My last few flights have been with Oudie only and when uploading to
the OLC the IGC validation has failed. I also had a format issue with my last flight and had to send it to the OLC help email. The response I got said "I fixed the file, but it has no signature at the end, so it will be invalid anyway. The contents stops with weird b-record, hours of the preceeding b-records, therefore it could not be parsed by the program." This may have been because the flight ended abruptly when the battery on the Oudie died mid thermal. Although my flight the day before was also invalid. Anyone seen this before? Suggestions? The flights: http://www.onlinecontest.org/olc-2.0...htId=956800845 http://www.onlinecontest.org/olc-2.0...tId=1097355504 |
Hi Tony,
Be sure to exit SeeYou Mobile when done flying. It saves the flight log and adds the security data to the end of the file when you exit SeeYou Mobile. To exit SeeYou Mobile, go to Menu Next Exit. Best Regards, Paul Remde Cumulus Soaring, Inc. "Tony" wrote in message ... My last few flights have been with Oudie only and when uploading to the OLC the IGC validation has failed. I also had a format issue with my last flight and had to send it to the OLC help email. The response I got said "I fixed the file, but it has no signature at the end, so it will be invalid anyway. The contents stops with weird b-record, hours of the preceeding b-records, therefore it could not be parsed by the program." This may have been because the flight ended abruptly when the battery on the Oudie died mid thermal. Although my flight the day before was also invalid. Anyone seen this before? Suggestions? The flights: http://www.onlinecontest.org/olc-2.0...htId=956800845 http://www.onlinecontest.org/olc-2.0...tId=1097355504 |
On May 30, 11:19*pm, "Paul Remde" wrote:
Hi Tony, Be sure to exit SeeYou Mobile when done flying. *It saves the flight log and adds the security data to the end of the file when you exit SeeYou Mobile.. To exit SeeYou Mobile, go to Menu Next Exit. Best Regards, Paul Remde Cumulus Soaring, Inc. "Tony" wrote in message ... My last few flights have been with Oudie only and when uploading to the OLC the IGC validation has failed. *I also had a format issue with my last flight and had to send it to the OLC help email. The response I got said "I fixed the file, but it has no signature at the end, so it will be invalid anyway. The contents stops with weird b-record, hours of the preceeding b-records, therefore it could not be parsed by the program." *This may have been because the flight ended abruptly when the battery on the Oudie died mid thermal. *Although my flight the day before was also invalid. *Anyone seen this before? Suggestions? The flights: http://www.onlinecontest.org/olc-2.0....html?flightId... http://www.onlinecontest.org/olc-2.0....html?flightId... ah ha. pretty sure after the flight on saturday i just turned the oudie off. on the other flight the battery died mid flight. that explains it, thanks paul! |
| Valid OLC log out of SN-10b | Jim Archer | Soaring | 4 | June 12th 08 12:46 AM |
| Valid OLC log out of SN-10b | Jim Archer | Soaring | 0 | June 11th 08 07:43 AM |
| LX20-Secret Key Not Valid! | Ken Ward | Soaring | 6 | April 29th 06 09:22 PM |
| Enroute charts valid for use in Canada? | Andrew Sarangan | Instrument Flight Rules | 3 | June 3rd 04 07:34 PM |
| Airworthiness Cert Still Valid? | Carl Orton | Owning | 12 | February 13th 04 11:21 PM |
