We have a Garmin GNS430, UPSAT SL30 NAC/COM and Sandel EHSI. I'd like to
add a second course deviation indicator/GS for when Murphy shows up and the Sandel quits at the worst possible time. A couple questions for the avionics gurus on r.a.o: - How much is this going to cost? There's the cost of the instrument, whatever switches and annunciators are needed, and maybe 8 shop hours for installation and checkout. I'm guessing about $3k for the lot. Is that realistic? Anything else? - Can I switch the indicator between the 430 VOR/LOC/GS and the SL30 NAV inputs? - Is it very difficult/expensive (or worthwhile) to add the GPS deviation info to the second indicator? We have an MX20 to use as a moving map while setting the GNS430 display to CDI mode. Thanks in advance for some free advice. |
MP wrote: We have a Garmin GNS430, UPSAT SL30 NAC/COM and Sandel EHSI. I'd like to add a second course deviation indicator/GS Don't the 430 AND the SL30 have builtin graphical CDIs? Good enough for emergency purposes. If you add a second CDI you should be able to drive it in parallel with the HSI. -- Ben Jackson http://www.ben.com/ |
MP,
I did that in my Tripacer, have a GNS430 and Sandel and KX-125. The backup indicator is a KI-209A. I had a couple of interesting moments because the 209A has a 'localizer' mode that is dependent on a LOCENGAGED low signal that switches the TO/FROM flag to TO. The 430 doesn't really put this out correctly. We got around it by tying it to the GPS/NAV switch. I also had to use the P6 connector of the 430 for my nav output to the 209, through a NAT 8pole relay. So, let's see .... NAT Relay - $160 KI-209A - $895 Switch and Light - $50 Avionics shop time - 3 to 4 hours Redundancy - priceless. Hope that this helps, Rod Wagoner Tucson, AZ MP wrote in message ... We have a Garmin GNS430, UPSAT SL30 NAC/COM and Sandel EHSI. I'd like to add a second course deviation indicator/GS for when Murphy shows up and the Sandel quits at the worst possible time. A couple questions for the avionics gurus on r.a.o: - How much is this going to cost? There's the cost of the instrument, whatever switches and annunciators are needed, and maybe 8 shop hours for installation and checkout. I'm guessing about $3k for the lot. Is that realistic? Anything else? - Can I switch the indicator between the 430 VOR/LOC/GS and the SL30 NAV inputs? - Is it very difficult/expensive (or worthwhile) to add the GPS deviation info to the second indicator? We have an MX20 to use as a moving map while setting the GNS430 display to CDI mode. Thanks in advance for some free advice. |
Thanks for the advice. I was afraid we were going to get locked into the
Garmin (read expensive) indicator. Maybe we can get it done for under $2k, your way. Cool. OBTW, a big AMEN on redundancy. "Tri Pacer Pilot" wrote in message ink.net... MP, I did that in my Tripacer, have a GNS430 and Sandel and KX-125. The backup indicator is a KI-209A. I had a couple of interesting moments because the 209A has a 'localizer' mode that is dependent on a LOCENGAGED low signal that switches the TO/FROM flag to TO. The 430 doesn't really put this out correctly. We got around it by tying it to the GPS/NAV switch. I also had to use the P6 connector of the 430 for my nav output to the 209, through a NAT 8pole relay. So, let's see .... NAT Relay - $160 KI-209A - $895 Switch and Light - $50 Avionics shop time - 3 to 4 hours Redundancy - priceless. Hope that this helps, Rod Wagoner Tucson, AZ MP wrote in message ... We have a Garmin GNS430, UPSAT SL30 NAC/COM and Sandel EHSI. I'd like to add a second course deviation indicator/GS for when Murphy shows up and the Sandel quits at the worst possible time. A couple questions for the avionics gurus on r.a.o: - How much is this going to cost? There's the cost of the instrument, whatever switches and annunciators are needed, and maybe 8 shop hours for installation and checkout. I'm guessing about $3k for the lot. Is that realistic? Anything else? - Can I switch the indicator between the 430 VOR/LOC/GS and the SL30 NAV inputs? - Is it very difficult/expensive (or worthwhile) to add the GPS deviation info to the second indicator? We have an MX20 to use as a moving map while setting the GNS430 display to CDI mode. Thanks in advance for some free advice. |
PACAF’s Hawaii air ops center sets new goals while adding 109 positions | Otis Willie | Military Aviation | 0 | August 20th 03 09:44 PM |
