In article , "N3722A"
wrote: I have a Sensenich 72CK-0-56 prop on my plane - is the "56" the pitch on the prop? yes. Also, can one have a prop "re pitched" so to speak to give more of a climb performance than cruise? It seems I once read (correct me if I am wrong) that this number (56) is the pitch and if one can have a prop reworked to a lower pitch (like 52) one can get a better climb performance. I suggest you contact Sensenich about the limits of re-pitching. I would think that changing the prop pitch would require either an STC or field approval (if not already covered by the original type certificate). For example, the STC to install a 160hp engine in my cherokee 140 also allowed either the original 58 pitch or a 60 pitch prop. Good luck. -- Bob Noel |
![]() Also, can one have a prop "re pitched" so to speak to give more of a climb performance than cruise? I just discussed this with my tech last week. He told me that I can have the prop repitched for climb on my 172H for around C$350.00. -- Tony Roberts (tonyroberts@ remove shaw.ca) PP-ASEL VFR-OTT - Night Cessna 172 C-GICE |
On Mon, 28 Jul 2003 16:05:14 -0700, "N3722A" wrote:
I have a Sensenich 72CK-0-56 prop on my plane - is the "56" the pitch on the prop? Yup. Also, can one have a prop "re pitched" so to speak to give more of a climb performance than cruise? It seems I once read (correct me if I am wrong) that this number (56) is the pitch and if one can have a prop reworked to a lower pitch (like 52) one can get a better climb performance. sig snip http://www2.sensenich.com/direct/propdir.htm Has a lot of useful information. If a pitch range is "approved" for your particular aircraft (there are quite a few that have standard/climb/cruise listed) you still need to ensure that the certified static rpm range is still maintained. Any prop shop that re-works/overhauls/sells Sensenich props should be able to give the straight scoop on what is allowable for your aircraft. TC |
