2-place Intercom and 4 Headsets
Old November 12th 03, 03:10 PM
Kai Glaesner
Default 2-place Intercom and 4 Headsets
Hello community,
imagine you have a plane (rented) with a build in 2-place intercom
(sigtronics in this case) and want to give your passengers their own
headsets, so you can communicate with them. It is not necessary for them to
hear the radio transmissions you make, although, it would be nice (if legal
What do you need? An additional portable 2-place intercom? A Y-cable
extension?
Thanks in advance for your answers.
Regards
Kai Glaesner
Old November 12th 03, 03:44 PM
John T
"Kai Glaesner" wrote in message
extension?
I purchased a 4-place portable intercom for this type of scenario.
John T
http://tknowlogy.com/tknoFlyer
__________
Ron Natalie
"Kai Glaesner" wrote in message ...
extension?
I have a 4-place sigtroncs portable that I used a lot. It seemed to work fine
cascaded into the copilots mic/phone jack.
Old November 12th 03, 04:13 PM
Kai Glaesner
Ron,
fine
So I guess you connected your headset to the pilots jack, and copilots and
passengers to the portable?
Old November 12th 03, 04:29 PM
Ron Natalie
Nope, I plugged all the headsets into the intercom. The only reason I used
the copilots side is to keep the mess of cords out of my way. I used a
portable PTT connected to PTT in on the intercom.... you may have to investigate
whether this will work on your plane. On some planes I did this with I used
the hand mike in.
Old November 12th 03, 05:12 PM
John T
copilots and passengers to the portable?
I've found that it's much better to have all headsets plugged into the same
intercom system. Otherwise you may find that your passengers can hear you,
but you might not hear them.
John T
__________
Old November 12th 03, 05:16 PM
Kai Glaesner
John,
same
you,
I guess if I connect the portable to the pilot's jack and press the planes's
build in PTT you can hear the whole group chatting while transmitting?
Old November 12th 03, 05:19 PM
John T
planes's build in PTT you can hear the whole group chatting while
transmitting?
Haven't tried it, but to prevent it from happening, I use my own PTT.
John T
__________
Old November 12th 03, 05:36 PM
Ron Natalie
Depends on the intercom. I believe that on some if you don't use the PTT
on the intercom itself, only the pilots mic goes thorugh (using their "fail safe" mode).
Old November 13th 03, 08:14 AM
Thomas Borchert
Kai,
no. You connect the 4-place to the pilot side connectors and switch off
the installed intercom. See www.ps-engineering.com and look for the
manual of their Aerocom III. It's all described in detail, including
use of an installed PTT switch.
Thomas Borchert (EDDH)
FS: Soft Comm ATC-4Y 4 place portable intercom Jaysen Underhill General Aviation 0 December 11th 03 09:42 PM
FS: Soft Comm ATC-4Y 4 place portable intercom Jaysen Underhill Aviation Marketplace 0 December 11th 03 09:41 PM
FS: Soft Comm ATC-4Y 4 place portable intercom Jaysen Underhill Instrument Flight Rules 0 December 11th 03 09:41 PM
FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 Jaysen Underhill Aviation Marketplace 1 October 17th 03 02:04 AM
FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 Jaysen Underhill General Aviation 0 September 4th 03 04:41 AM
