It's leaking where the bag is clamped to the PVC pipe just before the
ball valve with the push rod. It's likely original as I bought it with 230 hours in 2008. When I remove the clamps, what will I find for the seal? Is the existing sealant RTV or a gasket? What to use to re-seal it? Will I damage the bag in the area of the clamp due to old dried goop? Thanks, Bruce |
The factory assembled the bag to the pipe using two wraps of tape
similar to medical tape around the pipe to create a pliable surface and to bring the OD of the pipe close to the ID of the bag end (1.5 inch). The bag was fit over this tape then they added two more wraps of tape over the bag end to protect it from the two worm gear hose clamps. My guess is that the leak was caused by years of differing thermal expansion of the PVC pipe versus the stainless steel clamps. Automotive hoses use constant tension clamps to avoid this issue, so I'm going to use this type clamp. The weak link will still be the tape underneath not being pliable enough for the clamps to bite into. It should use a soft rubber (?) sleeve the OD of the pipe, but the wall thickness can only be 1mm. Has anybody solved this problem without RTV goop? |
On Apr 3, 6:25*pm, Barny wrote:
The factory assembled the bag to the pipe using two wraps of tape similar to medical tape around the pipe to create a pliable surface and to bring the OD of the pipe close to the ID of the bag end (1.5 inch). The bag was fit over this tape then they added two more wraps of tape over the bag end to protect it from the two worm gear hose clamps. *My guess is that the leak was caused by years of differing thermal expansion of the PVC pipe versus the stainless steel clamps. Automotive hoses use constant tension clamps to avoid this issue, so I'm going to use this type clamp. *The weak link will still be the tape underneath not being pliable enough for the clamps to bite into. It should use a soft rubber (?) sleeve the OD of the pipe, but the wall thickness can only be 1mm. Has *anybody solved this problem without RTV goop? Why don't you like RTV? It's perfect for this application and what I used to seal the bag to pipe interface of my ASW-19. Andy |
| Thread Tools | |
| Display Modes | |
| Brass Ball Valve,Gas Valve,Needle Valve,Angle Valve,Hose Bibcock Sale on good price | valvetom | Piloting | 0 | November 28th 06 03:25 AM |
| DG-300 water bag valve Q. | [email protected] | Soaring | 1 | February 28th 06 04:20 PM |
| water ballast leak | Robert Harvey | Soaring | 2 | May 27th 05 04:49 PM |
| water ballast leak | Robert Harvey | Soaring | 0 | May 26th 05 11:33 PM |
| WTB: ASW 27A water valve | Peter Van Camp | Soaring | 0 | April 28th 04 11:37 PM |
