It has been a few weeks since I added glide slope receiver (KN75) and ILS
indicater (KI209A) to my trusted KX125. All was well, and they track ILS just fine. But when tracking VOR, com transmission would somehow block off nav signal and both indicators (KI209A & KN125 built-in) would show "off" flag. It acts like those old 1&1/2 nav/com radios. I do not remember if my KX125 acted this way before I added KN75 & KI209A to it. I tried disconnecting the KI209A from it, but it still show "off" flag on its built-in indicator when transmitting. I did not try to disconnect the KN75 because it is hard to get to. Questions: 1. When transmitting from my other com radio, KX125 & KI209A do not lost nav signal. Does that rule out antenna problem? 2. I also noted that the "comm audio" line is not the shield type. Could this be the problem? 3. Is it likely the KN75 might be the problem, does it worth the time to disconnect it from KX125 and see if KN75 is the problem? Many thanks, Robin Hou |
nav signal. Does that rule out antenna problem? No. The two com radios use different antennas. What are you using for a glideslope antenna? I use a triplexer w/dual VOR & single GS. One of the VOR connector on the triplexer was left unconnected because I have only one Nav. |
No. Both com ant are about the same distance to nav ant.
This does sound very much like Radio Frequency Interference.
Do you still have a solid ident on the audio? If yes, then the shielding on the harness between the KX125 and the KI209 is in question. If no, then we have to think about antenna VSWR, etc. "ROBIN FLY" wrote in message ... It has been a few weeks since I added glide slope receiver (KN75) and ILS indicater (KI209A) to my trusted KX125. All was well, and they track ILS just fine. But when tracking VOR, com transmission would somehow block off nav signal and both indicators (KI209A & KN125 built-in) would show "off" flag. It acts like those old 1&1/2 nav/com radios. I do not remember if my KX125 acted this way before I added KN75 & KI209A to it. I tried disconnecting the KI209A from it, but it still show "off" flag on its built-in indicator when transmitting. I did not try to disconnect the KN75 because it is hard to get to. Questions: 1. When transmitting from my other com radio, KX125 & KI209A do not lost nav signal. Does that rule out antenna problem? 2. I also noted that the "comm audio" line is not the shield type. Could this be the problem? 3. Is it likely the KN75 might be the problem, does it worth the time to disconnect it from KX125 and see if KN75 is the problem? Many thanks, Robin Hou |
If yes, then the shielding on the harness between the KX125 and the KI209 is in question. I do not know, but I will find out next time I fly. Thanks. |
Do you still have a solid ident on the audio? If yes, then the shielding on the harness between the KX125 and the KI209 is in question. If no, then we have to think about antenna VSWR, etc. I finaly disconected both KI-209A and KN-75 from my KX-125, but tracking a VOR while transmit on COM still resulted "off" flag on KX-125's internal CDI. I took a test flight to POC which has a VOR and ILS, and I found the following: Transmitting on Com does not cut off ILS like it does with VOR; When VOR went "off" while transmitting, there was no ident on Nav audio, the Nav audio became completely silent; and Pomona VOR is 110.40 and I transmitted on all fequency from 118 to 136 and each fequency cuts off the VOR just the same. Help! Thanks, Robin Hou |
The frequency spread between the com and VOR/LOC frequencies is only a
few percent. The frequency spread between the com and glide slope is about 300%. While transmitting you are generating tens of VOLTS per meter at the transmit antenna while trying to receive MICRO volts per meter VOR signals at the nav antenna. To do this at the same time requires a lot of isolation between the transmitter and the receiver. You can easily filter out the transmitter signal if it is 1/3 of the receiver freq however if it is only a few percent away this requires very precise filters which are large, heavy and cost a lot of money. Unless you have a airplane as large as a airliner it is difficult to get the antennas spaced far enough away from each other to get the necessary isolation. This is one reason that the nav signal is horizonal polarized and the com is vertical polarized. and spaced as far apart on the aircraft as possible. Unless you have a strong nearby nav signal and GOOD shielding on both antenna cables the transmitter will overload the nav receiver resulting in no signal during transmit. You did not run the two antenna cables next to each other did you? The easy fix is to QUIT RUNNING YOUR MOUTH while making an approach! On 19 Sep 2003 23:11:56 GMT, (Sircompany) wrote: This does sound very much like Radio Frequency Interference. Do you still have a solid ident on the audio? If yes, then the shielding on the harness between the KX125 and the KI209 is in question. If no, then we have to think about antenna VSWR, etc. I finaly disconected both KI-209A and KN-75 from my KX-125, but tracking a VOR while transmit on COM still resulted "off" flag on KX-125's internal CDI. I took a test flight to POC which has a VOR and ILS, and I found the following: Transmitting on Com does not cut off ILS like it does with VOR; When VOR went "off" while transmitting, there was no ident on Nav audio, the Nav audio became completely silent; and Pomona VOR is 110.40 and I transmitted on all fequency from 118 to 136 and each fequency cuts off the VOR just the same. Help! Thanks, Robin Hou |
GPT (Gulfport MS) ILS 14 question | A Lieberman | Instrument Flight Rules | 18 | January 30th 05 04:51 PM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Question | Charles S | Home Built | 4 | April 5th 04 09:10 PM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
Partnership Question | Harry Gordon | Owning | 4 | August 16th 03 11:23 PM |
