I made it back
Old June 6th 11, 06:55 PM posted to rec.aviation.soaring
Tony[_5_]
Default I made it back
Somewhat revolutionary (for me), I actually returned to my point of
takeoff yesterday after a good cross country flight. I took the new-
ish to me NG-1 (a modified BG-12/16) out for a 300 km FAI triangle.
Had a good time, finished the task, and didn't need a retrieve. I can
see why you guys like more L's and fewer D's. Check out the final
glide. Flight report he http://soaringcafe.com/2011/06/diamond-goal/
Old June 6th 11, 09:20 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
takeoff yesterday after a good cross country flight. *I took the new-
Had a good time, finished the task, and didn't need a retrieve. *I can
see why you guys like more L's and fewer D's. *Check out the final
glide. Flight report hehttp://soaringcafe.com/2011/06/diamond-goal/
Good on you, Tony! I believe NG-1 was built by Jerry Nedouer, we tried
for our Diamond distance flights on the same day back in 1976? From
Minden to somewhere in the Owens Valley to Hawthorne. Jerry mad it and
completed his Diamond badge. I landed short in my Duster, .......... L/
D is a relative thing.
Cheers,
JJ
Old June 6th 11, 09:48 PM posted to rec.aviation.soaring
Tony[_5_]
Cheers,
JJ
JJ - yes, Jerome Niedrauer. His son Eric is still flying the Pik 20
they bought to replace the NG-1. He'll be in Wichita this fall to see
the old bird. I'll look in the logs for his diamond distance flight.
I'm pretty sure he did all his diamonds in the glider.
Old June 6th 11, 09:27 PM posted to rec.aviation.soaring
BruceGreeff
Indeed
Efficiency is addictive.
Moved from Bergfalke 2-55 (1:26) to Std Cirrus (1:37) to Kestrel 19 (1:44)
The low L/D number is not the main constraint - the speed means there
are a whole new world of tasks that become possible.
Welcome to the dark side.
Getting home is sometimes less adventurous and probably less fun, but is
a whole lot more compatible with family and commitments...
So far I am scoring more than 3 to 1 on the number of times I have
fetched outlanders, vs times I have needed to be fetched. Probably
means I'm not trying hard enough.
Bruce
Bruce Greeff
T59D #1771
Old June 6th 11, 10:16 PM posted to rec.aviation.soaring
Tony[_5_]
On Jun 6, 3:27*pm, BruceGreeff wrote:
Indeed
fetched outlanders, vs times I have needed to be fetched. *Probably
Bruce
Bruce Greeff
T59D #1771
this was my first soaring flight of the year that didn't result in a
landout. of course it was only my 4th soaring flight of the year. I
still flew about as slow on this flight as I did on my almost 300 km
out/return in the Cherokee last year. Most of that was on the upwind
leg, i was super conservative as I've learned over the years that its
hard to make progress on a task if you are sitting in a field.
Old June 8th 11, 12:34 AM posted to rec.aviation.soaring
Gary[_5_]
Indeed
Bruce
Bruce Greeff
T59D #1771
landout. of course it was only my 4th soaring flight of the year. *I
out/return in the Cherokee last year. *Most of that was on the upwind
hard to make progress on a task if you are sitting in a field.- Hide quoted text -
- Show quoted text -
Tony, for some reason I thought you did your 300k last year....am I
thinking of a near miss? Bruce is right; it's the speed.
Gary Adams GA2
Old June 8th 11, 03:08 AM posted to rec.aviation.soaring
Tony[_5_]
Gary,
Last year I did an out and almost return Diamond Goal attempt in the
Cherokee. The write up for that one is on my Cherokee II blog as well
as Soaring Cafe. Total distance on that one was a touch over 300 km
but i ended up landing 4 miles short of the starting airport at 7:30
PM. That one was a 6.5 hr flight, about the same as Sunday.
http://www.onlinecontest.org/olc-2.0...tId=1688698192
I also did a 300 km straight out flight last year for Gold Distance
http://www.onlinecontest.org/olc-2.0...tId=1618688367
Interestingly the speed I made in the Cherokee on the out and return
was about the same as I made in the NG-1 on Sunday. I bet if I was in
a Nimbus I could still average 30 mph!
Old June 8th 11, 07:22 AM posted to rec.aviation.soaring
BruceGreeff
Hey Tony
My first 300km flight in my Cirrus I averaged below stall speed....
One of my difficulties moving from the plywood overcast was the much
greater variation in speeds. Wood and fabric ships often have a very
small drag bucket because of the airfoil and construction. So you fly
between thermals at a speed not that vastly different from your thermal
speed.
Then you get into something with very laminar wings and flaps and cruise
speed is anything up to 3x stall. Kestrel has about the same handicap as
a Ventus. Stall is 32.5kt - full of water at max wingloading and with
thermals in the 4-5m/s range my flight computer is indicating 90kt
cruise. That is a bit optimistic but not that much.
The ASG29/Ventus2/JS1 crowd disdain to fly slower than 110kt (200km/h)
between thermals most of the time...
Consequently I'm still waaay too slow in the Kestrel. It just feels
wrong to cruise at 80kt. But that is her sweet spot for most of our
conditions.
Even in our winter conditions the efficient cruise speed makes long
flights possible. Get it wrong and the retrieves are correspondingly
long. Personal record is 126km...
All I can say is thanks for GPS - at least you can get people to find
you down some obscure farm road in the middle of nowhere.
That said, there is no difference in the fun you can have at any given
performance level - it is just the distance you can cover , places you
can reach that changes. (and the cost, never forget the cost)
On 2011/06/08 04:08 AM, Tony wrote:
Gary,
Bruce Greeff
T59D #1771 & Std Cirrus #57
2, People know that Swiss made watches are best, while the Asia madeare worst but cheapest, but Some of Asia made Oyster Perpetual Air King - AllStainless Steel are also close to a real thing that is in fact almostimpossible to tell the difference. [email protected] Piloting 0 April 26th 08 07:49 PM
Blue Angels back in Pensacola - practice session - Diamond heading back to the hangar Pensacola Beachcomber Aviation Photos 0 March 23rd 08 04:28 PM
Home, From Paris! Made It Back On 24th NW_Pilot Piloting 9 December 27th 07 06:59 PM
Getting Back to FS - CH analog drivers made all the difference TJ Simulators 5 February 26th 05 07:20 AM
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap tim liverance Military Aviation 0 August 18th 03 12:18 AM
