Sundowner Wing Flaps
Old November 30th 03, 04:57 PM
A Lieberman
Default Sundowner Wing Flaps
..... dont retract "on their own".
Beech Sundowner.
I will be talking to my A&P tomorrow, but just curious if anybody knows
whether I am talking major expense or something simple like a spring
that pulls the flaps up that came loose in the innards of the wings.
A gentle nudge on the outside and they go up. No rubbing or noises
noted.
Allen
Old November 30th 03, 05:47 PM
Jim Besselman
The flaps on my Sundowner behave the same way and have ever since I've owned
the plane. I had the A & P that did my prebuy check it out and could find
nothing wrong. I also found an entry in an old squawk booklet that noted the
problem. The maintenance responce was that this was "Normal". The air
movement from the prop is sufficient for them to retract. I am interested in
what your A & P says.
"A Lieberman" wrote in message
Beech Sundowner.
noted.
Allen
Old November 30th 03, 07:18 PM
BTIZ
interesting... this is I presume with the flap lever in the "extended and
locked position".. I've flown Sports and Sundowners and never had this
problem.. I "expect" that it is very much the same mechanism on various
Piper models to include the Twin Seneca.
now.. this type of flap can "extend" based on pressure applied externally
(tail wind, hand pressure) and when the props starts fanning the wings.. the
new air pressure is enough to cause a retract..
is there an "air load" on the flaps lock in flight to keep them from self
retracting?
BT
"Jim Besselman" wrote in message
owned
in
Beech Sundowner.
noted.
Allen
Old November 30th 03, 09:43 PM
A Lieberman
locked position"..
HI BTIZ,
Yes, I pull the lever up, and the flaps go down. I put the lever down
to retract the flaps, and they stay down. "Operationally, extending the
flaps feels perfectly normal. When I retract in increments, it feels
normal from the feel of the flap handle (I can feel the indents /
increments.
retracting?
I never thought of this, but you raise a good question. What actually
does prevent the flaps from retracting while in flight? When I have the
handle at each increment, the flaps are solidly locked in place. When I
put the handle in the retracted position, a gently nudge retracts the
flaps.
From the personal replies in my email, everything is pointing to a
lubrication fix. (I sure hope so anyway!) as this apparently is a
problem that has been experienced by other Sundowner owners. I will
post the results when the A&P gets to the plane (hopefully tomorrow!).
Allen
Old November 30th 03, 10:44 PM
BTIZ
and
locked position"..
HI BTIZ,
if you are at Ground speed zero.. on the ground.. no engine running.. than
that is perfectly normal.. just a little "drag" in the mechanism somewhere
that holds them in the down postion.
The flap lever, extends the flaps.. and it releases the flaps to either
retract or reduce to a lower flap setting.. the prop wash is enough to get
the flaps up.. the flaps are not mechanically connected to an "up lever", it
only holds and locks them down.. does that make sense.
Air loads in flight push against the "down stops" so the flap is more
responsive to the flap lever.
There are two reasons why the flaps are marked "No Step", one is they may
not support weight without being damaged, the second, if in the up position,
they may go to the down position when you step on them. (floor falling out
from under you) (trap door)
If the mechanic has looked and said they are ok.. I tend to agree.. I am not
a mechanic.
BT
Old December 1st 03, 06:35 PM
Dave Butler
a mechanic.
I likewise am not a mechanic. I have owned a Cherokee whose flaps behaved in the
same way, and I was told it was not a problem. It's only annoying on the ramp
after you complete your preflight check and want to retract the flaps.
Occasionally if I put the flap handle in the fully retracted position, after
several seconds or minutes the springs would suddenly overcome the friction that
was holding the flaps extended, and the flaps would retract with a loud bang.
Scares the *%&@$ out of you, and can't be good for the flap mechanism.
Dave
Remove SHIRT to reply directly.
Old December 3rd 03, 10:18 PM
Javier Gorordo
Just curious...What makes you think is the prop wash and not the
vibration of the engine?
Javier
[Not an A&P, haven't flown Sundowners in over 15 yrs]
"BTIZ" wrote in message news:ipuyb.333$yf.222@fed1read01...
SNIP
the flaps up..
UNSNIP
BT
Old December 2nd 03, 03:46 AM
A Lieberman
Update on flap situation
A&P lubed all moving parts and up they go on command. A&P said that no
prop wash should be needed to raise flaps. Problem solved.
Thanks to all that posted and emailed me privately!
Allen
Old December 4th 03, 12:03 AM
John Roncallo
Our club's Piper occasionally does this. I was told this is normal but
personally I believe that is BS. But I'm not an A&P I'm only an
Aerospace Engineer so what would I know. My guess without taking the
system apart is that this is a worn linkage allowing some bellcrack to
go over center at full extension. Will the air loads retract the flap?
Probably. Is this the mechanism the engineer had in mind for flap
retraction when it was designed? I doubt it.
John Roncallo
I read an article one time about pilot squawks and A&P responses. My
favorite one goes like this.
Pilot: Prop #3 seeping oil
Mechanic: Oil seepage is normal
Pilot: Props #1, 2, 4 lack normal seepage.
John Roncallo
Old December 2nd 03, 01:20 PM
Nathan Young
A Lieberman wrote in message ...
Beech Sundowner.
noted.
I have found that a strong tailwind while doing a preflight will keep
my flaps down after the handle has been released. This is on a PA28.
Running the engine up will provide enough 'headwind' to release the
flaps.
-Nathan
757 flaps miss-aligned in cruise AnyBody43 General Aviation 1 April 2nd 04 01:01 AM
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell Otis Willie Military Aviation 0 March 18th 04 08:40 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 02:33 AM
Wing Extensions Jay Home Built 22 July 27th 03 12:23 PM
