Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Chrome plating rocker covers
Old May 13th 04, 01:29 AM
Default Chrome plating rocker covers
Might not be that significant, but not as much heat will transfer from the oil
splashing around in the rocker box to air passing over the cover if it's
chromed.
On Wed, 12 May 2004 23:37:44 +0100, Peter wrote:
Hi All,
After just two years from new, the paint has mostly come off the
Lycoming IO-540 rocker covers, and I have taken the opportunity of an
annual to get them chrome plated.
I've had various non-aviation bits chromed in the past, both polished
and satin chrome.
But, having cleaned the covers out, I noticed that the steel is plated
with something, possibly cadmium. Presumably this will need to be
removed first. What would happen if the chrome plating on the inside
of the rocker covers started to peel off in chunks? It would really
mess up lubrication... And chrome plating can do that unless done
absolutely correctly.
Should I take care to not plate the inside of the covers?
Any suggestions much appreciated.
Peter.
Old May 13th 04, 02:04 AM
rip
A few chromium flakes in your oil, and you can kiss that engine goodbye.
Peter wrote:
Hi All,
and satin chrome.
Peter.
Return address is invalid to help stop junk mail.
E-mail replies to but remove the X and the Y.
Please do NOT copy usenet posts to email - it is NOT necessary.
Old May 13th 04, 03:14 AM
Orval Fairbairn
Peter wrote:
Hi All,
and satin chrome.
Why not strip the paint from the exteriors and ahve tham powder coated?
The stuff cures at 400 degrees.
An alternative is to strip them, then epoxy prime and paint with
polyurethane.
Old May 14th 04, 05:31 AM
Jay Honeck
Lycoming sells chrome-plated covers. Buy theirs.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
