For you guys flying injected engines.
I'm flying a Cessna P206C with the Continental IO-520. It quite often will quit on rollout after landing. I'm being told that it is probably vapor lock causing an interruption in fuel flow. I'm not convinced. The ambient temps are in the 60s to 70s. The airplane is being used to haul skydivers so it's a climb from 250 MSL to 13000MSL, then a power descent back down for the landing with the engine well leaned. Cowl flaps are opened on base or final once the speed is down to 100IAS or so (this is being done to help prevent the vapor lock). Today the airplane cutout right after liftoff, it was as if the throttle had been pulled back, I noticed the fuel flow was fluctating at about 1/2 or less the normal flow rate for takeoff. Only lasted a moment and power returned before I could get the boost pump on. It then ran normally up to 13K. An inspection has not found anything in the fuel system (filters, screens, injectors, etc). Again, I was told it was probably vapor lock. I'm not convinced. G Has anyone experienced anything similar? Does your injected engine quit on rollout? Have you experienced vapor lock during high power operation? or at anytime other than start? I also fly a turbo-charged P206 that doesn't suffer from the "vapor lock" problem. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
On Fri, 06 Aug 2004 22:21:13 -0800, Dale wrote:
For you guys flying injected engines. I'm flying a Cessna P206C with the Continental IO-520. It quite often will quit on rollout after landing. I'm being told that it is probably vapor lock causing an interruption in fuel flow. I'm not convinced. The ambient temps are in the 60s to 70s. The airplane is being used to haul skydivers so it's a climb from 250 MSL to 13000MSL, then a power descent back down for the landing with the engine well leaned. Cowl flaps are opened on base or final once the speed is down to 100IAS or so (this is being done to help prevent the vapor lock). Today the airplane cutout right after liftoff, it was as if the throttle had been pulled back, I noticed the fuel flow was fluctating at about 1/2 or less the normal flow rate for takeoff. Only lasted a moment and power returned before I could get the boost pump on. It then ran normally up to 13K. An inspection has not found anything in the fuel system (filters, screens, injectors, etc). Again, I was told it was probably vapor lock. I'm not convinced. G Has anyone experienced anything similar? Does your injected engine quit on rollout? Have you experienced vapor lock during high power operation? or at anytime other than start? I also fly a turbo-charged P206 that doesn't suffer from the "vapor lock" problem. Dale, My fuel injected engine is a Lycoming IO360 and the only time it quit on rollout was after I had landed at Leadville, CO (9928' MSL). I attributed that to the mixture being too rich for that altitude. Other times when it "almost quit" on rollout were when the idle setting required adjustment. So perhaps checking your idle and mixture adjustments would be a place to start. --ron |
I had my carb'd O-360 quit shortly after takeoff and traced it to a mud-dauber
nest in the fuel line on the right tank. It was fine in cruise when the fuel flow was lower, but on full-rich takeoff the pump couldn't pull it through the partial blockage fast enough. I'm not sure how the 206 is plummed, but partial blockages could cause the takeoff problem. Vapor locking does sound like a potential culprit. You don't burn much fuel for the entire descent so any fuel in the engine compartment hangs out for awhile and cooks.... especially with cowl flaps closed to keep from shocking the cylinders. I wouldn't be surprised if you've got two problems, though. -Cory Dale wrote: : For you guys flying injected engines. : I'm flying a Cessna P206C with the Continental IO-520. It quite often : will quit on rollout after landing. I'm being told that it is probably : vapor lock causing an interruption in fuel flow. I'm not convinced. : The ambient temps are in the 60s to 70s. The airplane is being used to : haul skydivers so it's a climb from 250 MSL to 13000MSL, then a power : descent back down for the landing with the engine well leaned. Cowl : flaps are opened on base or final once the speed is down to 100IAS or so : (this is being done to help prevent the vapor lock). Today the airplane : cutout right after liftoff, it was as if the throttle had been pulled : back, I noticed the fuel flow was fluctating at about 1/2 or less the : normal flow rate for takeoff. Only lasted a moment and power returned : before I could get the boost pump on. It then ran normally up to 13K. : An inspection has not found anything in the fuel system (filters, : screens, injectors, etc). Again, I was told it was probably vapor lock. : I'm not convinced. G : Has anyone experienced anything similar? Does your injected engine quit : on rollout? Have you experienced vapor lock during high power : operation? or at anytime other than start? : I also fly a turbo-charged P206 that doesn't suffer from the "vapor : lock" problem. : -- : Dale L. Falk : There is nothing - absolutely nothing - half so much worth doing : as simply messing around with airplanes. : http://home.gci.net/~sncdfalk/flying.html -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering Ph.D. Graduate Student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
| Thread Tools | |
| Display Modes | |
