Okay folks, your thoughts on the Standard Cirrus? Good, bad indifferent? Flying tail, pros and cons? I am new to gliding, Commercial Add on, 140 flights and approx 100 hours, mostly in 1-34. Would this be a reasonable next step?
Walt |
Delightful glider.
All flying tail - not really any pros or cons just different. You have a lot of elevator authority and low loads so if you waggle the stick you'll waggle the glider. Personally I liked the fact that I didn't have to continually adjust the trimmer. Airbrakes - without the double paddle mod they're pretty poor. With the mod they're similar to other glass gliders from the same era (Libelle, ASW15). Need to get your circuits & speed control sorted, less forgiving than the barn-door airbrakes on a Discus or LS4. Transition from 1-34 - No comment 'cos I haven't flown a 1-34, but probably no different to the transition to any other glass single seat. Find someone who's flown one a lot & talk to them. Try to avoid the opinions of people who haven't! Kevin At 01:55 17 March 2011, Walt Connelly wrote: Okay folks, your thoughts on the Standard Cirrus? Good, bad indifferent? Flying tail, pros and cons? I am new to gliding, Commercial Add on, 140 flights and approx 100 hours, mostly in 1-34. Would this be a reasonable next step? Walt -- Walt Connelly |
On Mar 16, 9:55*pm, Walt Connelly Walt.Connelly.
wrote: Okay folks, your thoughts on the Standard Cirrus? *Good, bad indifferent? *Flying tail, pros and cons? *I am new to gliding, Commercial Add on, 140 flights and approx 100 hours, mostly in 1-34. Would this be a reasonable next step? Walt -- Walt Connelly This would be a reasonable step given some intermediate glider experience. Get a good check out from a knowledgable instructor and ideally, a pilot that is skilled in type. Good Luck UH |
On Mar 16, 6:55*pm, Walt Connelly Walt.Connelly.
wrote: Okay folks, your thoughts on the Standard Cirrus? *Good, bad indifferent? *Flying tail, pros and cons? *I am new to gliding, Commercial Add on, 140 flights and approx 100 hours, mostly in 1-34. Would this be a reasonable next step? Walt -- Walt Connelly Yes, but so is pretty much any 15 meter glass ship. If you're looking at a Standard Cirrus, I'm guessing money IS an object. In near the same price range don't rule out Libelles or Jantars. You've read it here many times - the trailer makes a big difference. |
Or ASW 15s
but watch max gross.Mike |
G-102 would be excellent.
On a side note: Grider Pirate should really be Grider Pirot. Makes me wany to sing "Put a feather in his cap and called it Macalloni." (Sorry for the bad linguistic joke; if you don't get it, look up "macaronic" -- and I know it is still bad.) At 13:57 17 March 2011, Grider Pirate wrote: On Mar 16, 6:55=A0pm, Walt Connelly wrote: Okay folks, your thoughts on the Standard Cirrus? =A0Good, bad indifferent? =A0Flying tail, pros and cons? =A0I am new to gliding, Commercial Add on, 140 flights and approx 100 hours, mostly in 1-34. Would this be a reasonable next step? Walt -- Walt Connelly Yes, but so is pretty much any 15 meter glass ship. If you're looking at a Standard Cirrus, I'm guessing money IS an object. In near the same price range don't rule out Libelles or Jantars. You've read it here many times - the trailer makes a big difference. |
The Cirrus is a very nice ship and transition should not be a problem.
Resting your arm on your leg to keep a steady hand is not a bad idea until you get used to the low stick forces. When you raise the gear you might waggle a bit. A regular tail would be better but the all flying tail is not really an issue. I find it more pleasant to fly than the Jantar. The handling is nice and the cockpit is comfortable. Visibility is also very good. If you get one be sure to check the C.G., in particular if you plan to winch launch. I donīt like the LīHotellier connectors and the little pins but you get used to them. If itīs a pre ī75 model that has a sort of hook that connects elevator control pay close attention during assembly as itīs possible to connect improperly. The newer ones have a different system thatīs more foolproof but with a slight amount of wear in the fittings the tail can get quite wobbly. For assembly it really helps to make the little arm with a stub pin to hold one wing in while inserting the other. I think there is an article in the Standard Cirrus website on this as well as the tail assembly issue. As Grider Pirate says, a good trailer is really important. Another option in almost the same price range is the Pegase and itīs a more modern design. Good luck! Juan Carlos On Mar 17, 10:57*am, Grider Pirate wrote: On Mar 16, 6:55*pm, Walt Connelly Walt.Connelly. wrote: Okay folks, your thoughts on the Standard Cirrus? *Good, bad indifferent? *Flying tail, pros and cons? *I am new to gliding, Commercial Add on, 140 flights and approx 100 hours, mostly in 1-34. Would this be a reasonable next step? Walt -- Walt Connelly Yes, but so is pretty much any 15 meter glass ship. *If you're looking at a Standard Cirrus, I'm guessing money IS an object. *In near the same price range don't rule out Libelles or Jantars. You've read it here many times - the trailer makes a big difference. |
wrote: Okay folks, your thoughts on the Standard Cirrus? *Good, bad indifferent? *Flying tail, pros and cons? *I am new to gliding, Commercial Add on, 140 flights and approx 100 hours, mostly in 1-34. Would this be a reasonable next step? Walt -- Walt Connelly The combination of CG hook and a tail skid or small tail wheel can make takeoffs more demanding in a cross wind than for gliders with nose hooks and decent size tail wheels. It that respect it's probably no different from the ASW 19 that I have many hours in. I have not yet flown either of my club's standard Cirri but I have towed them and been quite alarmed by the lateral excursions seen in my mirrors on takeoff roll. Before attempting a cross wind takeoff suggest you talk to someone that actually knows how position the glider on the runway and how to use the controls. Hint - the glider should be positioned towards the upwind side of the runway and pointed downwind. Full downwind rudder should be applied before moving and held until it becomes effective. The angle to head the glider downwind, and the offset upwind of center line, depend on the magnitude of the crosswind, the width of the runway and the tendency of the glider to weather-vane. This technique allows the full width of the runway to be used twice and the glider glider should be under control and tracking straight before returning to the upwind side of the runway. If it isn't a release is called and the next attempt is made with a bigger lateral offset and/or larger heading downwind. It's not nearly as difficult as the description may make it sound. Some people seem to have a problem holding full downwind rudder when the glider is already heading downwind at the start of takeoff roll but it is essential to maintaining control. Andy |
Very nice glider.
I have had years of fun with mine. Somehow everything else feels heavy on the controls. She will teach you circuit planning and speed control... Lots to love. Early models are a little hot on landing because of low washout. Built like a little tank - hard to damage. The Tost lilliput wheel is a bad joke - zero brakes and tends to get fatigue. There is a disk brake mod. Real performance about 1:35 I have never made 400km, but #57 has 8 flights greater than 500km in the logbook, and there are 1400 hrs on the log... The Kestrel is much more "ladylike", but less fun to fly. It DOES have 1:44 which takes some getting used to. As has been gone over repeatedly - in this class - the trailer is most important, then the airframe condition. Expect to spend money on improving the instruments. Then - Fly the paint off the wings and build some happy memories for when/if you graduate to more performance... -- Bruce Greeff T59D #1771 & Std Cirrus #57 |
| Standard Cirrus C-Hook | Randy[_2_] | Soaring | 26 | September 26th 08 11:24 PM |
| Standard Cirrus Group | Jim Hendrix | Soaring | 0 | May 21st 08 04:15 PM |
| Standard Cirrus | Don Burns | Soaring | 0 | January 10th 07 06:24 AM |
| Standard Cirrus Web Site Move | Jim Hendrix | Soaring | 0 | December 11th 04 04:11 PM |
| F/S - Standard Cirrus 75 | Bob | Soaring | 0 | October 4th 04 01:23 AM |
