To all you communication experts,
I have a Schreder hp-15/18 I am rebuilding. I need to install a communication radio antenna. Is it possible that an installation in one of the winglets will provide reasonable radio communications. The winglet is fiberglass and I can ground to the aluminum wing structure. The winglet is about the same height as a standard comm antenna. I was thinking maybe a copper strip up the TE. Opinions? Mike |
On Nov 21, 3:46*pm, SoaringXCellence wrote:
To all you communication experts, I have a Schreder hp-15/18 I am rebuilding. *I need to install a communication radio antenna... I'm not a radio expert, but I have installed and tested four or five antennas in an HP-18. The only one that has worked very well was an external 1/4-wave whip installed over the aft fuselage. I tuned it to an SWR of about 1.4:1, at 123.4, which was about as good as you could expect. The troubles with installing an antenna in the winglet are that there is not a good ground plane for a 1/4-wave whip, and not enough vertical height for a 1/2-wave dipole (two 1/4-wave whips opposed). I suppose you could put a rubber ducky antenna out there, but there's no point since you could have the same antenna in the cockpit and do away with the 25 feet of cable. Anyhow, the other antennas I tried were a commercial 1/2-wave dipole strip antenna in various orientations in the fuselage (SWR above 2.5 in all cases), a 1/4-wave whip on the gear door (again, poor SWR and poor demonstrated performance), a Sebald-type combo 1/4-wave whip and Nicks tube (good SWR but pointless, since the ship has a Nicks tube elsewhere), an internal 1/4-wave whip the original builder had installed on the most forward metal bulkhead (poor SWR), and a rubber ducky installed on the cockpit rail (reasonable SWR, poor overall performance). At one point I played with the idea of building an Aramid fiber ruddervator and installing a Jim Weir style copper tape dipole inside its trailing edge. I know that the performance directly forward would be very poor, but the overall performance might have been decent. But in the end I just stuck a whip antenna on it and got on with life. Thanks, Bob K. |
On Nov 21, 4:46*pm, SoaringXCellence wrote:
To all you communication experts, I have a Schreder hp-15/18 I am rebuilding. *I need to install a communication radio antenna. *Is it possible that an installation in one of the winglets will provide reasonable radio communications. *The winglet is fiberglass and I can ground to the aluminum wing structure. *The winglet is about the same height as a standard comm antenna. I was thinking maybe a copper strip up the TE. Opinions? Mike Against: Requires about the longest possible cable run. Adds weight and cable loss. Requires 2 connector breaks if the winglet is removable either of which will cause problem if forgotten during rig/derig (failure to connect may cause failure of the transmitter) Any connector may be vulnerable to water ingestion if water ballast is used For: Can't think of anything On a metal tail boom sailplane a 1/4 wave whip mounted on the fuselage is probably the simplest and most effective solution. Andy |
Thanks for all the replies, both here and through email. I'll go with
the tail-boom mounted one. Mike |
winglet weight | Brad[_2_] | Soaring | 4 | November 15th 08 12:07 AM |
Winglet in flight | Patrick R7 | Aviation Photos | 8 | October 20th 08 10:13 PM |
Winglet sliced off? | [email protected] | Piloting | 15 | October 12th 06 01:07 AM |
Retractable Comm Antenna | Ron Wanttaja | Home Built | 11 | September 6th 04 06:59 PM |
Winglet Alternative? | mike fadden | Soaring | 1 | October 22nd 03 08:46 PM |
