Crank Seal?
Old November 10th 03, 01:57 AM
Mark S Conway
Default Crank Seal?
What would cause a crank seal to leak?
Seal got replaced, and 15 hrs later, started leaking again.
Any thoughts?
Thanks
Old November 10th 03, 02:22 AM
Stu Gotts
Improper installation, dirt, scoring of the surface, misalignment of
the cases.
On Mon, 10 Nov 2003 01:57:28 GMT, "Mark S Conway"
Any thoughts?
Thanks
Old November 10th 03, 03:03 AM
Larry Smith
"Mark S Conway" wrote in message
news:cgCrb.157136$Tr4.422856@attbi_s03...
Any thoughts?
Thanks
I don't know about Lycoming but Continental has an old service letter, iirc,
for lightly sanding the crank where the seal fits with something like 320
grit at about a 30 degree pitch. I've seen it done at 45. Oil is "screwed"
thereby back into the crankcase, as the crank turns. I rebuilt an engine
which had this problem and it leaked copiously around the new seal. The
crank had a little wear and scoring from the old seal, but the tiny "mill"
marks solved the problem. No more leak. This should be done by a pro,
natcherly. And, of course, the pitch must be like your prop's. If it's in
the wrong direction you screw the oil out onto the nose and aggravate the
problem.
Old November 10th 03, 04:29 AM
G.R. Patterson III
Check for a blocked crankcase ventilation tube.
George Patterson
If you're not part of the solution, you can make a lot of money prolonging
the problem.
Turnabout by SEAL Authentication Team Fred the Red Shirt Military Aviation 1 August 22nd 04 06:43 PM
Lyvoming Crank Phil Home Built 0 April 29th 04 01:12 AM
Remove oil seal from vacuum pump adapter on Lycoming IO320 HOW????? Ron Home Built 2 February 24th 04 04:34 PM
Crank it singha_lvr Naval Aviation 1 September 28th 03 09:29 PM
Ford V-6 engine work Corky Scott Home Built 19 August 21st 03 12:04 PM
