OLC 2011
Old October 19th 10, 01:00 AM posted to rec.aviation.soaring
dhaluza
Default OLC 2011
The new OLC season has started. There are a few rule changes everyone
should know about.
The FAI-OLC score is now a 30% bonus on the OLC Classic score, and
this combined score is now called OLC-Plus.
For the OLC classic score, legs 5 & 6 are no longer devalued. All six
legs are scored @100%.
There is now a Barron Hilton Challenge for flights on an
electronically pre-declared triangular course.
Most importantly, the submission deadline has changed to 48 hours
after landing (not midnight Tuesday as before).
For more info, go to the OLC web site:
http://www.onlinecontest.org/olc-2.0/gliding/
Doug Haluza
SSA-OLC Admin
Old October 19th 10, 02:38 AM posted to rec.aviation.soaring
Mike the Strike
Default OLC 2011
should know about.
Doug Haluza
SSA-OLC Admin
Been asleep for the last week, Doug?
There are two threads on this already.
Mike
Old October 19th 10, 01:39 PM posted to rec.aviation.soaring
Mike the Strike
Default OLC 2011
should know about.
Doug Haluza
SSA-OLC Admin
Mike
Just a gentle ribbing - but there were a few questions about the
impact on USA soaring, particularly the new 48 hour rule and the
restriction on aerotows longer than 15km, which will impact a number
of mainly western sites.
Perhaps you could review these and forward our concerns to the OLC
organizers?
Mike
Old October 19th 10, 04:24 PM posted to rec.aviation.soaring
Greg Arnold[_2_]
Default OLC 2011
On 10/19/2010 5:39 AM, Mike the Strike wrote:
Doug Haluza
SSA-OLC Admin
Mike
organizers?
Mike
I really don't understand the reason for the 48 hour rule. Most pilots
post immediately, because if they delay for a day none of their friends
will see their flight (since few of us look at posts from a day or two
earlier). Therefore, prompt posting will naturally occur without any
OLC rule on the matter. The OLC has to cut off postings at some point,
I suppose, but why not a week?
I also don't understand the reason for the 15km rule, but suspect that
it may be a poor attempt to solve a real problem. I do know that where
I fly there is never any lift within 15km of the airport. We have to
tow to the hills/mountains, which is about 20km. If the airport was
instead located at the base of the hills/mountains, the 15km rule would
be no problem. So my inability to compete in the OLC is a function of
the decision made decades ago about where to locate the airport. I
don't understand why airport location is relevant to the OLC.
Old October 19th 10, 05:22 PM posted to rec.aviation.soaring
Default OLC 2011
"Greg Arnold" wrote in message ...
I've been thinking about the 48 hr rule and locations that it may affect. The first place/location that came to mind as being impacted is the annual Willamette Valley Soaring Club's (http://www.wvsc.org) trip to the Alvord Desert. The nearest village is Fields, OR population 86. (http://en.wikipedia.org/wiki/Fields,_Oregon) To get to Fields from the soaring site one must drive about 35 to 40 miles on an unpaved road.
I find both the posting time and tow-distance rules prejudicial /exclusionary in nature. I wonder if there is/or could be a process for granting waivers for isolated locations and airfield located distances in excess of 15km away from lift.
http://www.soaridaho.com
Old October 19th 10, 06:06 PM posted to rec.aviation.soaring
Greg Arnold[_2_]
Default OLC 2011
As a follow-up, it might be useful to explain why there is no lift
around many of the gliderports in California. It is because the Pacific
Ocean is very cold along the coast (basically, the ocean currents bring
down cold water from up north), and this cools the air and creates an
almost permanent inversion in many valleys, even those far from the
ocean. For example, the ocean air has to follow a path of approximately
200 km before it reaches the soaring site at Williams (in the Sacramento
Valley), yet that is enough to make the airport area unsoarable. Pilots
at Williams must tow to hills/mountains that are more than 30 kilometers
away.
I would think that there must be similar problems in Europe?
Old October 19th 10, 11:32 PM posted to rec.aviation.soaring
dhaluza
Default OLC 2011
Mike
I guess I missed it. Hard to keep track of everything with the signal
to noise ratio here ;-)
I saw the article on the changes in Aerokurier, but my German is not
that good. I asked for an English summary before the season started,
but I didn't get one. So I had to claim a few flights on my own to
some first hand experience.
Unfortunately, the OLC team does not consult with us before making the
rule changes, so we are always behind the curve.
For the remote site problem, keep in mind that you can claim through
the OLC PDA interface on many mobile devices. If you have a SD logger,
and a mico SD card in an SD adapter, you can just take the micro SD
card from your logger to your phone to make a claim as long as you
have cell coverage, a web browser, and a data plan.
As far as the remote tow problem, I'm not sure how that rule came
about, and if we can get it suspended before the OLC League season
starts. I'll push for that.
Doug
Old October 20th 10, 04:54 AM posted to rec.aviation.soaring
5Z
Default OLC 2011
It's often hard enough to get a voice connection in huge portions of
the western US, let alone a reliable data link.
So, if one takes a long tow of more than 15km from airport A and
releases within 15km of airport B, can the flight then be claimed as
launching from B?
What if the glider and towplane do a touch & go at airport B? Yes,
I've done T&G on tow.
-Tom
Old October 20th 10, 08:05 AM posted to rec.aviation.soaring
Peter Scholz[_2_]
Default OLC 2011
launching from B?
No, that will not be covered by the rule.
What if the glider and towplane do a touch& go at airport B? Yes,
Yes, that will be counted as take-off from airport B.
Peter Scholz
ASW24 JE
Old October 22nd 10, 12:02 AM posted to rec.aviation.soaring
Gliderphud
Default OLC 2011
should know about.
Doug Haluza
SSA-OLC Admin
So has the OLC become antisemitic, anti-Christian and anti all
religions other than Islam? The rules have become draconian and geared
toward only those that have Saturday and Sunday free to fly, fly from
their local glider port with a house thermal within 15 km and have
instant access to the Internet. Yes they may be supported by
advertisers, but the advertisers are there because there is traffic to
the site. It is time for a new OLC site that listens to the pilots
and creates rules that are more inclusive and reasonable.
Boycott the current OLC!
A few suggestions:
1. At least three days to submit a file, four would be better
2. Drop the 15 km rule for non-motor gliders.
3. Make the league at least three days (or best two out of three),
i.e. Friday through Sunday so those of all faiths have an equal chance
to compete.
2011 USA competition schedule ? Dave Nadler Soaring 22 October 19th 10 08:07 PM
OLC Scoring for 2011 Mike the Strike Soaring 9 October 17th 10 03:41 AM
2011 US Sports Nationals Tim[_2_] Soaring 4 September 15th 10 08:13 PM
2011 15M Nationals Andy[_10_] Soaring 10 August 19th 10 05:23 PM
2011 USA 18M Nationals 5 ugly Soaring 3 August 18th 10 04:52 AM
