I recently acquired a nice Rotax-powered two-seater, but am hard pressed
for storage. So I might well want to store it on a trailer, that I could well build myself. Friends I consulted seemed to take it for granted I begin by welding together a frame of steel profiles, paint it with primer and gloss, then attach an axle and a few other paraphernalia. But why not bolt together a few lengths of aluminium? No need to paint or weld - or is this over simple? |
On Apr 12, 5:27*am, Tom De Moor
wrote: In article , says... I recently acquired a nice Rotax-powered two-seater, but am hard pressed for storage. So I might well want to store it on a trailer, that I could well build myself. Friends I consulted seemed to take it for granted I begin by welding together a frame of steel profiles, paint it with primer and gloss, then attach an axle and a few other paraphernalia. But why not bolt together a few lengths of aluminium? No need to paint or weld - or is this over simple? Firstly: you'll find steel in all sizes/quantity anywhere, aluminium beams in the sizes required nowhere. Secondely: the aluminium beams need to be anodized, a process which in Belgium is very expensif and hard to find due to the impact (of anodizing) on the environnement. Thirdly: your trailer will weigh a minimum of 150 kg regardless of construction material. The cost of raw material Fe compared Al is a factor 30 in favor of steel. For reasons of security (for a trailer) welding has a far better pedigree than bolting: assuming that you will be able to bolt it together, it *will* come loose and that -of course- at the worst moment. The total weight (trailer and your airship) *has* to be under 500 kg in order to not needing brakes nor an insurance premium. The axle will either be solid (no springs) and steel. Better is to go to a breakers yard and get a sprung axle. Peugeot 205 rear axle works great, get the wheels too and throw out the brakes. The other method is to buy a sprung axle at a specialist dealer. Best and cheapest way is to make a welded steel trailer with a PVC or plastic cover. Standard trailers are quite cheap *but don't expect that to be the case if it has to be custom made. Congrats with the 2-seater! * Tom De Moor I have my glider in a steel framed enclosed trailer (.045" thick aluminum skin). It has been tipped over twice. Once in heavy winds, once thanks to inept driving (me). Both times the trailer absorbed the impact and protected the glider inside it. I don't think I would consider anything but steel. |
On 04/22/2011 04:46 PM, Tony wrote:
On Apr 12, 5:27 am, Tom De wrote: In , says... I recently acquired a nice Rotax-powered two-seater, but am hard pressed for storage. So I might well want to store it on a trailer, that I could well build myself. Friends I consulted seemed to take it for granted I begin by welding together a frame of steel profiles, paint it with primer and gloss, then attach an axle and a few other paraphernalia. But why not bolt together a few lengths of aluminium? No need to paint or weld - or is this over simple? ( ... ) I have my glider in a steel framed enclosed trailer (.045" thick aluminum skin). It has been tipped over twice. Once in heavy winds, once thanks to inept driving (me). Both times the trailer absorbed the impact and protected the glider inside it. I don't think I would consider anything but steel. Thank you, Tony. There was no need to convince me, Tom already offered sufficient advice AND hands-down assistance at the design and construction of a steel trailer frame. I am still wondering about covering, though, so I'd be glad to have more details about how you covered yours. Do you have steel uprights too, welded to the trailer frame, to which your alu sheet is riveted? |
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! | flyingmr2 | Soaring | 4 | November 16th 10 02:11 AM |
Trailer tires for old (1981) Komet Trailer | [email protected] | Soaring | 3 | May 13th 09 10:24 PM |
Steel Strapping for Less | sanwan | Home Built | 1 | November 5th 07 04:35 PM |
Steel Axles | Alan & Ruth Glatt | Home Built | 0 | December 13th 05 12:59 AM |
steel 4130 | Philippe Vessaire | Home Built | 4 | October 19th 03 07:19 AM |
