Sorry guys, can't find the answer via search, but what is a parallelogram stick?
On Jan 9, 6:07*pm, Timinnc wrote:
Sorry guys, can't find the answer via search, but what is a parallelogram stick? -- Timinnc It is where the stick just moves backwards and forwards on a parallelogram mechanism, as opposed to being bottom hinged. It's supposed to stop pilots putting in unintentional movements due to g loadings. Derek C |
Timinc,
I have pictures of a parallelogram stick assembly if you'd like to see them. Contact me c i r r u s c f i ( a t ) g m a i l . c o m |
On Jan 9, 1:07*pm, Timinnc wrote:
Sorry guys, can't find the answer via search, but what is a parallelogram stick? -- Timinnc Tim, the elevator input is given by moving the stick back and forth on a straight line rather than rotating the stick around one single hinge point. To make matters worth, the commonly used sticks are typically off-set from the hinge point towards the rear. High vertical accelration can induce an unwanted elevator input. As Derek pointed out, pilot induced oscillations due to vertical accelerations is not an issue with these sticks. The Glassfluegel H303, H304 (incl. the CZ) Mosquito and maybe other types have this type of stick. Uli |
On Jan 9, 2:54*pm, GM wrote:
On Jan 9, 1:07*pm, Timinnc wrote: Sorry guys, can't find the answer via search, but what is a parallelogram stick? -- Timinnc Tim, the elevator input is given by moving the stick back and forth on a straight line rather than rotating the stick around one single hinge point. To make matters worth, the commonly used sticks are typically off-set from the hinge point towards the rear. High vertical accelration can induce an unwanted elevator input. As Derek pointed out, pilot induced oscillations due to vertical accelerations is not an issue with these sticks. The Glassfluegel H303, H304 (incl. the CZ) Mosquito and maybe other types have this type of stick. Uli Almost all, if not all, of the DG series gliders have them. |
On Sun, 09 Jan 2011 16:36:39 -0800, brianDG303 wrote:
On Jan 9, 2:54Â*pm, GM wrote: On Jan 9, 1:07Â*pm, Timinnc wrote: Sorry guys, can't find the answer via search, but what is a parallelogram stick? -- Timinnc Tim, the elevator input is given by moving the stick back and forth on a straight line rather than rotating the stick around one single hinge point. To make matters worth, the commonly used sticks are typically off-set from the hinge point towards the rear. High vertical accelration can induce an unwanted elevator input. As Derek pointed out, pilot induced oscillations due to vertical accelerations is not an issue with these sticks. The Glassfluegel H303, H304 (incl. the CZ) Mosquito and maybe other types have this type of stick. Uli Almost all, if not all, of the DG series gliders have them. DG 300 for sure, but not, IIRC the DG1000 and I seem to remember a 'normal' stick in the DG-500. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Jan 9, 5:07*pm, Martin Gregorie
wrote: On Sun, 09 Jan 2011 16:36:39 -0800, brianDG303 wrote: On Jan 9, 2:54*pm, GM wrote: On Jan 9, 1:07*pm, Timinnc wrote: Sorry guys, can't find the answer via search, but what is a parallelogram stick? -- Timinnc Tim, the elevator input is given by moving the stick back and forth on a straight line rather than rotating the stick around one single hinge point. To make matters worth, the commonly used sticks are typically off-set from the hinge point towards the rear. High vertical accelration can induce an unwanted elevator input. As Derek pointed out, pilot induced oscillations due to vertical accelerations is not an issue with these sticks. The Glassfluegel H303, H304 (incl. the CZ) Mosquito and maybe other types have this type of stick. Uli Almost all, if not all, of the DG series gliders have them. DG 300 for sure, but not, IIRC the DG1000 and I seem to remember a 'normal' stick in the DG-500. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | DG1000 is "normal" Kestrel's also had the parallelogram stick. took very little time to get used to and was quite comfortable to fly with. Al |
I was told that the parallelogram stick was to prevent PIO. Is that
the same as "unintentional movements due to g loadings"? I have flow a DG-101G, DG-300 and DG-303 with a parallelogram stick. I also fly an assortment of ships without a parallelogram stick. Honestly, I don't know if I have noticed much of a difference. However, the DG (with parallelogram) has a CG release while the others (non-parallelogram) do not. Would a parallelogram stick help prevent ballooning (with ugly consequences). If so, I am all for it. - John |
On Sun, 09 Jan 2011 18:20:39 -0800, wrote:
Kestrel's also had the parallelogram stick. So does the Glasflugel Mosquito. took very little time to get used to and was quite comfortable to fly with. The only parallelogram stick glider I've flown was a DG-300. My impressions were the same as yours. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Jan 10, 1:07*am, Martin Gregorie
wrote: On Sun, 09 Jan 2011 16:36:39 -0800, brianDG303 wrote: On Jan 9, 2:54*pm, GM wrote: On Jan 9, 1:07*pm, Timinnc wrote: Sorry guys, can't find the answer via search, but what is a parallelogram stick? -- Timinnc Tim, the elevator input is given by moving the stick back and forth on a straight line rather than rotating the stick around one single hinge point. To make matters worth, the commonly used sticks are typically off-set from the hinge point towards the rear. High vertical accelration can induce an unwanted elevator input. As Derek pointed out, pilot induced oscillations due to vertical accelerations is not an issue with these sticks. The Glassfluegel H303, H304 (incl. the CZ) Mosquito and maybe other types have this type of stick. Uli Almost all, if not all, of the DG series gliders have them. DG 300 for sure, but not, IIRC the DG1000 and I seem to remember a 'normal' stick in the DG-500. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * |- Hide quoted text - - Show quoted text - We have a DG300 fitted with a parallelogram stick based at our site. It seems to be more prone to pilot induced oscillations on aerotow than most! Derek C |
Dead Stick | Big John | Piloting | 18 | August 3rd 08 04:25 AM |
Big Stick | R. J. \(Bob\) Van Horn | Piloting | 5 | September 4th 07 06:54 PM |
Stick on Bi-focals | MC | Soaring | 0 | December 6th 04 03:24 AM |
The F-16 control stick? | Christopher | Military Aviation | 13 | September 22nd 03 10:18 AM |
Stick grips | John Nicholson | Home Built | 17 | July 23rd 03 10:13 AM |
