My fiberglass topped Cobra trailer has a significant leak when being
towed in the rain that results in good deal of water in the big plastic bin up front. It appears that when closed there is a noticable gap between the rubber gasket on the fixed part of the trailer, and the movable fiberglass top. The gasket does not appear to be worn and there appears to be no adjustment to the position of the top. I'm guessing that this isn't the only one like this and someone out there has already solved this problem. Recomendations? |
On Dec 20, 12:45*pm, SF wrote:
My fiberglass topped Cobra trailer has a significant leak when being towed in the rain that results in good deal of water in the big plastic bin up front. *It appears that when closed there is a noticable gap between the rubber gasket on the fixed part of the trailer, and the movable fiberglass top. *The gasket does not appear to be worn and there appears to be no adjustment to the position of the top. *I'm guessing that this isn't the only one like this and someone out there has already solved this problem. *Recomendations? Look at the hinges and see if it looks like the top was ever bent back enough to change the shape of the hinges. In any case, the hinge end is where you will have to correct. Latch end should clamp seal. If not, either reshape latch or add shim to face where it catches. Good Luck UH |
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! | flyingmr2 | Soaring | 4 | November 16th 10 02:11 AM |
COBRA TRAILER | Gordon Schubert[_2_] | Soaring | 0 | February 10th 09 04:15 AM |
WTB: Cobra Trailer for LS-4 | [email protected] | Soaring | 0 | July 31st 08 05:04 PM |
Cobra Trailer | [email protected] | Soaring | 22 | December 7th 06 11:38 PM |
Cobra Trailer | Soaring | 1 | September 28th 03 01:14 PM |
