This is a pretty good gliding PR piece aimed General Aviation folks
found on AIRCRAFT OWNER ONLINE WEEKLY NEWSLETTER December 1, 2010 issue. Check it out at http://www.aircraftowner.com/videos/...show_1567.html Bob T. 19 |
On Dec 1, 8:11*pm, Bob wrote:
This is a pretty good gliding PR piece aimed General Aviation folks found on AIRCRAFT OWNER ONLINE WEEKLY NEWSLETTER December 1, 2010 issue. *Check it out athttp://www.aircraftowner.com/videos/view/cross-country-soaring-on-the... Bob T. 19 Very well done indeed. I particularly liked the unique tow-out gear - any idea who made that? Mike |
Hi Mike,
The tow out rig for the Grob was made (I believe) by Don Ingraham or Cross Country Soaring, Inc. I don't recall the exact design, but it makes it easy to connect the cart to the 2 Grob 103s they fly and pull them around without a long rope between them. Paul Remde "Mike the Strike" wrote in message ... On Dec 1, 8:11 pm, Bob wrote: This is a pretty good gliding PR piece aimed General Aviation folks found on AIRCRAFT OWNER ONLINE WEEKLY NEWSLETTER December 1, 2010 issue. Check it out athttp://www.aircraftowner.com/videos/view/cross-country-soaring-on-the... Bob T. 19 Very well done indeed. I particularly liked the unique tow-out gear - any idea who made that? Mike |
On Dec 1, 8:31*pm, Mike the Strike wrote:
On Dec 1, 8:11*pm, Bob wrote: This is a pretty good gliding PR piece aimed General Aviation folks found on AIRCRAFT OWNER ONLINE WEEKLY NEWSLETTER December 1, 2010 issue. *Check it out athttp://www.aircraftowner.com/videos/view/cross-country-soaring-on-the... Bob T. 19 Very well done indeed. *I particularly liked the unique tow-out gear - any idea who made that? Mike Don designed and built it. IIRC, it's 2" PVC pipe, a toilet plunger to protect the glider nose and rope down the middle with a Tost ring set. The stiff pipe prevents the glider from over running and colliding with the tow out vehicle. It eliminates the need for a tail dolly and tow bar. Very clever. It works perfectly with the Grobs and probably any glider with the aero tow hook in the point of the nose. |
On 12/2/2010 11:45 AM, bildan wrote:
Very well done indeed. I particularly liked the unique tow-out gear - any idea who made that? Mike Don designed and built it. IIRC, it's 2" PVC pipe, a toilet plunger to protect the glider nose and rope down the middle with a Tost ring set. The stiff pipe prevents the glider from over running and colliding with the tow out vehicle. It eliminates the need for a tail dolly and tow bar. Very clever. It works perfectly with the Grobs and probably any glider with the aero tow hook in the point of the nose. I'm guessing it's important the weight on the tailwheel be low, or at least, don't tow it on pavement. The Grob tail weight is likely low, because the main wheel is farther back than "tail dragger" gliders. You could still tow a heavy tail glider around as shown, if you used a tail dolly. A clever system. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
On Dec 2, 1:48*pm, Eric Greenwell wrote:
On 12/2/2010 11:45 AM, bildan wrote: Very well done indeed. *I particularly liked the unique tow-out gear - any idea who made that? Mike Don designed and built it. *IIRC, it's 2" PVC pipe, a toilet plunger to protect the glider nose and rope down the middle with a Tost ring set. *The stiff pipe prevents the glider from over running and colliding with the tow out vehicle. *It eliminates the need for a tail dolly and tow bar. *Very clever. It works perfectly with the Grobs and probably any glider with the aero tow hook in the point of the nose. I'm guessing it's important the weight on the tailwheel be low, or at least, don't tow it on pavement. The Grob tail weight is likely low, because the main wheel is farther back than "tail dragger" gliders. You could still tow a heavy tail glider around as shown, if you used a tail dolly. A clever system. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarmhttp://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz Again, IIRC, Don's G103 Twin II's are very light on the tailwheel when unoccupied. I don't think they have ever had their booms repaired. I was astonished how little effort was needed to lift the tailwheel. |
Hi,
Awesome! Well done! The person in the video is Don Ingraham of Cross Country Soaring, Inc. He's a great guy. He represents our sport extremely well and is fun to be around. Paul Remde "Bob" wrote in message ... This is a pretty good gliding PR piece aimed General Aviation folks found on AIRCRAFT OWNER ONLINE WEEKLY NEWSLETTER December 1, 2010 issue. Check it out at http://www.aircraftowner.com/videos/...show_1567.html Bob T. 19 |
My final flight as owner in N1943L - Video | nate_fl | Instrument Flight Rules | 1 | May 5th 10 01:11 PM |
My final flight as owner in N1943L - Video | [email protected] | Piloting | 4 | May 4th 10 07:50 PM |
My final flight as owner in N1943L - Video | [email protected] | Owning | 0 | April 30th 10 01:30 AM |
New gliding online directory | Dan G | Soaring | 2 | December 24th 07 04:52 AM |
Online shop for gliding instruments | Mika Koski | Soaring | 3 | October 12th 07 08:52 PM |
