New Airport Ordinance?
Old June 5th 11, 05:07 PM posted to rec.aviation.soaring
Gary Boggs
Default New Airport Ordinance?
The authorities that govern our airport have adopted this new
ordinance regulating activity here. What do you think?
http://www.portofhoodriver.com/airpo...nance%2023.php
I have filed a complaint with the FAA. We will see what they think
soon.
Boggs
Old June 5th 11, 05:22 PM posted to rec.aviation.soaring
vaughn[_3_]
"GARY BOGGS" wrote in message
soon.
Among other issues: Did they really mean to prohibit self-launching motor
gliders?
"e. Only a tow plane shall be used to launch a Glider, unless the Glider pilot
has written permission from the Port, or is permitted by the terms of a
Concession Agreement, to do so."
Vaughn
Old June 5th 11, 05:31 PM posted to rec.aviation.soaring
Gary Boggs
I am encouraging any and all pilots to join me in filing complaints
with the FAA. Please send your thoughts to:
Or:
Boggs
Old June 5th 11, 05:39 PM posted to rec.aviation.soaring
Gary Boggs
When I asked the port what authority they had to enact these new laws
this was their response:
http://www.youtube.com/watch?v=ua5W90FQSGk
Boggs
Old June 6th 11, 12:28 AM posted to rec.aviation.soaring
SF
ordinance regulating activity here. *What do you think?
I have filed a complaint with the FAA. *We will see what they think
soon.
Boggs
What did you guys do to work them up enough to write all this up?
Someone had to be pretty mad at you guys to go to this much effort to
exert this level of control.
Old June 6th 11, 04:15 AM posted to rec.aviation.soaring
Larry Goddard
"SF" wrote in message
soon.
Boggs
IMHO, not necessarily... Remember "There is no kingdom so small that
someone doesn't want to rule it with an iron fist."
Larry
"Zero One"
Old June 6th 11, 04:39 PM posted to rec.aviation.soaring
mgh3485
In Section 27 they claim that an FAA request was behind their action,
and then go on to declare this to be an "emergency" situation (which I
assume allowed for immediate enactment without comment or waiting
periods).
It states: "Because it is important to reduce risks of harm to persons
and property associated with Airport use as soon as possible due to
increasing Airport use in spring and summer, and because the FAA has
requested the Port to enact an ordinance regulating certain Airport
activities, therefore, an emergency is declared to exist. This
Ordinance shall take effect immediately upon passage."
It would be interesting to see exactly what the FAA requested
(assuming such a request exists).
Also, having never been there to see what operations used to be like,
it is hard to tell how limiting these new restrictions are. Were you
doing vehicle tow launches? Were you leaving gliders tied down in
restricted areas for more than 20 minutes as a matter of practice?
How will this change your operations?
Mike
Old June 6th 11, 05:01 PM posted to rec.aviation.soaring
Gary Boggs
We have been staging on the SE corner of the airport, about 80ft from
the edge of the runway. We have a perfect safety record and we blend
very well with the small amount of power traffic that we share our
public airport with. The main reason for whatever action the FAA
might have called for is that a grass runway was put in between the
main runway and the taxi way on the north side of the runway. The
port is now requiring the gliders to stage more than 1000ft up the
3000ft runway, which will greatly lower our margins for safety on
takeoff. We will either have to back taxi 1000+ feet back down the
only runway for every flight, tying up the active runway. or leave
1000 feet of runway behind us. Neither option is as good as the way
we have been safely operating for decades now. The requirement that
only one aircraft at a time is allowed on the taxi ways will be very
interesting during our fly-ins when many dozens of aircraft will want
to depart at the same time.
Boggs
Old June 8th 11, 07:22 AM posted to rec.aviation.soaring
Did you, perchance, let a large gopher snake loose in the airport
commission meeting?
Hemet Airport: FAA Ruling Supports Soaring Right of Airport Access HoUdino Soaring 21 February 20th 11 01:44 AM
...and the #1 stupid Dallas city ordinance is: Dallas Piloting 35 April 21st 07 02:40 PM
JAX Ordinance News? Dan Horton Home Built 1 November 7th 06 11:02 AM
Anyone have an airport diagram for Toronto Center City airport? Peter R. Piloting 10 November 19th 04 01:26 AM
Airport Radial/Distance/Fix on Jepp Airport Chart Dave Johnson Instrument Flight Rules 9 May 2nd 04 11:03 PM
