I have the copy of the CAFE test of Cozy Mk IV canard where it states
that swept wings tend to start stalling at the tip rather than the root. This moves the center of lift forward and is a bigger problem for aft CG. While canard planes swept wings typically already have those "vortilon" tabs, has anyone investigated placing a few vortilons near outer wing part to compensate for the early tip stall tendency? I am talking about the main swept wing of a typical canard and not the front canard wing itself. ---------------------------------------------------- Paul Lee, SQ2000 canard project: www.abri.com/sq2000 |
that swept wings tend to start stalling at the tip rather than the root. This moves the center of lift forward and is a bigger problem for aft CG. By the very nature of a canard configuration, if the aft wing stalls, the tip will stall first, as it it in the upwash caused by the tip vortex coming off the canard. The inboard part of the aft wing is in downwash from the canard. With that said, the aft wing of a canard aircraft should NEVER be allowed to stall. If it does, the neutral point will shift forward and the aircraft will become longitudinally unstable. The idea is for the canard to stall first. This makes the airplane more stable and causes the nose to pitch down. While canard planes swept wings typically already have those "vortilon" tabs, has anyone investigated placing a few vortilons near outer wing part to compensate for the early tip stall tendency? The vortilons are always placed on the outer part of the aft wing of a canard configured aircraft, to keep the outer aft wing from stalling. There is no sense on placing them on the inboard wing, unless the aircraft is really screwed up. On early VariEzes, it was found that the outboard portion of the aft wing, of poorly built aircraft, would stall. Rutan retrofitted a cuff on the outboard aft wing, to prevent this stalling. |
I know about what should be about CG and main wing should
not be allowed to stall, etc. etc. But my question is about possible further improvement. I mistyped the last sentence question. "..has anyone investigated placing a few vortilons near outer wing part to compensate for the early tip stall tendency?.." Should have been ...has anyone investigated placing a few vortex generator tabs near outer wing part to compensate for the early tip stall tendency? I am talking about the popular small VG tabs on top of the wings. And if a few could be placed near the last 1 or two feet of the outboard wing part to improve wing stall. The usual vortilon tabs used on swept wings are not really on the extreme part of wing outboard but rather almost mid wing. Inboard (imagine wing sweep) --------------------------------------------------------------- / \ / \ - extra VG's --------------------------------------------------------------- | | | - current vortilons David Lednicer wrote in message ... I have the copy of the CAFE test of Cozy Mk IV canard where it states that swept wings tend to start stalling at the tip rather than the root. This moves the center of lift forward and is a bigger problem for aft CG. By the very nature of a canard configuration, if the aft wing stalls, the tip will stall first, as it it in the upwash caused by the tip vortex coming off the canard. The inboard part of the aft wing is in downwash from the canard. With that said, the aft wing of a canard aircraft should NEVER be allowed to stall. If it does, the neutral point will shift forward and the aircraft will become longitudinally unstable. The idea is for the canard to stall first. This makes the airplane more stable and causes the nose to pitch down. While canard planes swept wings typically already have those "vortilon" tabs, has anyone investigated placing a few vortilons near outer wing part to compensate for the early tip stall tendency? The vortilons are always placed on the outer part of the aft wing of a canard configured aircraft, to keep the outer aft wing from stalling. There is no sense on placing them on the inboard wing, unless the aircraft is really screwed up. On early VariEzes, it was found that the outboard portion of the aft wing, of poorly built aircraft, would stall. Rutan retrofitted a cuff on the outboard aft wing, to prevent this stalling. |
My recollection, from an aerodynamics class long ago, is that the tendency
of a wing to stall first at the tip and progress inward is not a function of sweep. The sweep just makes it LETHAL. Assuming that the wing has no twist, also known as wash-out, and that the wing is well constructed and finished; then: 1 A straight (Hershey Bar) wing will stall from the root outward. 2 An elliptical wing will stall all at once. 3 A radically tapered (2:1) wing will stall from the tip inward. 4 A moderately tapered wing will approximate an elliptical wing. The earlier comment regarding the canard vortex on the Vari-Eze is an excellent note of caution, as it will tend to simulate reverse wash-out of the main wing. Therefore, it the main wing was ever allowed to stall, it could be expected to do so in the manner of a wing with a much more radical taper ... BTW, radically swept tapered wings have the reputation of being impossible to recover from a stall -- if you allow it to occur! Peter Paul Lee wrote: I know about what should be about CG and main wing should not be allowed to stall, etc. etc. But my question is about possible further improvement. I mistyped the last sentence question. "..has anyone investigated placing a few vortilons near outer wing part to compensate for the early tip stall tendency?.." Should have been ..has anyone investigated placing a few vortex generator tabs near outer wing part to compensate for the early tip stall tendency? I am talking about the popular small VG tabs on top of the wings. And if a few could be placed near the last 1 or two feet of the outboard wing part to improve wing stall. The usual vortilon tabs used on swept wings are not really on the extreme part of wing outboard but rather almost mid wing. Inboard (imagine wing sweep) --------------------------------------------------------------- / \ / \ - extra VG's --------------------------------------------------------------- | | | - current vortilons David Lednicer wrote in message ... I have the copy of the CAFE test of Cozy Mk IV canard where it states that swept wings tend to start stalling at the tip rather than the root. This moves the center of lift forward and is a bigger problem for aft CG. By the very nature of a canard configuration, if the aft wing stalls, the tip will stall first, as it it in the upwash caused by the tip vortex coming off the canard. The inboard part of the aft wing is in downwash from the canard. With that said, the aft wing of a canard aircraft should NEVER be allowed to stall. If it does, the neutral point will shift forward and the aircraft will become longitudinally unstable. The idea is for the canard to stall first. This makes the airplane more stable and causes the nose to pitch down. While canard planes swept wings typically already have those "vortilon" tabs, has anyone investigated placing a few vortilons near outer wing part to compensate for the early tip stall tendency? The vortilons are always placed on the outer part of the aft wing of a canard configured aircraft, to keep the outer aft wing from stalling. There is no sense on placing them on the inboard wing, unless the aircraft is really screwed up. On early VariEzes, it was found that the outboard portion of the aft wing, of poorly built aircraft, would stall. Rutan retrofitted a cuff on the outboard aft wing, to prevent this stalling. |
Peter,
That is certainly nice iformation to know. But back to my original question - to help the situation. "..has anyone investigated placing a few vortilons near outer wing part to compensate for the early tip stall tendency?.." This could be done with a standard EZ by observing if the bobing stall frequency increases with addition of a few outboard vortex generators. Any EZ volunteers out there? Here is the procedu Measure the stall bobing frequency as a position of CG. Then measure it again after the few outboard VG's are installed and see if the frequency increases or decreases with CG position. Would not be very expensive, just time consuming. I am building a SQ2000 canard but KLS Composites has designed the thing so that there is no bobing stall frequency - it simply descends at a constant rate. KLS demonstated that to me in their factory bird. So I can't do the test - at least in the same way. ---------------------------------------------------- Paul Lee, SQ2000 canard project: www.abri.com/sq2000 Peter Dohm wrote in message ... My recollection, from an aerodynamics class long ago, is that the tendency of a wing to stall first at the tip and progress inward is not a function of sweep. The sweep just makes it LETHAL. Assuming that the wing has no twist, also known as wash-out, and that the wing is well constructed and finished; then: 1 A straight (Hershey Bar) wing will stall from the root outward. 2 An elliptical wing will stall all at once. 3 A radically tapered (2:1) wing will stall from the tip inward. 4 A moderately tapered wing will approximate an elliptical wing. The earlier comment regarding the canard vortex on the Vari-Eze is an excellent note of caution, as it will tend to simulate reverse wash-out of the main wing. Therefore, it the main wing was ever allowed to stall, it could be expected to do so in the manner of a wing with a much more radical taper ... BTW, radically swept tapered wings have the reputation of being impossible to recover from a stall -- if you allow it to occur! Peter .. |
Dang it... I copied the wrong question again... here is the correct stuff..
back to my original question - to help the situation. ...has anyone investigated placing a few vortex generator tabs near outer wing part to compensate for the early tip stall tendency? This could be done with a standard EZ by observing if the bobing stall frequency increases with addition of a few outboard vortex generators. Any EZ volunteers out there? Here is the procedu Measure the stall bobing frequency as a position of CG. Then measure it again after the few outboard VG's are installed and see if the frequency increases or decreases with CG position. Would not be very expensive, just time consuming. I am building a SQ2000 canard but KLS Composites has designed the thing so that there is no bobing stall frequency - it simply descends at a constant rate. KLS demonstrated that to me in their factory bird. So I can't do the test - at least in the same way. ---------------------------------------------------- Paul Lee, SQ2000 canard project: www.abri.com/sq2000 |
Proposed new flightseeing rule | C J Campbell | Home Built | 56 | November 10th 03 05:40 PM |
wing root strakes (not canard A/C) | Wallace Berry | Home Built | 0 | October 2nd 03 08:47 PM |
Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 03:40 PM |
Can someone explain wing loading? | Frederick Wilson | Home Built | 4 | September 10th 03 02:33 AM |
Wing Extensions | Jay | Home Built | 22 | July 27th 03 12:23 PM |
