I purchased one of the new SPOT’s (SPOT Satellite Messenger, sometimes
called SPOT II). As a fall-back, I have a few options for mounting it directly on my ship, but I’d prefer a chute mount. I’ve read Allen Silvers 2009 file on how NOT to attach it to a parachute, although that file didn’t seem to say how/where was a good place to attach it. I will talk to my rigger, but first wanted to check for actual experience with the latest generation SPOT. I looked in ras for recent posts on mounting the SPOT, but only found a set of posts in early 2009 and early 2010. I’d like to check for experience last season with the newer units. Specifically how well did parachute attachments work (good tracking), and how/where on the chute was it attached? Thanks, - Frank |
On Mar 14, 2:03*pm, V1 wrote:
I purchased one of the new SPOT’s (SPOT Satellite Messenger, sometimes called SPOT II). As a fall-back, I have a few options for mounting it directly on my ship, but I’d prefer a chute mount. I’ve read Allen Silvers 2009 file on how NOT to attach it to a parachute, although that file didn’t seem to say how/where was a good place to attach it. I will talk to my rigger, but first wanted to check for actual experience with the latest generation SPOT. I looked in ras for recent posts on mounting the SPOT, but only found a set of posts in early 2009 *and early 2010. I’d like to check for experience last season with the newer units. Specifically how well did parachute attachments work (good tracking), and how/where on the chute was it attached? Thanks, - Frank Frank, see: http://www.silverparachutes.com/smak_pak.html I have the "new" SPOT as well and mount it in a similar location as is shown in those pictures for the SMAK pack. I think I usually put my spot on my left side, above the chest strap but low enough that it doesn't cause issues like you read about with the parachute opening. I picked up some velcro bands and use those to attache the SPOT to the chute. I've never had any issues with satellite reception as long as the SPOT is working otherwise. |
I mount my SPOT 1 on the left sholder strap but only through the outer most
strap. In my Ventus I am laynig back and that gives a relatively flat facing up and have had no issues of not seeing tracks. The outer most strap on my chute is the one that is attached to the harness and the spot will not interfere with the deployment. At 19:19 14 March 2011, Tony wrote: On Mar 14, 2:03=A0pm, V1 wrote: I purchased one of the new SPOT=92s (SPOT Satellite Messenger, sometimes called SPOT II). As a fall-back, I have a few options for mounting it directly on my ship, but I=92d prefer a chute mount. I=92ve read Allen Silvers 2009 file on how NOT to attach it to a parachute, although that file didn=92t seem to say how/where was a good place to attach it. I will talk to my rigger, but first wanted to check for actual experience with the latest generation SPOT. I looked in ras for recent posts on mounting the SPOT, but only found a set of posts in early 2009 =A0and early 2010. I=92d like to check for experience last season with the newer units. Specifically how well did parachute attachments work (good tracking), and how/where on the chute was it attached? Thanks, - Frank Frank, see: http://www.silverparachutes.com/smak_pak.html I have the "new" SPOT as well and mount it in a similar location as is shown in those pictures for the SMAK pack. I think I usually put my spot on my left side, above the chest strap but low enough that it doesn't cause issues like you read about with the parachute opening. I picked up some velcro bands and use those to attache the SPOT to the chute. I've never had any issues with satellite reception as long as the SPOT is working otherwise. |
My rigger added a webbing "hard point" on the left riser cover of a
couple of Mini Softies. The cover is only sewn to the harness on the inside, velcroed on the outside to allow riser deployment. Position is about perfect for the SPOT 1 that's on each. Best mount I found for the older SPOT uses a modified pouch that Wings And Wheels used to sell for the EBC 102 Personal ELT. The SPOT 2 has it's own pouch so should be easier to mount on the hard point. Jim |
I have several pair of jeans modified for flying. I have a had a pocket put
on the left leg just below the knee for my spot; right leg has a pocket for my first aid kit - 2 things I want with me if I bail out. My glider has an instrument pod rather than a panel. My lower legs have a clear view of the sky thru the canopy. My Spot works great in this position and it's out of the way. While it works for me, not a solution for everyone. John |
I use a small caribiner to attach my Spot 2 to the metal ring that my
chest strap clips into. I figure if the chest strap can clip in, so can the Spot. I'm fairly reclined in my Kestrel and the Spot sits on my chest looking upwards -- no issues getting reception. And I'd rather have it with me instead of the ship, in case we get separated. |
город долгопрудный знакомства где можно познакомиться мусульманские знакомства москва, знакомства г ухта пары би знакомства быстрый секс онлайн, знакомства санкт петерберг секс знакомства качканар сайт знакомств воткинск, rambler знакомства url зарегистрирован чат тольятти секс секс домашняя съемка онлайн, сайт знакомств израиль сайт знакомств инвалидов знакомства любовь ру, знакомства эмо симферополь знакомства города димитровграда анкеты знакомств североуральск, чара знакомства сайт знакомств г обнинска знакомства юрьев польский, знакомства г нежин порно хентай секс онлайн мамаши хотят секса онлайн
On Mar 14, 12:03*pm, V1 wrote:
I purchased one of the new SPOT’s (SPOT Satellite Messenger, sometimes called SPOT II). As a fall-back, I have a few options for mounting it directly on my ship, but I’d prefer a chute mount. I’ve read Allen Silvers 2009 file on how NOT to attach it to a parachute, although that file didn’t seem to say how/where was a good place to attach it. I will talk to my rigger, but first wanted to check for actual experience with the latest generation SPOT. I looked in ras for recent posts on mounting the SPOT, but only found a set of posts in early 2009 *and early 2010. I’d like to check for experience last season with the newer units. Specifically how well did parachute attachments work (good tracking), and how/where on the chute was it attached? Thanks, - Frank I initially flew with my SPOT I located on the top right of the chute shoulder strap (45deg angle). Drop message rates were significantly high... say 15-30 per cent .. sometimes higher. Flying a Discus 2A and I suspect the carbon in the fuselage obscured coverage. When moving it to the top of the instrument panel cover lying flat (hooked on by a piece of tie wrap), error rates lowered to near zero. My 2 cents... Walt Rogers |
On Mar 16, 11:32*am, WaltWX wrote:
On Mar 14, 12:03*pm, V1 wrote: I purchased one of the new SPOT’s (SPOT Satellite Messenger, sometimes called SPOT II). As a fall-back, I have a few options for mounting it directly on my ship, but I’d prefer a chute mount. I’ve read Allen Silvers 2009 file on how NOT to attach it to a parachute, although that file didn’t seem to say how/where was a good place to attach it. I will talk to my rigger, but first wanted to check for actual experience with the latest generation SPOT. I looked in ras for recent posts on mounting the SPOT, but only found a set of posts in early 2009 *and early 2010. I’d like to check for experience last season with the newer units. Specifically how well did parachute attachments work (good tracking), and how/where on the chute was it attached? Thanks, - Frank I initially flew with my SPOT I located on the top right of the chute shoulder strap (45deg angle). Drop message rates were significantly high... say 15-30 per cent .. sometimes higher. Flying a Discus 2A and I suspect the carbon in the fuselage obscured coverage. When moving it to the top of the instrument panel cover lying flat (hooked on by a piece of tie wrap), error rates lowered to near zero. *My 2 cents... Walt Rogers I flew the whole season last year with Spot 2 (over 300 hours). It is mounted on my parachute strap below the problematic area (verified by Allen Silver). I am getting zero dropped messages (at least when reviewing my messages after the flight, it is still possible some messages were delayed by more than 10 minutes and then cought up). Another concern I read before about Spot 2 was battery life. While indeed it is shorter than Spot 1, it is still quiet reasonable. I found out I need to replace mine every 100-150 flying hours. The Spot 2 UI is much better than Spot 1 and the additional custom message makes it much more useful for communicating with your crew, as you can decide on 3 different course of actions based on the message type (OK, Help or Custom). Ramy |
Spot deal, today only, buy service get a free Spot | Tim Taylor | Soaring | 3 | December 1st 08 10:30 PM |
Mounting 396 | Paul kgyy | Piloting | 40 | August 24th 07 08:47 AM |
Mounting 396 | Paul kgyy | Owning | 30 | August 24th 07 08:47 AM |
Mounting my GPS | Charles Talleyrand | Owning | 8 | November 19th 03 11:51 AM |
Mounting my GPS | Charles Talleyrand | Piloting | 8 | November 19th 03 11:51 AM |
