I am pleased to announce that the opensource and free software LK8000 v.2.0 was released today.
It is now translated into 14 languages. paolo |
On Jan 15, 10:03*am, "PCool" wrote:
I am pleased to announce that the opensource and free software LK8000 v.2..0 *was released today. It is now translated into 14 languages. paolo Just curious, can LK8000 run on an Oudie? Kirk 66 |
Yes, if you can boot off the SD card. The OS (Windows CE) is supported.
On Jan 15, 9:03*am, "PCool" wrote:
I am pleased to announce that the opensource and free software LK8000 v.2..0 *was released today. It is now translated into 14 languages. paolo Very nice Paolo. Thank you for your great effort. |
On Jan 15, 2:59*pm, mike wrote:
On Jan 15, 9:03*am, "PCool" wrote: I am pleased to announce that the opensource and free software LK8000 v..2.0 *was released today. It is now translated into 14 languages. paolo Very nice Paolo. Thank you for your great effort. I have been using this for awhile on an old nokia navigator, but I need something with better battery life, and USB for condor. Anyone have any suggestions? Thanks |
On Jan 15, 8:03*am, "PCool" wrote:
I am pleased to announce that the opensource and free software LK8000 v.2..0 *was released today. It is now translated into 14 languages. paolo ok, so I am looking for the installation instructions so I can stop seeing the fatal error 001 code and start seeing the program. no links for the manual, at least that I can find, and no description on how to install other than read the manual..............so I am in a quandary. of course, the info is probably right in front of me but I don't see it. help! Brad |
On Mon, 17 Jan 2011 18:32:34 -0800, Brad wrote:
ok, so I am looking for the installation instructions so I can stop seeing the fatal error 001 code and start seeing the program. no links for the manual, at least that I can find, and no description on how to install other than read the manual..............so I am in a quandary. of course, the info is probably right in front of me but I don't see it. Unzip it onto an empty SD card, copy your airspace, map (.LKM + .DEM) and turnpoint files into the appropriate subdirectories. Add your polar file if you use a one. Set up the launch system as you did for the previous version: Binatone B.350s need a 'shell.ini' file in the root of the SD card to tell WM 5 or 6 where to find LK8000. This should run OK. *DON'T* copy over your old task and profile files because both file formats have changed. The release notes mention that the task file format has changed, but say nothing about the profiles. I initially copied mine over and got a crash during start-up. I'd wondered if copying the profiles was a good idea, so I restored the ones that were in the 2.0a zip file and this time it 'just ran'. The only snaggettes I've found a - configuration: it defaults to metric units, so select the files on page 1 and then go immediately to the Units page, select feet, knots, etc. and then immediately exit config, shut down and restart. If you don't restart at that point you'll find that its still expecting safety heights, etc to be input in metric values. - custom overlay colours: If, like me, you fly with terrain turned off and a white background for maximum contrast, set 'Inverse b/w' ON and 'overlay colours' to WHITE, but leave 'Turnpoint labels' set to BLACK. If you set the turnpoint labels to white as well, turnpoints marked as Airfields will appear as white with a black border though the rest will be plain black. - finding the GPS device: my Binatone came up with both devices set to COM1 and so LK8000 reported that no GPS was found until I manually set the devices to COM7. Another way is to unzip it into the C:\ drive, add files as described above and then run up LK8000-PC.EXE in sim mode, configure this as you like it and then copy the LK8000 directory and all its contents to a blank SD card. This will leave everything (except possibly the GPS ports) set correctly. I like having the sim functions rolled into the main LK8000 program - that was a good move. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Well this is really interesting, at least for me.
What's difficult in looking into www.lk8000.it and the download section? See the download menu: maps, manual, software... Manuals! The fatal error is given because you have not installed the software correctly, probably in the wrong directory. But on the same fatal error screen, you can also clearly read what the program is trying to access, the full path. That's the place, of course. So the question is: where have you been looking for manuals so far? paolo "Brad" ha scritto nel messaggio ... On Jan 15, 8:03 am, "PCool" wrote: I am pleased to announce that the opensource and free software LK8000 v.2.0 was released today. It is now translated into 14 languages. paolo ok, so I am looking for the installation instructions so I can stop seeing the fatal error 001 code and start seeing the program. no links for the manual, at least that I can find, and no description on how to install other than read the manual..............so I am in a quandary. of course, the info is probably right in front of me but I don't see it. help! Brad |
On Tue, 18 Jan 2011 16:35:25 +0000, PCool wrote:
Well this is really interesting, at least for me. What's difficult in looking into www.lk8000.it and the download section? See the download menu: maps, manual, software... Manuals! Paolo, Just to clarify: does the 1.22 manual, which is what I see on the manual page, also apply to 2.0? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
The latest available version is 1.22b manual, as written on the download
page. The install procedure is the same. But even in doubts, when nothing else better is available, why not looking into the available manual release 5 months ago? Other gliding software have a manual obsoleted by years.. The web pages have now explanation about new 2.0 features, while I am updating the 2.0 doc. "Martin Gregorie" ha scritto nel messaggio ... On Tue, 18 Jan 2011 16:35:25 +0000, PCool wrote: Well this is really interesting, at least for me. What's difficult in looking into www.lk8000.it and the download section? See the download menu: maps, manual, software... Manuals! Paolo, Just to clarify: does the 1.22 manual, which is what I see on the manual page, also apply to 2.0? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
iPAQ-310-LK8000-wind calculation | Brad[_2_] | Soaring | 6 | September 7th 10 11:05 PM |
The LK8000 copyright issue is solved | Max Kellermann | Soaring | 5 | September 7th 10 06:50 PM |
LK8000 questions | Andy[_1_] | Soaring | 9 | March 15th 10 11:10 AM |
New LK8000 glide computer video | PCool | Soaring | 6 | October 12th 09 06:19 PM |
T-37 PCATD released | JD | Simulators | 0 | October 6th 03 08:51 PM |
