I'm building an all wood airplane. The skin is 1/32, 1/16 & 1/8 plywood. Do the
scarf joints that are required to join the plywood together need to fall on the underlying structure or can they be located where the plywood spans the structural members? Thanks! David |
In my All wooden project the designer has the scarf joints located on
the underlying structural members. Infact, the underlying members have extra spruce laminated to the sides of them to support a greater width of the joint. After building the craft I think it would be difficult, especially with the thinner materials to get a nice transition if the joint were "floating" Structurally I don't see a problem as long as the joint is well constructed. You may want to take a deeper look into your plans and see it they reccomend locations for the scarf joints. Orval Fairbairn wrote in message .. . In article , (Flyhighdave) wrote: I'm building an all wood airplane. The skin is 1/32, 1/16 & 1/8 plywood. Do the scarf joints that are required to join the plywood together need to fall on the underlying structure or can they be located where the plywood spans the structural members? Thanks! David Check Manual 18. Scarf joints can be anywhere == as long as they are of the required angle (12:1 minimum) and are properly glued (good compression along the length of the joint). |
