Does anyone have any experience with the Maule with the Allison turbine
engine ? The Maule with the Lycombing IO-540 is $170.M , where the MT7-420 is going for $470.M new. I would have to add about $75.M in options for either bird. What do you think about the Allison turbine in a Maule ? Thanks |
You are joking, right?
Look, the Maule is a fine airplane and does it's thing well, which is short field and grass operations... It is not a turbine bird, and installing one is a waste of money... Unless you are going into the bush of africa or asia where 100LL is not available, stick to the Lycoming... Denny "kevin" wrote in message news:6kiWa.22942$cF.9271@rwcrnsc53... Does anyone have any experience with the Maule with the Allison turbine engine ? The Maule with the Lycombing IO-540 is $170.M , where the MT7-420 is going for $470.M new. I would have to add about $75.M in options for either bird. What do you think about the Allison turbine in a Maule ? Thanks |
Dennis O'Connor wrote:
You are joking, right? Look, the Maule is a fine airplane and does it's thing well, which is short field and grass operations... It is not a turbine bird, and installing one is a waste of money... Unless you are going into the bush of africa or asia where 100LL is not available, stick to the Lycoming... Denny I was not talking about a conversion, you can buy a new Maule from the factory with the Allison engine. I was looking at the difference of cruise speed 164 with the Lycoming as opposed to 190 with the Allsion. The 2800 fpm climb is also tempting. "kevin" wrote in message news:6kiWa.22942$cF.9271@rwcrnsc53... Does anyone have any experience with the Maule with the Allison turbine engine ? The Maule with the Lycombing IO-540 is $170.M , where the MT7-420 is going for $470.M new. I would have to add about $75.M in options for either bird. What do you think about the Allison turbine in a Maule ? Thanks |
kevin wrote: I was not talking about a conversion, you can buy a new Maule from the factory with the Allison engine. I was looking at the difference of cruise speed 164 with the Lycoming as opposed to 190 with the Allsion. The 2800 fpm climb is also tempting. The slower Maule will go a lot further between fill ups. |
Newps wrote:
kevin wrote: I was not talking about a conversion, you can buy a new Maule from the factory with the Allison engine. I was looking at the difference of cruise speed 164 with the Lycoming as opposed to 190 with the Allsion. The 2800 fpm climb is also tempting. The slower Maule will go a lot further between fill ups. This is true. 15gph as opposed to 25 for the turbine. |
kevin writes:
I was not talking about a conversion, you can buy a new Maule from the factory with the Allison engine. I was looking at the difference of cruise speed 164 with the Lycoming as opposed to 190 with the Allsion. The 2800 fpm climb is also tempting. The slower Maule will go a lot further between fill ups. This is true. 15gph as opposed to 25 for the turbine. 15 vs. 25gph for different speeds, right? What are the fuel consumptions for the same speed at cruise altitudes (10-20K)? To be fair you should also add in the extra 5 gallons the turbine can carry (in situations where you're at gross). --kyler |
You might want to have the factory take you for a ride to see what 190mph is
like inside of a fabric covered fuselage with angular otlines.... Denny cruise speed 164 with the Lycoming as opposed to 190 with the Allsion. The 2800 fpm climb is also tempting. |
You might want to have the factory take you for a ride to see what 190mph is like inside of a fabric covered fuselage with angular otlines.... Denny cruise speed 164 with the Lycoming as opposed to 190 with the Allsion. The 2800 fpm climb is also tempting. Yes , without a doubt i would want a demo ride. A cruise speed of 164 is not bad for a STOL bird, 190 is smoking. |
I recently flew a local pilots, new 260 Maule... I didn't see anything
approaching 164... Denny "kevin" wrote in message news:MKSWa.49034$Ho3.7660@sccrnsc03... Dennis O'Connor wrote: You might want to have the factory take you for a ride to see what 190mph is like inside of a fabric covered fuselage with angular otlines.... Denny cruise speed 164 with the Lycoming as opposed to 190 with the Allsion. The 2800 fpm climb is also tempting. Yes , without a doubt i would want a demo ride. A cruise speed of 164 is not bad for a STOL bird, 190 is smoking. |
kevin wrote: Does anyone have any experience with the Maule with the Allison turbine engine ? The Maule with the Lycombing IO-540 is $170.M , where the MT7-420 is going for $470.M new. I would have to add about $75.M in options for either bird. What do you think about the Allison turbine in a Maule ? The turbine carries 35 pounds more and takes the same distance to clear a 50' obstacle. The major difference is the 2800 fpm climb rate versus the 1500 fpm for the piston engine. The turbine goes for $450,000. There are several models of 235 hp planes, one of which costs $139,600. So. That climb rate will set you back over $300,000 and burn twice as much fuel. It wouldn't be worth it to me. Check http://www.mauleairinc.com for figures. George Patterson The optimist feels that we live in the best of all possible worlds. The pessimist is afraid that he's correct. James Branch Cavel |
| Thread Tools | |
| Display Modes | |
| turbine in microturbine generator for aircraft? | Shin Gou | Home Built | 19 | December 26th 04 03:19 PM |
| turbine propeller | sebastian | Home Built | 19 | March 21st 04 01:47 AM |
| earliest turbine powered helicopter? | Charles Gray | Military Aviation | 7 | January 3rd 04 12:35 AM |
| Water Cooled Jet Engines: a possibillity then and now? | The Enlightenment | Military Aviation | 3 | December 18th 03 10:41 AM |
| WTB: Turbine ignition exciter unit, single plug | Juan E Jimenez | Aviation Marketplace | 0 | August 25th 03 01:48 AM |
