Where is the RFI capacitor typically located in a 1971 Piper Cherokee 180?
On the firewall? In the cabin? Next to the battery? Here's a link to the Cherokee electrical schematic. http://www.needlescentered.com/cherokee_electrical.htm Thanks, Nathan |
Nathan Young wrote:
Where is the RFI capacitor typically located in a 1971 Piper Cherokee 180? On the firewall? In the cabin? Next to the battery? Here's a link to the Cherokee electrical schematic. http://www.needlescentered.com/cherokee_electrical.htm Usually, it's bolted to the alternator (with it's wire connected directly to the output terminal of the alternator). --- Jay -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino/ ! ! ! Checkout http://www.oc-adolfos.com/ for the best Italian food in Ocean City, MD and... Checkout http://www.brolow.com/ for authentic Blues music on Delmarva |
Nathan Young wrote:
Where is the RFI capacitor typically located in a 1971 Piper Cherokee 180? On the firewall? In the cabin? Next to the battery? Here's a link to the Cherokee electrical schematic. http://www.needlescentered.com/cherokee_electrical.htm Thanks, Nathan On the alternator. What kind of RFI are you experiencing? Things that cause RFI in GA airplanes: Brush arcing in electric Turn Coord. Brush arcing inside the alternator. Brush noise in electric motor (such as old rotating beacons) Bad shields on spark wires Bad shields on P-leads Bad shields on strobe wiring MikeM |
Your schematic shows it attached to the alternator.
Having said that, sometimes they are on the backside outside but if the alternator has been replaced....might be inside. Neal |
On Mon, 12 Jan 2004 12:21:37 -0700, mikem
wrote: Nathan Young wrote: Where is the RFI capacitor typically located in a 1971 Piper Cherokee 180? On the firewall? In the cabin? Next to the battery? Here's a link to the Cherokee electrical schematic. http://www.needlescentered.com/cherokee_electrical.htm Thanks, Nathan On the alternator. What kind of RFI are you experiencing? Things that cause RFI in GA airplanes: Brush arcing in electric Turn Coord. Brush arcing inside the alternator. Brush noise in electric motor (such as old rotating beacons) Bad shields on spark wires Bad shields on P-leads Bad shields on strobe wiring Thanks Mike, Fortunately, I do not have any RFI problems with the plane. The radios are clear, and the voltage is stable (ammeter is stable too). However, I've been debugging a problem with my charging system, and spent some time looking at the schematics. While doing this, I realized had no idea where the RFI cap sits... I checked this afternoon. It is mounted on the engine side of the firewall. The model is a Hisonic RFI 70. It's probably as old as the plane, so I wonder if it has any capacitance left, or is merely along for the ride. -Nathan |
Nathan Young wrote:
I checked this afternoon. It is mounted on the engine side of the firewall. The model is a Hisonic RFI 70. It's probably as old as the plane, so I wonder if it has any capacitance left, or is merely along for the ride. -Nathan If that Hisonic box is about 2" X 3" X 4", and has two terminals (instead of one), it is actually a low pass filter containing series rf chokes wound on ferrite as well as shunt capacitors. If it has just one terminal, then it is likely just a shunt capacitor, where the case is the other side... In either case, the case has to be well grounded for it to have any effect. The capacitor(s) in these things are high quality, and usually do not dry out. Mike M Skylane '1MM Pacer '00Z |
On Tue, 13 Jan 2004 18:25:43 -0700, MikeM
wrote: Nathan Young wrote: I checked this afternoon. It is mounted on the engine side of the firewall. The model is a Hisonic RFI 70. It's probably as old as the plane, so I wonder if it has any capacitance left, or is merely along for the ride. -Nathan If that Hisonic box is about 2" X 3" X 4", and has two terminals (instead of one), it is actually a low pass filter containing series rf chokes wound on ferrite as well as shunt capacitors. If it has just one terminal, then it is likely just a shunt capacitor, where the case is the other side... In either case, the case has to be well grounded for it to have any effect. The capacitor(s) in these things are high quality, and usually do not dry out. Thanks again Mike. The box is as you describe. A terminal on either side, and presumably ground on the case... -Nathan |
Nathan Young wrote:
On Tue, 13 Jan 2004 18:25:43 -0700, MikeM wrote: Nathan Young wrote: I checked this afternoon. It is mounted on the engine side of the firewall. The model is a Hisonic RFI 70. It's probably as old as the plane, so I wonder if it has any capacitance left, or is merely along for the ride. -Nathan If that Hisonic box is about 2" X 3" X 4", and has two terminals (instead of one), it is actually a low pass filter containing series rf chokes wound on ferrite as well as shunt capacitors. If it has just one terminal, then it is likely just a shunt capacitor, where the case is the other side... In either case, the case has to be well grounded for it to have any effect. The capacitor(s) in these things are high quality, and usually do not dry out. Thanks again Mike. The box is as you describe. A terminal on either side, and presumably ground on the case... -Nathan btw- I dont think that this big LPF box is standard equipt. It was probably added by somebody (probably without logging the work) in a misguided attempt to cure "alternator whine" in the radios. The Hisonic filters are RF lowpass; they are NOT effective at audio frequencies and do NOT filter alternator ripple at audio frequencies. Brush arcing in an alternator causes RF noise (hash), and the shunt hypass (oil filled tub) capacitor was usually installed at the factory to suppress this RF at its source. The RF noise out of an unsuppressed alternator will clobber ADF and Loran frequencies (100-500Khz), but will rarely effect a VHF (120MHz) radio, so even if there is no bypass capacitor on your alternator; you are not likely to hear hash in a VHF radio. Alternator whine (& Strobe squeal) is not caused by radiated RFI travelling from the alternator to a VHF antenna. Rather, they are usually caused by alternator ripple currents flowing along the airframe coupling into the audio system. Said coupling can be fixed by correctly wiring the audio system so as to eliminate multiple grounding points (single point ground). Naive avionics techs and owners install the big Hisonic box filters on their alternator output lead as a bandaid which rarely works to eliminate alternator whine; however, they will improve ADF and/or Loran reception. MikeM Pacer '00Z Skylane '1MM |
FS: several Piper parts (long) | Jay Masino | Aviation Marketplace | 0 | September 15th 04 01:09 AM |
Cherokee National Fly-In & Convention - THIS MONTH | Don | General Aviation | 0 | June 3rd 04 05:01 AM |
Piper Cherokee RFI Capacitor | mikem | Home Built | 0 | January 16th 04 05:09 PM |
replacement rotating beacon for 64 piper cherokee | Patrick Mathews | Owning | 2 | October 1st 03 01:55 PM |
FS: Piper Side Window (New) | JimC | Aviation Marketplace | 0 | August 10th 03 12:19 PM |
