post vs stick hangar construction
Old October 29th 03, 12:06 AM
Joa
Default post vs stick hangar construction
For anybody that is in construction or that has researched affordable
hangar options....for an insulated steel sided and roofed hangar which
is more affordable to build- post style (pole barn) or traditional
stick (framed walls)?
Our EAA chapter built a traditional stick hangar and insulated between
the studs but a friend here at work built his hangar post style and
just squished the insulation between the cross pieces and the steel.
Ignore the hangar door (will use a sideways folding door on the gable
end).
Thanks.
Joa
Old October 29th 03, 03:38 AM
Blueskies
Pole barn is the way to go here in MI. The stick built version was 2x the cost of the poles....
Dan D.
"Joa" wrote in message om...
end).
Thanks.
Joa
Old October 29th 03, 05:34 AM
Roger Halstead
I built a 28 by 40 foot shop. The floor is high strength concrete with
a rat wall type foundation. (I wish I had gone with a standard
foundation although no problems with the rat wall). We used stick
built,, with one inch styrofoam over the outside covered with vinyl
siding. The inside is barn metal which is what most use on the
outside. The walls are filled with roll insulation while the ceiling
has 16 inches of cellulose blown in. If condensation is not a problem
I'd use the cellulose for insulation although the foam seals "tight".
I also have one inch of styrofoam under the concrete.
The cost (using a contractor) was little different than had I gone
with a pole type construction finished in the same manner.
The only reason I wish I had gone with a conventional foundation which
would not have added more than a couple hundred dollars over the rat
wall is thermal isolation. I'd put a thermal barrier between the
floor and the outside wall/foundation using either half inch bead
board or styrofoam.
Even with the two big doors plus the man door it's quite economical to
heat and I can keep it comfortable with a little window air
conditioner in the hot summer.
The shop is just north of my garage, but I'm based at 3BS (Midland)
which is about 11.3 on the 337 radial from MBS.
The second page of my G-III construction diary has some photos of the
construction at http://www.rogerhalstead.com/glasair2.htm
Roger Halstead (K8RI EN73 & ARRL Life Member)
N833R World's oldest Debonair? (S# CD-2)
Old October 29th 03, 03:25 PM
Jerry Wass
What's a "rat wall" ??
board or styrofoam.
Old October 29th 03, 03:45 PM
Montblack
You the one leaning on the shovel? :-)
What is a rat wall? Or rat wall type foundation?
Your interior looks like some of the hangars on Millionaire Row, out at my
airport, ANE (Anoka-Blaine, MN). White metal on the inside walls, those are
the hangars that have Citations and King Airs in them.
You've measured, and the plane will fit out the door when finished, right?
g
Montblack
"Styled by the laws of nature.............Concorde"
("Roger Halstead" wrote)
snips
Old October 29th 03, 08:15 PM
Roger Halstead
On Wed, 29 Oct 2003 08:45:16 -0600, "Montblack"
What? Me get dirty? Not a chance. Besides it's not greasy enough
No, I'm the guy with little hair in a few farther down the page
working on some lay-ups.
If you look at the photo where the trench just inside the forms is
visible...they pour the floor and then right on over into that trench.
That forms the "rat wall" which is just an extension of the floor. In
my case it's 16 inches down. The reason for a "rat wall" which is a
lot like a shallow foundation is to ...discourage rats from making a
home under the floor which can be a real problem when you only pour a
slab.
Around here a true foundation would have only been about a foot deeper
and required one more course of cement blocks.
That is painted "barn metal" and costs about the same as dry walling
the interior. Actually the barn metal is more expensive, but takes
far less labor to install. It's a whole lot easier on your back too.
:-)) Those sheets weight a fraction of a dry wall sheet.
g
That's going to be an interesting exercise. "THEORETICALLY" if the
landing gear is on dollies, I *should* be able to take it out corner
wise by sticking the tail in one corner next to the door, sliding the
nose out, sliding the whole works forward and then sliding it sideways
to take the tail out.
OTOH, the wing is separate until final assembly and I may do that at
the EAA building at 3BS. I would like to put it together and do the
engine testing before taking it to the airport. That would reduce the
final, final assembly to less than a week. I plan on doing the flight
testing, or at least the initial flight testing with the plane only
primered.
Then again, I have more concerns about being too old to fly it by the
time it's done, compared to getting it out of the shop. sigh
Old October 31st 03, 12:56 AM
Blueskies
I am putting up a 48x48 'hanger' with radiant heat floor. Just now getting to the wiring stage. I've got pictures of the
construction but no where to post them...
Roger, what did you seal/paint the floor with? I need to do that soon before it gets too cold or wait 'till spring...
Dan D.
"Roger Halstead" wrote in message ...
board or styrofoam.
Old October 31st 03, 01:07 AM
Larry Smith
"Blueskies" wrote in message
.com...
Green is me, with envy. Post the pictures in alt.appalachian.binaries,
Dan, then announce here that you've posted them.
Dan D.
Old October 31st 03, 03:50 AM
Roger Halstead
First I pressure washed it, then acid etch followed by another wash.
Gave it 3 days to dry with the heat on, and then gave it three coats
of 2-part epoxy from Lowe's. Other than that I used no sealers.
The Auction Hangar - Completely free aviation auction site. The Auction Hangar Instrument Flight Rules 10 April 19th 04 01:37 AM
The Auction Hangar - Completely free aviation auction site. The Auction Hangar Instrument Flight Rules 0 April 6th 04 01:57 AM
post vs stick hangar construction Joa Home Built 25 November 1st 03 02:03 PM
Re; What do you think? Kelsibutt Naval Aviation 0 September 29th 03 07:55 AM
