We at the Fault Line Flyers Glider Club in Briggs Texas want to build
or buy a tension meter for our auto tow operation. Does anyone have experience that might be helpful. Bill Snead 6W |
On Dec 19, 3:52*pm, " wrote:
We at the Fault Line Flyers Glider Club in Briggs Texas want to build or buy a tension meter for our auto tow operation. Does anyone have experience that might be helpful. Bill Snead 6W If you have a dedicated tow vehicle, you might look at this http://www.coloradosoaring.org/think...ey/default.htm Frank Whiteley |
Below is a link to the user manual for a Digital Tension gauge for
paragliding and hanggliding winches but it might be adaptable for auto tow of sailplanes. http://www.lemmen-engineering.nl/ima...Manual_DTM.pdf Excerpt: The Digital Tension Meter is specially designed for paragliding and hangliding winches., however it can also be used in other applications where force need to be measured. The Digital tension meter is available in two versions: single and double cable drum winches (DTM-S and DTM- D). The digital tension meter consists of three main parts: the analogue panel display, the DTM box (electronics) and one or two load cells. The DTM can be calibrated to the application by means of three buttons. After calibration the DTM stores the calibration values in non-volatile memory. The DTM-D automatically compares - after calibration- the measured forces of the sensor inputs and displays the highest force. The display value is updated every 25ms. snip |
At 22:52 19 December 2010, wrote:
We at the Fault Line Flyers Glider Club in Briggs Texas want to build or buy a tension meter for our auto tow operation. Does anyone have experience that might be helpful. I have no direct experience (though I'm currently designing a load cell setup for a winch), but a 2000 lb capacity S-type load cell like this one: http://www.icscale.com/td112.htm In combination with an indicator like this: http://www.icscale.com/XK315Aind.html Should do the job. Marc |
On Dec 19, 6:47*pm, Marc Ramsey
wrote: At 22:52 19 December 2010, wrote: We at the Fault Line Flyers Glider Club in Briggs Texas want to build or buy a tension meter for our auto tow operation. Does anyone have experience that might be helpful. I have no direct experience (though I'm currently designing a load cell setup for a winch), but a 2000 lb capacity S-type load cell like this one: http://www.icscale.com/td112.htm In combination with an indicator like this: http://www.icscale.com/XK315Aind.html Should do the job. Marc Marc, What you describe was in the system that Udo built for auto launching his ASW-27. I believe I have images of the system if anyone is interested. |
We used an auto tow system for launching Hang Gliders back in the Mid-
West. The vehicle hardware consisted of a small hydraulic cylinder mounted on the rear bumper and a 5-inch diameter gauge mounted on the hood with a CB antenna magnetic mount. They were connected with nylon tubing and poly-flow fittings. We used this system for years without any problems. |
We at the Fault Line Flyers Glider Club in Briggs Texas want to build or buy a tension meter for our auto tow operation. Does anyone have experience that might be helpful. Bill Snead 6W You can buy strain gauge based electronic tension systems with hand held readout units either wired or wireless. They are sometimes called "crane scales" or "dynomometers". Just Google "tension load cell". You'll want a 0-2000 Lbf unit. There are also clevis attached USB tension load cells which plug into your laptop which come with appropriate software. The USB units are nice since they are powered by the USB bus - just plug and play. |
On Dec 20, 9:07*am, bildan wrote:
On Dec 19, 3:52*pm, " wrote: We at the Fault Line Flyers Glider Club in Briggs Texas want to build or buy a tension meter for our auto tow operation. Does anyone have experience that might be helpful. Bill Snead 6W You can buy strain gauge based electronic tension systems with hand held readout units either wired or wireless. *They are sometimes called "crane scales" or "dynomometers". *Just Google "tension load cell". *You'll want a 0-2000 Lbf unit. There are also clevis attached USB tension load cells which plug into your laptop which come with appropriate software. The USB units are nice since they are powered by the USB bus - just plug and play. There are others too. I've been looking for a similar inline load cell and will probably purchase from http://www.futek.com/. I don't have any relation to the company, but have been looking for a while and their offerings appear to be pretty solid. Craig |
On Dec 20, 1:40*pm, Craig wrote:
On Dec 20, 9:07*am, bildan wrote: On Dec 19, 3:52*pm, " wrote: We at the Fault Line Flyers Glider Club in Briggs Texas want to build or buy a tension meter for our auto tow operation. Does anyone have experience that might be helpful. Bill Snead 6W You can buy strain gauge based electronic tension systems with hand held readout units either wired or wireless. *They are sometimes called "crane scales" or "dynomometers". *Just Google "tension load cell". *You'll want a 0-2000 Lbf unit. There are also clevis attached USB tension load cells which plug into your laptop which come with appropriate software. The USB units are nice since they are powered by the USB bus - just plug and play. There are others too. I've been looking for a similar inline load cell and will probably purchase fromhttp://www.futek.com/. *I don't have any relation to the company, but have been looking for a while and their offerings appear to be pretty solid. Craig- Hide quoted text - - Show quoted text - Great information Thanks to all Bill Snead |
" wrote in message
: On Dec 20, 1:40*pm, Craig wrote: On Dec 20, 9:07*am, bildan wrote: On Dec 19, 3:52*pm, " wrote: We at the Fault Line Flyers Glider Club in Briggs Texas want to build or buy a tension meter for our auto tow operation. Does anyone have experience that might be helpful. Bill Snead 6W You can buy strain gauge based electronic tension systems with hand held readout units either wired or wireless. *They are sometimes called "crane scales" or "dynomometers". *Just Google "tension load cell". *You'll want a 0-2000 Lbf unit. There are also clevis attached USB tension load cells which plug into your laptop which come with appropriate software. The USB units are nice since they are powered by the USB bus - just plug and play. There are others too. I've been looking for a similar inline load cell and will probably purchase fromhttp://www.futek.com/. *I don't have any relation to the company, but have been looking for a while and their offerings appear to be pretty solid. Craig- Hide quoted text - - Show quoted text - Great information Thanks to all Bill Snead Just out of curiosity, where is one of the items placed in the system??? They look like a big "S". Where do you attach what? Larry |
| Best Rope to purchase for Auto Tows? | [email protected] | Soaring | 4 | October 17th 10 04:23 PM |
| tow rope | tazman | Soaring | 9 | August 25th 10 03:30 AM |
| For sale: DG-600 17-meter and 15-meter wingtips | Lars Peder Hansen | Soaring | 0 | January 21st 07 07:18 PM |
| Winch tension meters - sources? | [email protected] | Soaring | 2 | January 7th 07 02:54 AM |
| 11 on a Rope | Peter Seddon | Rotorcraft | 0 | May 27th 04 12:33 PM |
