Howdy,
Gasoline Direct Injection (GDI) has been integrated into quite a few automotive engines over the past few years. After reading an article about it, and googling for the availability of GDI fuel injectors I started thinking this might be a cool direction to go in for those persons interested in engine design, particularly the HCI Radial guys. One engine I've always thought was elegant was the 29 packard aero- diesel because it did away with the second valve per cylinder. If they had had forced induction in those days the old packard radial might have been a keeper rather than an oddity. It occurs to me that GDI recreates the possibility of a uni-valve layout. If there is no fuel in the intake manifold, there is less reason to seperate the intake and exhaust gasses. With a big venturi on the intake side, there may not even be a need for forced induction. One problem that would certainly have to be overcome in this arrangment, is that air metering in the manifold is not preportional to fuel metering. Some exhaust gases may be recycled during normal operation, particularly during decelaration. If the manifold is 'T' shaped rather than 'L' shaped, the inlet pressure does not accurately reflect the volume of air going into the cylinder. So you'd have to base your fuel flow on something other than manifold pressure. Probably a combination of a known throttle map (in the form of a cam or wedge) and a barometric lifter of some sort. Anyway. If I was going to build a new gas aviation engine, I would be inclined to look at a radial GDI with 1 valve per cylinder, 1 throttle body per cylinder, a relatively low pressure centrifugal supercharging setup on a planetary gear around the prop shaft. The fuel system would be similar to the bosch piston pump injection system that was used on the Packard, and many engines since. So you'd still have 2 cams, except one is for the valves, and the other actuates the injection pulse. How to handle mixture control still baffles me. But this is just shooting the breeze. Anyway... Comments welcomed. Thanks! |
On Jun 22, 2:30Â*am, Philippe wrote:
le mardi 21 juin 2011 17:46, s'est pench sur son critoire num rique: Gasoline Direct Injection (GDI) has been integrated into quite a few automotive engines over the past few years. Â*After reading an article about it, and googling for the availability of GDI fuel injectors I started thinking this might be a cool direction to go in for those persons interested in engine design, particularly the HCI Radial guys. Forget GDI on an aircraft engine, it is a good thing only when you use the engine a very low charge with EGR (exhaust gas recirculation) system. The GDI engines are not better than standard engines at full charge. For an airplane we kneed light engines and best fuel use at full power. It may be achieve with mechanical injection. The best I know is the IO320 in the homebuilt Â*power range, it is better than most of automotive conversion. --http://www.youtube.com/watch?v=1ODCf7J8L0o Â* Â* Philippe Vessaire Â*Ò¿Ó¬ Can you site a source? From what I've read thermal efficiency has been increased by designing the injection pattern and the top of the piston in order to keep the combustion away from the cylinder walls. I've seen nothing that suggests this negatively effects performance at wide open throttle. It occurs to me that with a fixed injection map, mixture can be controlled with the throttle body. Rather than reducing fuel, you add air instead to lean the mixture. So there is potential for a fully mechanical system. Thanks |
le lundi 27 juin 2011 21:33, s'est penché sur son écritoire numérique:
I've seen nothing that suggests this negatively effects performance at wide open throttle. No negative effect but no gain... It occurs to me that with a fixed injection map, mixture can be controlled with the throttle body. Rather than reducing fuel, you add air instead to lean the mixture. So there is potential for a fully mechanical system. This way is only made to reduce NOx production for lower charges. EGR don't work for high power output when full cubic inches are needed. -- http://www.youtube.com/watch?v=1ODCf7J8L0o Philippe Vessaire Ò¿Ó¬ |
Preheating engines: Airplane engines versus auto engines | Peter R. | Owning | 86 | January 2nd 08 07:48 PM |
Aircraft with the most jet engines? | Dallas | Aviation Photos | 24 | June 27th 07 12:07 AM |
A few thoughts on "Aircraft Engines" vs. the regular kind. | Bret Ludwig | Home Built | 20 | February 18th 06 10:31 PM |
New v220 v300 aircraft engines | bluesky | Piloting | 1 | February 11th 05 05:55 AM |
Harley Davidson engines for aircraft | Brett | Aviation Marketplace | 3 | August 27th 04 02:13 PM |
