CAI 302 date problem
Old October 27th 10, 12:08 AM posted to rec.aviation.soaring
Bernie[_4_]
Default CAI 302 date problem
I flew yesterday (26 October) and had two hours, later I used the
Cambridge utility on my PDA to download the flight log from the
Cambridge 302.
First thing I noticed was that the utility said the flight was 111
hours long, and that the date of the flight was 21 October.
I later checked the log file in See You and it thinks it was 21 Oct.
also.
I then noticed that I had not reset the date in my PDA after replacing
the battery a few weeks back, it thought it was 2002.
However I can't see how the date in the secure .igc file could or
should be affected by that.
The only other thing I can think is that when I last flew (17th Oct ),
I flipped the master switch off rather than doing an orderly shutdown
on the 302.
Any ideas?
Old October 27th 10, 12:35 AM posted to rec.aviation.soaring
Darryl Ramm
Cambridge utility on my *PDA to download the flight log from the
Cambridge 302.
also.
on the 302.
Any ideas?
Is the C302 internal battery OK? Does the data in the file look OK
when you look at the flight in SeeYou? Did the Cambridge utility
complain about any security failures? I'm curious and will look at
the file - if you want to attach the file to an email and send to me
(or try posting it on OLC).
Darryl
Old October 27th 10, 12:47 AM posted to rec.aviation.soaring
Bernie[_4_]
Thanks Darryl,
I will post the file on the OLC when I get home from work this
afternoon, and email it to you.
The file looks complete in See You. The CAI utility did not complain
about it's integrity.
We also wondered about the internal battery in the 302, but after
checking the manual I
cannot even find any suggestion that one exists. I know that the
earlier Cambridge models
had them. The manual states " Flash memory is used for firmware as
well as flight logs. "
Regards, Bernie.
Old October 27th 10, 12:58 AM posted to rec.aviation.soaring
Tim Taylor
Cambridge 302.
also.
on the 302.
Any ideas?
First is the name of the file correct? Not the date but the actual
name of the file, should be a 0AQxxxx file name. If that is correct
the 302 is fine and it is the date on the PDA that is the problem.
The PDA will store the file under the current date it thinks it is.
If the file name is different then it is likely a 302 problem.
Old October 27th 10, 01:07 AM posted to rec.aviation.soaring
Bernie[_4_]
Thanks Tim.
I will check the file name tonight when I get home. (I'm in Australia,
we are working right now!)
I would have thought that the date in an .igc file would have been
derived from the GPS satellite data.
Certainly, when I copied the file from the PDA to my PC, it was
timestamped 2002, as per the PDA.
If the .igc file also said 2002, I would tend to agree with you. But
just 4 days earlier?
Regards, Bernie.
Old October 27th 10, 01:57 AM posted to rec.aviation.soaring
JS
Mr. Baer, from 13,000km away I believe Mr. Taylor has the answer.
Old October 27th 10, 02:07 AM posted to rec.aviation.soaring
Darryl Ramm
Ah? SeeYou and any other sane software will derive the date/duration
of the file from the IGC file HFDTE record and B record timestamps and
does not care what a file is named. And no software will care about
the filesystem time stamp on a file. What is going on should be
obvious within the IGC file.
If the download utility did not complain about security fail then the
battery backup should be fine.
Darryl
Old October 27th 10, 02:21 AM posted to rec.aviation.soaring
Bernie[_4_]
Hey Jim,
not sure that I agree yet, wishing I had the file here at work to take
a look at now!
Coming to Keepit this year? We're there for the NSW State titles in a
month or so.
BB.
Old May 3rd 16, 08:46 AM posted to rec.aviation.soaring
Dear All
The CLEAR LOG command in See You Moile works very easily so I wonder can SEE You mobile also e used to set the date and time in the Camridge 302 at the start of a days flying? Anyone know what the command is and correct syntax for the date and time?
See You mobile retains the command in a drop down menu so it would e easy to do each day
Thanks for your help
Martin
Old May 3rd 16, 02:07 PM posted to rec.aviation.soaring
Google on the 302 Data Port User's Guide. I don't see any way to set a date shown in that manual. It does mention another document called the Secure BIOS User's Guide that may include such details but I've never been able to find a copy of that document anywhere.
RS
On Tuesday, May 3, 2016 at 2:46:06 AM UTC-5, wrote:
Dear All
Martin
FSDO enforcement- GPS before effective date - which date to put in Aircraft Log for Part 43? Ron A. Instrument Flight Rules 18 March 15th 06 02:30 PM
First Date Jay Honeck Piloting 35 September 14th 05 04:42 AM
FS2004 date FWI Brian Summers Simulators 0 August 10th 03 04:24 AM
GPS 90b out of date? Roger Long Piloting 2 August 8th 03 03:58 PM
Need a date.... Sagz525 Instrument Flight Rules 2 July 23rd 03 02:34 PM
