When does an engine needs an overhaul?
Old August 3rd 03, 10:16 PM
Victor
Default When does an engine needs an overhaul?
When does an engine needs an overhaul? There are several indications
that the engine is comming to the end of its life. But what do peolple
really look for to decide an engine is to go to overhaul.
Low oil pressure, High oil temperature, Low cylinder compression, Loss
of power. Which is the factor that maters most. For example low
cylinder compression can easily be fixed replacing the cylinder not
necessarilly an overhaul.
Of course I am talking about part 91 operation. I have heard people
that run engines 1000 hrs and far more than ten years past TBO.
For those of you who decided to overhaul your engine. What made you
spend the big buck?
Old August 4th 03, 01:07 AM
Aaron Coolidge
Victor wrote:
: When does an engine needs an overhaul? There are several indications
: that the engine is comming to the end of its life. But what do peolple
: really look for to decide an engine is to go to overhaul.
: Low oil pressure, High oil temperature, Low cylinder compression, Loss
: of power. Which is the factor that maters most. For example low
: cylinder compression can easily be fixed replacing the cylinder not
: necessarilly an overhaul.
Low power (low static RPM with a fixed-pitch prop), high oil consumption,
excessive camshaft wear (on lycoming engines), and the Lycoming oil
pump AD are popular reasons to overhaul. I think pilot comfort factor is
very important as well.
The Lyc. oil pump AD is what made my friend overhaul after 30 years and
3200 hours of operation of his O-320. Other wise it was running well.
Another friend had ignored the impulse coupling AD, and had the impulse
disintegrate and fill the oil with metal. Time for an overhaul!
Aaron Coolidge (N9376J)
Old August 4th 03, 08:08 PM
Steve Dold
spend the big buck?
My first overhaul was at about 1800 hours and the oil pressure was
low. It also used a lot of oil.
The second one was an O-200 that had 200 hours on it, On a routine oil
change I found aluminum in the oil screen from disintegrated piston pin
plugs. The screen collapsed and filled the bearings with oil, causing reduced running clearances.
This required complete dissasembly and repair. Luckily there wasn't much
wear to journals, cam, etc.
Once I did a top overhaul (replaced with Milleniums) because the blow-by
was causing overheating. It was using about one quart in four hours, but
the overheating was a problem, I was amazed how much difference it made,
the oil temps dropped over 30 degrees after the cylinder replacement.
Say NO to useless over-quoting! Just quote a few lines to get the
point across, not the whole goddamn thing, OK? Thanks! :-)
Old August 7th 03, 05:21 PM
Jay Honeck
spend the big buck?
We discovered metal in the oil filter at the pre-buy inspection. This
forced us to lower our offer accordingly, and take the plunge on an
overhaul.
It was a giant pain in the butt, and very expensive -- but we haven't
regretted it. It's nice when the glass is still mostly full...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old August 14th 03, 07:02 AM
Doug Campbell
We had a first run IO-540 at 2400 hrs start to have a valve stick, and a
plug foul repeatedly.
Decided we had got our money's worth, and went overhaul rather than work on
the one cylinder.
We bought factory reman, so didn't get to find out the details of how many
things inside were near EOL.
After 2000 hrs, we had switched to more frequent oil changes (30 hr), with
analysis, to increase the warning before the end.
"Jay Honeck" wrote in message
news:38uYa.88877$o%2.39014@sccrnsc02...
spend the big buck?
overhaul.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old August 14th 03, 06:02 PM
Jim Weir
The guy that taught me said that when you can read the serial numbers on the
metal chunks in the oil screen, it is time.
http://www.rst-engr.com
Old August 15th 03, 03:22 AM
Mike Spera
Our engine had 1830 hours and 18 years. It had been flown only 40 hours
for each of 2 of those years. Oil consumption was 1 quart in about 2.5
hours. Compressions were in the mid 60s and dropping. It was leaking oil
at the lower front case seal. The #1 cylinder had already been replaced
for an exhaust port crack. Replacement cylinder was an off-the-rack
chrome overhauled unit of unknown history. Baffle seals were eroding.
Oil/fuel hoses were antiques. Muffler needed overhaul. Carb heat shields
were deteriorating. Motor mount needed repainting. Carb accel pump seal
was just replaced for leakage. The oil pump gear AD was due. At that
time, the crankshaft corrosion AD was due and did not yet exempt the
150hp engine (which this was).
It was time.
Mike
__________________________________________________ ____________________
Posted Via Uncensored-News.Com - Still Only $9.95 - http://www.uncensored-news.com
The Worlds Uncensored News Source
Old August 15th 03, 05:17 PM
Mike Spera wrote:
: Our engine had 1830 hours and 18 years. It had been flown only 40 hours
: for each of 2 of those years. Oil consumption was 1 quart in about 2.5
: hours. Compressions were in the mid 60s and dropping. It was leaking oil
: at the lower front case seal. The #1 cylinder had already been replaced
: for an exhaust port crack. Replacement cylinder was an off-the-rack
: chrome overhauled unit of unknown history. Baffle seals were eroding.
: Oil/fuel hoses were antiques. Muffler needed overhaul. Carb heat shields
: were deteriorating. Motor mount needed repainting. Carb accel pump seal
: was just replaced for leakage. The oil pump gear AD was due. At that
: time, the crankshaft corrosion AD was due and did not yet exempt the
: 150hp engine (which this was).
: It was time.
: Mike
Uh, yeah. I've got a buddy with a Cherokee 150 that just started
making metal in the screen. I'm thinking that it's time too. Probably
eating its cam, eh?
: __________________________________________________ ____________________
: Posted Via Uncensored-News.Com - Still Only $9.95 - http://www.uncensored-news.com
: The Worlds Uncensored News Source
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 02:09 AM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 07:42 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 04:03 PM
Objective Engine Discussion Rick Maddy Home Built 26 October 14th 03 05:46 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
