End of Autogas?
Old November 21st 03, 03:44 PM
David Lesher
Default End of Autogas?
The GOP's energy bill will require ethenol in gasoline, apparently
even in areas that do not have smog issues.
Is this the end of autogas?
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old November 21st 03, 11:34 PM
Doug
At the nearby airport where we can buy mogas, the owner gets 91 octane
from a local supplier BEFORE any auto additives are added. I assume he
will be able to continue to do so. Although I own stock in Exxon, I
think this energy bill is the worst legislation I have ever seen come
out of Congress, and I hope if it passes in it's present form that
Bush vetoes it (I doubt he will as it is supported by many of the oil
companies). The alchohol requirement is only part of the bad things.
Where are the liberal, soak the rich, penalize the oil companies
LIBERALS when you need them? (many liberals voted for it).
David Lesher wrote in message ...
Old November 22nd 03, 12:57 AM
Alexi
"Doug" wrote in message
om...
Kind of funny how the Bush/Cheney supporters stop sucking up real quick when
the legistration affects their own little world.
Don't like paying a little extra for avgas to support your FBO?
Autogas should be renendered useless for aviation use, illegal even. Maybe
someday we'll get clean hydrogen running engines that will eliminate the
need for burning petro.
Would have had themt a long time ago if it wasn't for the special interest
lobbies and the Cheney/Bush types!
Alexi
Old November 22nd 03, 01:48 AM
Alexi
The question to which I have yet to hear an answer from the hydrogen
advocates is, since it takes more energy to produce hydrogen than you
can get from burning it, where do you get the energy to produce the
hydrogen in the first place? Reactors on every corner? Yeah, that will
be real popular.
Alcohol has the same problem plus there not being enough land in the US
to produce enough to replace gasoline. So we replace Saudi oil with
Mexican and Argentinian corn and put a reactor on every corner?
As for being clean, any engine that uses air to supply the oxidizer
produces oxides of nitrogen no matter what the fuel.
Jim Pennino
Remove -spam-sux to reply.
Old November 22nd 03, 03:59 AM
Javier Henderson
"Alexi" writes:
Wow.
Me, I prefer autogas because the engine in my Skylane won't foul
plugs on it.
As for supporting the FBO at my home base, his pricing practices
leave much to be desired, so ...
-jav
Old November 22nd 03, 05:10 AM
C J Campbell
"Alexi" wrote in message
Since the ethanol rider was attached by Daschle as a sop to his constituency
(Archer-Daschle-Midland, or something like that), I fail to see how you can
blame this on Cheney/Bush special interests. This is a Daschle special
interest, pure and simple.
Old November 22nd 03, 06:16 AM
Peter Gottlieb
I condemn the whole lot of them.
"C J Campbell" wrote in message
constituency
can
Old November 22nd 03, 05:06 AM
C J Campbell
"David Lesher" wrote in message
This requirement was a rider attached by Daschle. The GOP accepted it or the
bill would have been filibustered like all of Bush's judicial appointments.
So, the GOP is condemned for not compromising, then condemned for accepting
a compromise.
Old November 22nd 03, 09:10 PM
Doug
The bill is PORK. And it has a LOT of pork for a lot of constituents.
Both parties are to blame here. It is just plain a bad piece of
legislation.
"C J Campbell" wrote in message ...
a compromise.
Old November 24th 03, 07:38 PM
Michael Houghton
Howdy!
*ahem*
....like four of the most contentious appointments (as opposed to the one
hundred sixty eight (IIRC) that have been approved).
Hardly "all".
Bad radical. No biscuit.
a compromise.
Eh? You make no sense.
yours,
Michael
Michael and MJ Houghton | Herveus d'Ormonde and Megan O'Donnelly
| White Wolf and the Phoenix
Bowie, MD, USA | Tablet and Inkle bands, and other stuff
http://www.radix.net/~herveus/
Autogas and high end engines John Skorczewski Home Built 10 August 17th 04 06:19 PM
Hi Octane Autogas UltraJohn Home Built 24 April 18th 04 03:43 AM
Objective Engine Discussion Rick Maddy Home Built 26 October 14th 03 05:46 AM
Hot weather and autogas? Rich S. Home Built 33 July 31st 03 12:25 AM
New autogas rules in the US Roger Halstead Owning 0 July 14th 03 09:37 PM
