status of Delta Hawk diesel
Old January 3rd 11, 04:19 PM posted to rec.aviation.homebuilt
jan olieslagers[_2_]
Default status of Delta Hawk diesel
The Delta Hawk has been VERY slow to come to the market, yet I have a
vague memory of the first samples being very close to release.
Anyone know the details, or of any flying apart from factory test/demo
planes?
TIA,
Old January 4th 11, 03:27 PM posted to rec.aviation.homebuilt
stol
On Jan 3, 9:19*am, jan olieslagers
planes?
TIA,
I have NEVER seen a Delta Hawk in any other plane but the factory Demo
canard. This motor program is as close to vaporware as on can get.
Just my opinion........
Old January 4th 11, 04:24 PM posted to rec.aviation.homebuilt
Op 04/01/2011 15:27, stol schreef:
On Jan 3, 9:19 am, jan
planes?
TIA,
Thanks for sharing your opinion - obviously my info was incorrect. As
for "vaporware", I always believed this discipline's grandmaster is
Germany's Zoche diesel engine?
Rgds,
Old January 4th 11, 07:45 PM posted to rec.aviation.homebuilt
Orval Fairbairn[_2_]
planes?
TIA,
Rgds,
Zoche would have my vote, too! He has NEVER had one of his engines flown
in the 30 years that I have been aware of it.
If it sounds too good to be true, it probably is! (Like Zoche's engine)
Old January 6th 11, 01:28 AM posted to rec.aviation.homebuilt
On Jan 4, 9:24 am, jan olieslagers
Moller's the grandaddy of them all. Even takes deposits on vaporware.
Dan
Old January 5th 11, 12:14 AM posted to rec.aviation.homebuilt
BobR
planes?
TIA,
I don't know about the vaporware aspect but I did notice where they
upped the price to the point that it would make no sense to even
consider one over any other engine. Their initial concept and price
level looked attractive but the last time I looked, I laughed and
never went back.
Old January 17th 11, 07:42 PM posted to rec.aviation.homebuilt
Lots of hype on Diesels in airplanes, little action.
I wonder if the problem is the sharpness of the combustion event
destroying props?
Bill Hale BPPP instructor
planes?
TIA,
Old January 17th 11, 07:53 PM posted to rec.aviation.homebuilt
Morgans[_2_]
" wrote in message
destroying props?
Not at all.
The problem is that diesels are usually heavy as crap to withstand the
higher combustion chamber pressures that diesel engines have, mainly. The
other problem is that fuel pumps and injector systems used on diesel engines
usually will not work using jet fuel, which is the fuel these engines are
normally going to be using.
Of course, the largest problem is having the money it takes to develop an
engine and get it to market. Costs can be enormous.
Jim in NC
Old January 17th 11, 09:19 PM posted to rec.aviation.homebuilt
Tom De Moor
says...
Not at all.
Aero-diesels impose from the start a kind of supercharger, adding
complexity, weight and more things to go wrong.
Some makes add also a PSRU, once again adding weight, extra maintenance
and cost.
The
Diesel engines require minimal mods to run on Jet grade A1. The Thielert
Aero-Diesel Engine is nothing else than a Mercedes A-class motor. This
is also the reason why Thielert states TBR (to be replaced) instead of
TBO: due to the engine core being mass produced it is not economical to
overhaul.
Thielert is one of the few on the market We are - 6 years after the
promised launch- still waiting for the Delta Hawk, the WAMdiesel and
others. Thielert even found the time to go bust and recommence. :-)
When the lady goes shopping, costs can be enormous too.
Doesn't stop her either AND she enjoys the shopping. ;-)
Bottomline is that diesel or jet grade A1 is not yett an alternatif for
100LL, not even in Europe where 100LL is at 11.15 US$ / USG.
150 HP Diesel Thielert replacing a 150HP Lycoming in a C172 or PA28.
Engine 2000 Hr TBR: 39 kUS$ First installation aerodiesel: 20 kUS$
Fuel consumption: 7 USG/ Hr
150 HP Lyc Overhaul installation included : 15 kUS$
Fuel consumption : 9 USG/Hr
In Europe it is far more interesting to get an STC for mogas (which is
about 30% less expensif than 100LL).
Tom De Moor
Old January 18th 11, 08:17 AM posted to rec.aviation.homebuilt
bod43
On Jan 17, 9:19*pm, Tom De Moor
says...
Hmm, well a 2-stroke like the delta-hawk does.
On the other hand on the Deltahawk there are no -
magnetos, spark plugs, leads
valves, camshafts, followers, pushrods, rockers
cylinder head gaskets (head integral with cylinder)
Engine has *no* need for an electrical supply to run.
I have followed the development for a while and very much like
the concepts behind the deltahawk.
and cost.
Engine speed is such that no PSRU is required.
The
Deltahawk designed from outset for Jet fuel.
engine and get it to market. *Costs can be enormous.
DH are still there. They claim that "Experimental" engines
are available now with certification Real Soon
As I said, I like the options they have chosen for their
clean sheet design. There seems every prospect that they
will be safe, robust and economical if the fuel tax in any
particular jurisdiction does not rule that out.
zoche diesel status and specs? Ed Wischmeyer Home Built 5 June 21st 04 02:24 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Home Built 3 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Rotorcraft 2 September 13th 03 12:44 AM
