Our Hartzell prop governor on an IO-360 Lyc has developed a nasty little oil
leak around the control shaft. The company in Wichita that successfully repaired it many years ago is no longer performing this type of work. Currently we are considering sending it directly to Hartzell, but if good experiences have been found in the midwest, we would be interested. The prop and governor were overhauled in '98. (about 750 hrs ago). Thanks and reply to newsgroup. ks_av8r |
![]() "ks_av8r" wrote in message ... Our Hartzell prop governor on an IO-360 Lyc has developed a nasty little oil leak around the control shaft. I'd recommend finding anybody other than Hartzell to do the work. Their shop has a propensity for: 1. Being expensive to begin with. 2. Insisting on additional work not strictly required. 3. Declaring things unairworthy (and defacing them in the process). Many prop shops can work on your governor. If you can't find anybody else, I think that Sennsenich in Lancaster, PA will do it (yes, they work on Hartzell props). |
Thanks for the lead. We will follow up with Sennsenich. And thanks for the
answer before I asked it about working on Hartzell's, because I was already thinking it before I got to the end of the sentence ![]() Denny "Ron Natalie" wrote in message m... "ks_av8r" wrote in message ... Our Hartzell prop governor on an IO-360 Lyc has developed a nasty little oil leak around the control shaft. I'd recommend finding anybody other than Hartzell to do the work. Their shop has a propensity for: 1. Being expensive to begin with. 2. Insisting on additional work not strictly required. 3. Declaring things unairworthy (and defacing them in the process). Many prop shops can work on your governor. If you can't find anybody else, I think that Sennsenich in Lancaster, PA will do it (yes, they work on Hartzell props). |
Terra Switch repair | George A. Graham | Home Built | 1 | October 25th 03 12:15 AM |
