J.S.W Calculator--K35
Old February 1st 11, 02:12 AM posted to rec.aviation.soaring
Dave White
Default J.S.W Calculator--K35
I have an old whiz wheel that is apparently used to calculate height
needed to cover a specified distance. I got it with my Libelle 201B.
Was just looking at it and trying to figure it out. It has a
semicircular rotating part on the front with Height Needed across the
top and a speed scale across the bottom (flat side). On the fixed
card, the outer scale is Nautical Miles to Go and there is a wind
component graph at the bottom left and upper right. It looks like I
put my speed to fly over the wind component and then read altitude
required under the desired distance. Does anyone know if that is
correct? Also, I think it's missing a piece on the back. The back of
the whiz wheel is labeled JSW Wind Component Resolver. The brass hub
is there, but there's not any moving part, which I suspect is
required. It says made in England, Copyright 1986 JS Williamson. Can
anyone give me more information about this little device?
Old February 1st 11, 06:34 AM posted to rec.aviation.soaring
JS
Think there was just one moving part on the front, operating as you
assumed.
It's also been called a Dial-A-Prayer Wheel.
I probably still have one somewhere, along with a similar dusty old
slide rule for SCUBA diving.
....Or did it get given away with the barograph, foil and camphor?
Old February 1st 11, 03:15 PM posted to rec.aviation.soaring
Tim Mara
it should have the simple instruction written right on it.......most did
simple to set the datum mark to the distance to go and read the altitude
needed (on the squiggled line for the different winds) and/or set the datum
line to the altitude you have and read the distance you can go before
striking the earth surface...pretty much works like an E6B.
tim
"Dave White" wrote in message
__________ Information from ESET NOD32 Antivirus, version of virus
signature database 5837 (20110201) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5837 (20110201) __________
http://www.eset.com
density altitude calculator and wind calculator on web site and asGoogle gadget Howie Piloting 3 August 5th 07 11:52 PM
density altitude calculator and wind calculator on web site and asGoogle gadget virtuPIC[_2_] General Aviation 0 August 4th 07 05:55 PM
VFR xcountry calculator/log (NEW!!!) Cecilia Lang Piloting 0 December 26th 05 10:45 AM
Calculator Phoebus_810 Soaring 0 January 8th 05 04:36 PM
JSW Glide Calculator snaproll59 Soaring 5 November 7th 04 04:01 PM
