'Hot' cylinder after overhaul?
Old August 4th 03, 07:39 PM
Tony Cox
Default 'Hot' cylinder after overhaul?
Since a major overhaul about 60 tach hours ago now,
I've noticed my #3 cylinder (O470R, 182) is running
consistently hot. It is typically 30-40 degrees warmer than
the average, which puts it at 4-bars in the EDM700
display. To keep this cylinder temp down, I'm having to
leave the cowl flaps open in cruise, which slows me down
some 6knots or so. EGT's are all equal.
Does this indicate extra friction in that cylinder which could
be a problem? The engine as a whole is using about 1qt
every 15 hours or so now & I followed the Continental
break-in procedure to the letter. It's running great.
Did someone miss a bit of baffling in reassembly? Can
missing baffle really make that much difference?
Perhaps things will return to normal after a few more hours
and I should stop worrying. Comments?
Dr. Tony Cox
Citrus Controls Inc.
e-mail:
http://CitrusControls.com/
Old August 4th 03, 08:06 PM
Scott Skylane
display. /snip/
Tony,
Baffling certainly could be the issue here, make sure the flexible
baffle seal in this area is laying down correctly. Also, you may want
to swap CHT probes with another cylinder, and see if the indication
follows the probe. Also check if this jug has the factory CHT probe in
it, in which case the sparkplug gasket probe for the EDM *will* read
differently than the others. Good luck, and
Happy Flying!
Scott Skylane
N92054
Old August 5th 03, 12:00 AM
Jim Vadek
How hot is the CHT reading?
"Tony Cox" wrote in message
thlink.net...
Dr. Tony Cox
e-mail:
Old August 5th 03, 12:18 AM
Tony Cox
"Jim Vadek" wrote in message
news:aABXa.65943$Ho3.9080@sccrnsc03...
I can keep the hot cylinder down to around 375 with
the cowl flaps almost fully open, at around 5000' here
in the desert southwest. The rest hover around 340.
Dr. Tony Cox
e-mail:
Old August 5th 03, 05:10 PM
Jim Weir
Roughly...temperatures are worth the coin. That is, a dime size hole in the
baffling will cause 10° rise, a quarter 25°, and so on up to the 50°
half-dollar.
"Tony Cox"
-Did someone miss a bit of baffling in reassembly? Can
-missing baffle really make that much difference?
http://www.rst-engr.com
Old August 5th 03, 06:11 PM
Tony Cox
"Jim Weir" wrote in message
half-dollar.
Interesting rule of thumb. But how come I'm only seeing an increase
in the middle cylinder on the passenger side?
Old August 5th 03, 10:43 PM
gross_arrow
is this by any chance the cylinder on which the stock cht probe
is installed? in my installation, (t-arrow iii), the stc on the
edm-700 required that the stock cht be retained (it's #1 on the
tsio-360fbfc). so on that cylinder, instead of a bayonet probe,
the edm-700 uses a "gasket" probe under the spark plug. the
gasket probes are notorious for reading high -- on my t-arrow,
#1 reads about 50 deg higher than the hottest of the other 5
cylinders. we've replaced the gasket probe to no avail. when
the jpi flags a warning in climb (470 degrees), the stock cht
still shows a good 16th or 3-32nds of an inch below the red line.
our a & p has checked the temps and found the gasket probe to
read high. so, at least in our case, it is a "false alarm".
don't know if the same is true for you, but you might want to
check it out.
g_a
"Tony Cox" wrote in message rthlink.net...
Old August 10th 03, 07:25 PM
Tony Cox
"gross_arrow" wrote in message
om...
is installed?
Yes, indeed. I checked today and this is exactly what the
problem is. I'll check on availability of the part (5050-A) from
JPI.
Dr. Tony Cox
e-mail:
Instrument overhaul - Are all overhauls created equal? RonLee Home Built 1 February 7th 05 06:35 PM
Compression loss on cylinder when rings line up Truth of fiction? test it Home Built 10 May 11th 04 08:11 PM
Cylinder Wrenches for 0-320A Narrow Deck DAVE Home Built 1 December 31st 03 01:45 PM
O-200 overhaul & Vari EZ value Steve Ruse Home Built 13 October 21st 03 09:52 PM
When does an engine needs an overhaul? Victor Owning 9 August 15th 03 04:17 PM
