Thermal Velocities
Old October 18th 10, 03:22 PM posted to rec.aviation.soaring
JSoar
Default Thermal Velocities
I have been test flying my new self-launching ultralight sailplane
design this fall, and it is going well. The Red Tail Hawk so far looks
like it has a glide ratio of around 21/1 at about 60 mph, which is at
the low end of the range of what was expected. But it has a minimum
sink of about 250 fpm at around 50 mph, which is worse than I had
hoped.
I have subscribed to XC Skies and have been watching the soaring
forecasts for tops of useable lift and thermal velocity for about a
month now, and seeing some 300 to 400' thermal velocities predicted
these fall days. That rate does not leave a lot left for climb at the
250 fpm sink rate of the Red Tail Hawk.
I'm in the central Illinois area. What I was wondering is what kind of
thermal velocities might I expect for next year during the prime part
of the soaring season. Is there some easy to read historical data
somewhere I could go thru? Or does anyone here have any anecdotal data
they could provide?
Thanks in advance,
Jerry Booker
http://groups.yahoo.com/group/RedTai...ightSailplane/
Old October 18th 10, 03:52 PM posted to rec.aviation.soaring
Frank Whiteley
hoped.
they could provide?
Thanks in advance,
Jerry Bookerhttp://groups.yahoo.com/group/RedTailHawkUltralightSailplane/
1. If you don't have SeeYou, download a copy here
http://www.naviter.si/products/seeyou.php?Itemid=213
The evaluation copy will allow you to examine flight logs.
2. Go to the OLC and register so you can log in.
http://www.onlinecontest.org/olc-2.0...st=olc&sp=2011
Change soaring region to USARegion 7
Change OLC Scoring to Statistic:Airfield
Change period by year. Find the airfields nearest you then click on
them to find the flights. Click the info button for the flight on the
right. From there you can see the flight log and download the IGC
file (after logged in) and start your analysis for the dates.
Frank Whiteley
Where is the next thermal? danlj Soaring 36 September 28th 09 12:12 AM
Landing on a sloping runway with different wind velocities Tony Cox Piloting 47 October 16th 06 03:31 PM
Which Way is That Thermal? ContestID67 Soaring 26 September 9th 06 08:30 PM
Thermal Data Files Thermal Mapping Project Australia Mal Soaring 0 December 2nd 05 11:14 PM
Units for velocities in forward motion/vertically masa Soaring 0 October 13th 05 10:43 AM
