I just had an factory overhauled engine installed in my Piper Cherokee 180.
The shop had given me an original estimate of 20 hours of labor, but when it was done they billed me for 33 hours blaming it on problems they had with various fittings that they had not expected. Does anyone have any experience with engine install on similar aircraft and what is a reasonable amount of labor ? --Rohit |
I worked with my mechanic back in October to reinstall my overhauled engine.
I also fly a Cherokee 180. We completed the work over a weekend and did not work full days. Lycoming has an engine installation and labor guidebook which if I recall correctly estimates the time to remove/install the engine at 24 hours. http://www.lycoming.textron.com/supp...5/SSP875-1.pdf Outside of needing to be a contortionist to get at some of the connections it's not that tough a piece of work. "Rohit Fedane" wrote in message rvers.com... I just had an factory overhauled engine installed in my Piper Cherokee 180. The shop had given me an original estimate of 20 hours of labor, but when it was done they billed me for 33 hours blaming it on problems they had with various fittings that they had not expected. Does anyone have any experience with engine install on similar aircraft and what is a reasonable amount of labor ? --Rohit |
I just had an factory overhauled engine installed in my Piper Cherokee 180. The shop had given me an original estimate of 20 hours of labor, but when it was done they billed me for 33 hours blaming it on problems they had with various fittings that they had not expected. Does anyone have any experience with engine install on similar aircraft and what is a reasonable amount of labor ? Is this just for installation or for removal and reinstallation? If it is for both I would say it is not unreasonable. Going on takes longer than coming off. Problems with fittings are always possible. The classic one is an oil quick drain fitting that was put on by a gorilla and ends up getting destroyed on removal despite various attempts to ease it out normally. On installation it is not uncommon even from the factory to have various plugs that take fittings installed so tightly that eventually they have to be drilled out. Then there are baffling repairs and the like as well. John Dupre' |
| Thread Tools | |
| Display Modes | |
| Photos of damage to J3 Cub propeller after new engine mount installation | [email protected] | Home Built | 0 | August 9th 04 10:32 PM |
| Photos of damage to J3 Cub propeller after new engine mount installation | [email protected] | Home Built | 0 | August 9th 04 10:31 PM |
| Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 07:42 PM |
| Engine Replacement Labor costs.... | [email protected] | Owning | 10 | November 20th 03 01:14 PM |
| Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 05:29 AM |
