were two options: Cycle the gear, and try an emergency extension.
There are so many different gear systems out there it's hard to say what
would help.
I'd say a bad limit switch is a reasonable guess, but I wouldn't be so
quick to rule out an actual failure to lock. Some tiny last bit of
travel to get a cam overcenter or a lock in place.
Hydraulic and combination electric/hydraulic runs the risk of running
out of fluid if there's a leak. That's the case in the Arrow, right?
On the other hand, isn't the fluid just there to hold the gear *up*? In
theory it should just fall down (spring assist?). Some of the big Cessnas
can 'blow' the gear down with compressed gas if the hydraulics run out.
My Comanche's gear is all mechanically interconnected, and there is only
one down light. If it didn't light my first thought would be to slow way
down and try again (slowing down is part of the emergency extension anyway),
and follow through on the manual extension lever to help the electric motor.
If I felt the downlock through the lever I'd be tempted to leave the motor
engaged, since it helps hold the gear in place, and there's likely not much
more I could do with the lever alone. You can't re-engage the motor in
the air, you have to jack it up. After the flight you probably install one
of those little parabolic mirrors on the left wingtip for checking the
gear (every PA-24 I've flown but my own has had one
The Mooney is similar to the Comanche (ie I see no harm in cycling it,
other than the battery drain, since those big motors draw more than the
alternator can continuously supply). My brief Mooney gear training did
not include any caveats about the manual extension being "weaker" than
electric extension, so I'd be tempted to try it. It's a cable you pull
sort of like starting a lawnmower, and you get a gear down indication
through a little window. You *can* go back to electric gear in the air
if you change your mind.
Ben Jackson
http://www.ben.com/
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 03:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 06:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 04:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 07:24 AM
Landing gear door operation Elliot Wilen Military Aviation 11 July 8th 03 04:30 AM
