PowerFLARM
Old November 5th 10, 05:49 AM posted to rec.aviation.soaring
Paul Remde
Default PowerFLARM
Hi,
I have finally added PowerFLARM to my web site. I have tried to make it a
valuable resource with new photos and dimensional drawings not found
elsewhere.
http://www.cumulus-soaring.com/flarm.htm
I'm taking a lot of orders for PowerFLARM units. Group Discounts are shown
on the web site. Note that the discounts go down dramatically after 2010.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
Old November 5th 10, 10:28 AM posted to rec.aviation.soaring
Bruce Hoult
Default PowerFLARM
On Nov 5, 5:49*pm, "Paul Remde" wrote:
Hi,
I have finally added PowerFLARM to my web site. *I have tried to make it a
elsewhere.http://www.cumulus-soaring.com/flarm.htm
I'm taking a lot of orders for PowerFLARM units. *Group Discounts are shown
on the web site. *Note that the discounts go down dramatically after 2010.
The discount structure is ... interesting.
For example, 80 units are cheaper than 79.
Old November 5th 10, 02:33 PM posted to rec.aviation.soaring
Paul Remde
Default PowerFLARM
Hi Bruce,
I'm not sure I understand your comment. Any discount structure has points
at which the discount changes. That is done to motivate additional sales,
and because it is less expensive to import and ship batches of units than
single units.
I didn't create the discount structure. I am just following the recommended
discounts proposed by FLARM.
There are many soaring clubs putting together some very nice orders. It is
exciting to see the PowerFLARM building the required "critical mass" very
quickly.
Best Regards,
Paul Remde
"Bruce Hoult" wrote in message
On Nov 5, 5:49 pm, "Paul Remde" wrote:
Hi,
Old November 5th 10, 03:35 PM posted to rec.aviation.soaring
Greg Arnold[_2_]
Default PowerFLARM
Paul, your website says "The standard unit does not have Engine Noise
Level recording enabled. It can be enabled for $100."
I assume this means that if you bought a motorglider in the future, you
would not need to have the unit physically modified as the ENL hardware
is already there? Is there a software code that would enable the ENL?
On 11/5/2010 6:33 AM, Paul Remde wrote:
Hi Bruce,
points at which the discount changes. That is done to motivate
additional sales, and because it is less expensive to import and ship
batches of units than single units.
recommended discounts proposed by FLARM.
is exciting to see the PowerFLARM building the required "critical mass"
very quickly.
Best Regards,
Paul Remde
Hi,
shown
Old November 5th 10, 04:40 PM posted to rec.aviation.soaring
Paul Remde
Default PowerFLARM
Hi Greg,
I believe that the ENL hardware is in every unit and it can be enabled with
a key - which can be purchased at an time for $100. But I am not 100%
certain about that. I have sent an inquiry to find the precise answer.
I was surprised to learn that the PowerFLARM units will be IGC approved, but
will not have the logger's altimeter calibrated upon arrival. Their take on
it is that it only needs to be calibrated after a successful badge or record
flight. I'm sure that will save them a lot of labor before shipping the
units, and help keep the cost reasonable. Of course, I offer an option to
calibrate the unit before shipment, or anytime.
Best Regards,
Paul Remde
"Greg Arnold" wrote in message
would not need to have the unit physically modified as the ENL hardware is
Hi Bruce,
very quickly.
Best Regards,
Paul Remde
Hi,
a
shown
2010.
Old November 5th 10, 06:27 PM posted to rec.aviation.soaring
Ramy
Default PowerFLARM
At the PASCO seminar, Urs was asked the same question and his answer
was that ENL is software enabled.
Ramy
On Nov 5, 8:40*am, "Paul Remde" wrote:
Hi Greg,
a key - which can be purchased at an time for $100. *But I am not 100%
certain about that. *I have sent an inquiry to find the precise answer.
will not have the logger's altimeter calibrated upon arrival. *Their take on
flight. *I'm sure that will save them a lot of labor before shipping the
units, and help keep the cost reasonable. *Of course, I offer an option to
Best Regards,
Paul Remde
Level recording enabled. *It can be enabled for $100."
already there? *Is there a software code that would enable the ENL?
Hi Bruce,
very quickly.
Best Regards,
Paul Remde
Hi,
a
shown
2010.
For example, 80 units are cheaper than 79.- Hide quoted text -
- Show quoted text -
Old November 5th 10, 06:28 PM posted to rec.aviation.soaring
David[_13_]
Default PowerFLARM
Paul,
Nice page and info. Thanks!
I am wondering about the antennae in the brick version.
It says: "remote antennas". Is the intent that the antennae be
attached directly to the brick or be remote *to* the brick (as
in transponder installations)?
Either way, it raises interesting installation challenges.
If attached to the brick, of course it raised questions about how
good reception/transmission will be if the brick is installed in/
behind
the instrument panel (together with a bunch of other metallic
objects).
If remote to the brick, the challenge is similar to a transponder,
routing
coax, finding a good place for the antennae, securing them, orienting
them, etc.
David
Old November 5th 10, 07:06 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default PowerFLARM
On 11/5/2010 8:40 AM, Paul Remde wrote:
Hi Greg,
with a key - which can be purchased at an time for $100. But I am not
100% certain about that. I have sent an inquiry to find the precise
answer.
I need the ENL, so I'm very interested in the answer. It sounds like the
hardware cost for it is small, but maybe the development wasn't, and
this "key" is a way to recoup those costs from the people that need the
feature.
A thought on the various PowerFlarm versions: if you intend to loan your
unit to other people (as I intend to, e.g., to a contest pilot, or to
let other pilots see how it works), you probably want to get the
self-contained version.
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz
Old November 6th 10, 05:30 AM posted to rec.aviation.soaring
Bruce Hoult
Default PowerFLARM
It's quite common to express discounts as $X each for the first 10, $Y
each for the next 90, $Z each after that, or so on. Then it's
impossible to get a situation where a larger order will cost less than
a smaller order.
I can understand that there might perhaps be some saving in shipping
unbroken cartons of 10, for example, but that wouldn't explain why 79
units cost $103,932.40 while 81 units cost $104,141.7 i.e. only
$209.30 more for TWO extra units and presumably broken cartons and
more handling.
On Nov 6, 2:33*am, "Paul Remde" wrote:
Hi Bruce,
I'm not sure I understand your comment. *Any discount structure has points
at which the discount changes. *That is done to motivate additional sales,
single units.
I didn't create the discount structure. *I am just following the recommended
There are many soaring clubs putting together some very nice orders. *It is
quickly.
Best Regards,
Paul Remde
Hi,
PowerFLARM questions Greg Arnold[_2_] Soaring 21 November 10th 10 05:05 AM
PowerFLARM Greg Arnold[_2_] Soaring 6 November 2nd 10 10:32 AM
PowerFlarm response to transponders Mark Soaring 1 November 1st 10 04:07 PM
PowerFLARM Mode S question kirk.stant Soaring 54 October 26th 10 03:51 PM
Build your own PowerFLARM! Darryl Ramm Soaring 51 August 19th 10 07:39 PM
