Does anyone have any figures and references for about what ratio lift is
produced by Newton's Laws and Bernoulli's Laws? I appreciate this is not a static figure - but say a yer average C-172, or perhaps a 737. I would hazard a semi-educated guess that lift is *primarily* produced by angle of attack (or deflection if you like) - Newton's Laws - and by a much lesser degree by Bernoulli's Law. I would guess that Bernoulli's principle might create 20% of the lift a wing generates. A friend believes it would be much lesser - about 5%. -- Duncan. |
Dave Doe wrote: Does anyone have any figures and references for about what ratio lift is produced by Newton's Laws and Bernoulli's Laws? I appreciate this is not a static figure - but say a yer average C-172, or perhaps a 737. I would hazard a semi-educated guess that lift is *primarily* produced by angle of attack (or deflection if you like) - Newton's Laws - and by a much lesser degree by Bernoulli's Law. I would guess that Bernoulli's principle might create 20% of the lift a wing generates. A friend believes it would be much lesser - about 5%. Newton and Bernoulli approach the idea of lift generation from two different perspectives -- both correct. Newton's laws explain lift as an exchange of energy and momentum -- a craft flying through the air imparts some of its momentum to the vertical axis, which manifests itself as "lift." Bernoulli explains the fluid mechanics of lift generation via pressure distribution, to create "lift." Newton explains why we get a downdraft as a plane flies overhead. |
On 2011-05-23, Dave Doe wrote:
Thanks for the reply - looking for numbers, not the physics behind it. IE looking for the percentage of lift obtained by each - and as I said, although this is variable dependent no doubt on the plane and the airspeed - just trying to get a rough idea (hence, say a C-172 or a 737). 100% is produced by Newton's laws. 100% is produced by Bernoulli's principles. The laws of physics are not additive with "x% produced by Newton and y% by Bernouilli", they are complementary. They are merely looking at the same phenomenon - lift - from different perspectives. Also, note that if you hear "the air travels faster over the curved surface of the top of the wing so it meets the air going underneath at the same time", this is wrong. The transit times are not equal, air going over the top of the wing gets accelerated and arrives at the trailing edge _before_ the air that goes underneath. |
Dave Doe writes:
Does anyone have any figures and references for about what ratio lift is produced by Newton's Laws and Bernoulli's Laws? All lift is produced by Newton's third law of motion. Air is forced downwards by the wings, and this produces an equal and opposite force that attempts to raise the wings, and that is lift. How the air is forced downwards is irrelevant, as long as it happens. In practice, principles discovered by Bernoulli and others play a role in diverting the air flow when this is accomplished by an airfoil. |
In article , er, Private
says... "Dave Doe" wrote in message ... In article , , Mxsmanic says... Dave Doe writes: Does anyone have any figures and references for about what ratio lift is produced by Newton's Laws and Bernoulli's Laws? All lift is produced by Newton's third law of motion. Air is forced downwards by the wings, and this produces an equal and opposite force that attempts to raise the wings, and that is lift. How the air is forced downwards is irrelevant, as long as it happens. In practice, principles discovered by Bernoulli and others play a role in diverting the air flow when this is accomplished by an airfoil. As said in other reply - not looking for a run-down on the physics - looking for the *ratio* of lift obtained by each. -- Duncan. Simple answer, there is no "ratio" - Newton 100% + Bernoulli 100%, total = 100% So a wing generates as much lift upside down? What I want, is half the difference between a wing up the right way, and the wing up the wrong way. That is, I presume, the additional lifting force from the Bernoulli effect vs a wing with a mirrored camber (obtaining no lift due to the Bernoulli effect). It really is a "chicken or egg" question. Google "Newton vs. Bernoulli" and "Newton vs. Bernoulli" NASA Perhaps it is. I have googled. I recommend http://www.grc.nasa.gov/WWW/K-12/airplane/bernnew.html Been there. and much more http://www.grc.nasa.gov/WWW/K-12/airplane/short.html And there. When done you can also work (troll?) on other important old disputes regarding - high wing vs. low wing, track up vs. north up, and slip vs. crab with a kick. Happy landings, Not interested in trolling. If you think I am, please do not reply, or reply and say so, and I will do as such. -- Duncan. |
On 5/23/2011 3:40 AM, Dave Doe wrote:
Simple answer, there is no "ratio" - Newton 100% + Bernoulli 100%, total = 100% So a wing generates as much lift upside down? For an aircraft flying level, at the same speeds, upright and inverted, the wings produce IDENTICAL lift. To do this, the inverted airfoil needs a higher angle of attack usually. You are really dragging out all the old causes for disagreement: I can see why you would be using a pseudonym Brian W |
Three take offs = three landings at Newton MS and Madison MS - Video | [email protected] | Piloting | 39 | November 28th 09 01:22 AM |
How can the Magnus effect be explained with Bernoulli? | Mikki | Piloting | 4 | June 24th 09 05:51 AM |
Lift-to-Drag Ratio? | Toks Desalu | Home Built | 6 | November 23rd 03 10:53 PM |
The bernoulli theory of starting a long thread | David CL Francis | Piloting | 7 | October 26th 03 07:40 PM |
worked fairly well - the German 37mm and British 40mm, frank mitch newton on Stukas | fmn2 | Naval Aviation | 1 | August 10th 03 02:14 AM |
