Hi All,
The charity I help out with (http://www.freedomswings.ca/fw/ -- we provide Inspiration Flights and training in the disabled community) has come into possession of various PDA/PNA parts. I've gotten everything together and working except for an iPaq rz1710 and Cambridge Model 10. I figure I just need a cable to connect the C-10 into the port on the iPaq... anyone have one, cheap/free? We also need to figure out if the C-10 is working -- the boss is handling that. I didn't see anything that looked like the LCD display -- will the combination work without this? Any help would be appreciated. Thanks! John |
Hi John,
The GPS-NAV LCD Navigation display is not required, but it is highly recommended. It makes navigation easy and is a nice and reliable backup to a PDA (PDAs require careful care and feeding to work properly). You can still buy the LCD displays he http://www.cumulus-soaring.com/cai_prices.htm#CAF-013x According to the HP "Quickspecs" page for the rz1710 (see link below), the unit has full RS-232 support through its power/data connector. Therefore a standard Goddard I38C-x cable would work great for connecting it to the Cambridge GPS-NAV's DB-9 serial port. http://h18000.www1.hp.com/products/q.../11969_na.html http://www.cumulus-soaring.com/goddard.htm#I38C-x I'm sorry, but I don't have any used LCD displays or I38C cables. Best Regards, Paul Remde Cumulus Soaring, Inc. "jsbrake" wrote in message ... Hi All, The charity I help out with (http://www.freedomswings.ca/fw/ -- we provide Inspiration Flights and training in the disabled community) has come into possession of various PDA/PNA parts. I've gotten everything together and working except for an iPaq rz1710 and Cambridge Model 10. I figure I just need a cable to connect the C-10 into the port on the iPaq... anyone have one, cheap/free? We also need to figure out if the C-10 is working -- the boss is handling that. I didn't see anything that looked like the LCD display -- will the combination work without this? Any help would be appreciated. Thanks! John |
Thanks, Paul.
I'll have to talk with the boss about making any purchases. That, and we still need to figure out if the GPS-Nav is working (I've got the iPaq running). Cheers! -John |
Power up the C-10 (12vdc)
Plug a serial cable into the C-10 serial port (DB-9 to DB-9) You may need a NULL Modem too Any "terminal" (e.g. hyperterm on Windows) program should see the NEMA data. I don't have my manual handy but I think the serial configuration is 4800,8,N,1 If it is not streaming, try 9600 baud with/without the NULL modem. It is a pretty simple device so it usually "just works". Old versions of GLideNav II work well with it. |
Hi,
There is a minor bug in that suggestion. The Cambridge GPS-NAV doesn't start sending GPS data out the DB-9 port until the PDA software requests the start of the transmission of the data. However, the date is always sent out the RJ (data to L-NAV) cable without any request for the start of data. Best Regards, Paul Remde Cumulus Soaring, Inc. "Todd" wrote in message ... Power up the C-10 (12vdc) Plug a serial cable into the C-10 serial port (DB-9 to DB-9) You may need a NULL Modem too Any "terminal" (e.g. hyperterm on Windows) program should see the NEMA data. I don't have my manual handy but I think the serial configuration is 4800,8,N,1 If it is not streaming, try 9600 baud with/without the NULL modem. It is a pretty simple device so it usually "just works". Old versions of GLideNav II work well with it. |
| Thread Tools | |
| Display Modes | |
| Cambridge GPS NAV Model 20 with S NAV | Leigh | Soaring | 0 | March 21st 08 08:58 PM |
| Cambridge Model 20 to OLC | Bubba | Soaring | 6 | June 22nd 06 09:45 PM |
| older aviation model kits | Gasoline Alley Antiques | Rotorcraft | 0 | May 15th 06 02:22 AM |
| Buy -- Model 20 Cambridge GPS | John Murphy | Soaring | 0 | March 24th 05 03:32 AM |
| Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 | Nathan Whelchel | Soaring | 4 | July 6th 04 12:22 AM |
