Piper Archer III or Cessna 172SP
Old July 4th 03, 06:15 AM
Dale Harwell
Default Piper Archer III or Cessna 172SP
I normally fly new 172's but if I were to choose between a brand new
172sp or a Archer ? I do know that most all the 172's Ive flown that are
2002 or newer have awsome avionics. full auto pilot 4" moving map gps.
If the Archer has the equivalent. I would by the Piper. other wise Id'e
go with the Cessna. The 172 also carries alot more weight than what the
weight and balance says. Overall, I like the piper. Good luck !!!
*** Sent via http://www.automationtools.com ***
Add a newsgroup interface to your website today.
Old July 8th 03, 05:53 PM
Sydney Hoeltzli
The Flynns wrote:
75% (that is 2700 rpm at 7500' or POH values)
I have a 62" Sensenich prop and a low time engine (170 SMOH by Mattituck)
Have you had your tach checked or calibrated recently?
I helped with the tach check at the AYA convention last
summer. We checked 3 dozen planes. Most were 100 rpm
(or more) low, with the tendency to be least accurate at
highest power settings.
Of course, your weight, temperature, and how the plane is
loaded are also factors. Suffice it to say while we loves
our Tigger, we don't see 138 kts TAS at 7500 ft. We are
usually traveling w/in 100 lbs of max gross and near-
rearward CG. 'Course it's not uncommon to be over 70 degrees
at 7000 ft here, either.
Cheers,
Sydney
Old July 9th 03, 05:44 AM
The Flynns
I've had the tach checked and you are dead on- --100 rpm low consistently
across the range. (Ken Blackmon did the last one at annual.) I've wondered
about getting it overhauled in the winter when I get the plane painted.
In any case, I adjust for that so I'm showing 2600 rpm at 7500' or so. I
never fly near gross weight. Typically I'm loaded with 2 aboard for 300lbs,
plus 50 lbs of luggage and stuff. I've got 945 of useful so will be nearly
300lbs under gross. And sometimes another 140 under that. Last trip I
checked this out at we were at 48-58F at 7000 to 8000 coming up the
Sacramento valley in May.
Are you going to SSI?
"Sydney Hoeltzli" wrote in message
Mattituck)
Cheers,
Sydney
Old July 9th 03, 07:07 AM
Sydney Hoeltzli
I think that's a good idea, or a digital tach
Yep, that's a big part of the picture. 2000 lbs vs 2400 lbs does
improve the angle of attack = more airspeed. I was really bummed
about a Tiger owner based at Sparta who claimed all sorts of wonders
in airspeed, until I realized he was always flying by himself and
partial fuel and I was always flying with the husband, the kid, and
the kitchen sink along.
Alas, no, but if you are please extend my greetings to Bob Steward
and have your wife give him a big hug for me and tell Mike Letrello
he's a brave man indeed (keeps trying to straighten me out as a pilot).
Cheers,
Sydney
Old July 10th 03, 02:18 PM
Jonathan Goodish
In article W4NOa.13721$N7.2280@sccrnsc03,
I would seriously consider replacing it or supplementing it with a good
digital tach. I had the tach replaced in my PA-28-181 a few years ago
with a brand new Mitchell tach with the painted faceplate. Despite what
the calibration card said when it was installed, it didn't take long for
it to drift almost 100 RPM low at cruise. Any mechanical tach is is
going to have some drift which is only going to get worse over time.
I did not put a digital in because my mechanic at the time discouraged
it. I now basically believe that he did that because he didn't want to
do the extra work to put in the digital tach.
JKG
Old July 10th 03, 02:38 PM
Jonathan Goodish wrote:
: I did not put a digital in because my mechanic at the time discouraged
: it. I now basically believe that he did that because he didn't want to
: do the extra work to put in the digital tach.
From what I understand, the digital tach is a very simple install.
It only needs power, ground, and P-leads from the ignition switch. Of
course it requires a 337 paperwork bu11$h!t, but since it's STC'd, even
that's not a big deal. My tach is about 100 RPM low (checked it myself
with a strobe tach), so I just take that into account when cruising. A
friend of mine told me once after I flew a cross-country flight and
guessed the fuel burn that I'm the only guy he knew who would be able to
tell the tach was off 100 RPM by the fuel required after the flight. It's
dead-on at 8.5 gal/hour on 180hp @ 65% (with tach correction factor).
-Cory
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
Old July 15th 03, 04:01 AM
Mike Schumann
The one thing that I really like in the Piper line is the flap lever. You
can set / check your flap setting instantly, without having to divert your
attention from all the other things (like looking for traffic) when you are
turning onto final.
Mike Schumann
"Larry David" wrote in message
news:KANJa.2439$Fy6.888@sccrnsc03...
Besides those of you who will say it's a matter or personal preference or
that it's like comparing a Honda and a Toyota, what are the major
differences and pro's/con's to owning a late-model version of these
aircraft. Considerations include cost, avionics, useful load/size (I'm 6'
240lbs), reliability and features.
World War II Flying 'Ace' Salutes Racial Progress, By Gerry J. Gilmore Otis Willie Military Aviation 2 February 22nd 04 03:33 AM
$15,000 Cash for a Cessna 152 Or Piper Tomahawk MRQB Aviation Marketplace 17 February 15th 04 12:05 PM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Aviation Marketplace 1 November 4th 03 12:57 AM
Charity Auction - Flight in a Piper Archer over Cambridge Charlie General Aviation 0 October 8th 03 09:50 AM
