Question about 175B
Old August 6th 03, 11:41 PM
John Galban
Default Question about 175B
"Wayne" wrote in message ...
I am getting the 1961 175B Cessna that I mentioned before here. I am
trying to figure out how fast it should be. The owner said that it would go
GPH. Then I looked at the original specifications from Cessna. It
was supposed to cruise at 122 knots @ 75% power at 7500'. I had assumed that
he meant 125 MPH but that is only a little less than 109 knots.
Strange. I used to own a '59 Cessna and all of the performance
numbers from the factory were in mph back then. He probably meant 125
mph. The Skylark might be able to do 125 kts @ 75% @7,500' if the
plane is perfectly rigged and light, but the fuel burn he gave you
indicates that he's probably flying at 65% power. At 75% power
expect the O-360 to burn around 10.5 gph.
This has the
Lycoming O360 conversion with a constant speed prop, I would think that
would make it slightly faster and surely better on takeoff performance.
Why? The original Skylark made only 5 less horsepower and also had
a constant speed prop. Practically speaking I wouldn't expect 5 hp
to change the performance numbers a whole lot (particularly speed).
Real world, I'd expect to see 115-120 kts @ 75% @ 7,500' DA with
10gph for that plane, depending on its condition.
Old August 7th 03, 12:06 AM
go GPH. Then I looked at the original specifications from Cessna.
It
that he meant 125 MPH but that is only a little less than 109 knots. This
has
the Lycoming O360 conversion with a constant speed prop, I would think
that
The 2003 172 that I fly is supposed to cruise at 115 knots @ 75% (I forget
altitude) so I wouldn't expect this one to fly faster than a new one with
the same HP and a fixed pitch prop. Anyone have a simular plane? Anyone
know what I should expect? Did Cessna stretch things that far in 1961?
I don't have any experience with C-175s, either with the original geared
engine or with the 0-360 conversion. However, over hundreds of hours in a
C-172N (with the original 150 hp 0-320) I can state that it is a 112 kt
airplane at best. The important thing to remember is that, for a given
airframe, cruise speed will vary as the cube root of horsepower. Thus,
going from 150 hp to 180 hp, for instance, will increase cruise speed (at a
given percentage power setting) by only 6.3%. That would boost a 112 kt
cruise speed to 119 kts.
The idea that you can boost cruise speed with a modest power increase is
mostly wishful thinking. A bigger engine really helps mostly in takeoff and
climb performance (or, in some cases, allowing for more useful load). A
significant increase in cruise speed generally requires aerodynamic cleanup
of the airframe.
You will rarely meet a seller who can resist exaggerating the performance of
the plane he/she is selling. However, with the availability of handheld GPS
units, measuring cruise speed during a test flight is fairly easy. Just fly
in three headings 120 degrees apart, within a relatively small area (so the
wind will not change) and record groundspeed (from the GPS) for each
heading. From that data it is easy to compute the wind component, and then
the true airspeed. If the air is reasonably smooth you should be able to
calculate to within a knot or two.
-Elliott Drucker
Old August 7th 03, 01:25 AM
Thanks for the reply. I thought he meant MPH but what Cessna said about it
made me second guess.
Cessna.
It
This
has
that
forget
with
a
and
cleanup
of the airframe.
of
GPS
fly
then
-Elliott Drucker
Old August 7th 03, 02:01 AM
G.R. Patterson III
Bill Clarke quotes the Cessna specs as showing a cruise speed of 131 mph at
75% power with the original engine.
George Patterson
The optimist feels that we live in the best of all possible worlds. The
pessimist is afraid that he's correct.
James Branch Cavel
Old August 7th 03, 01:23 AM
Ok, thanks! I didn't realize that is had a constant speed prop before.
"John Galban" wrote in message
om...
go
It
that
This has the
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Phoenix AIM-54A (QUESTION) Krztalizer Naval Aviation 10 February 23rd 04 07:22 AM
T Tail question Paul Austin Military Aviation 7 September 23rd 03 06:05 PM
