Tiny vacuum pump
Old January 16th 04, 04:41 PM
Jim Weir
Default Tiny vacuum pump
Does anybody have an idea on how to make a tiny little vacuum pump on the order
of an aquarium pump or so that will draw just a few inches of water? Preferably
110, but I can rig up a 12 volt supply if necessary.
The reason I say this is that I'm getting ready to pack a fairly large number of
bags with used but serviceable engine parts (valves, pistons, etc.) and I'd like
to put each part in a "baggie" (sandwich bag or equivalent) along with a little
preservative oil, and then suck the baggie down with a football needle stuck
into the top closing mechanism just before sealing.
Thoughts?
http://www.rst-engr.com
Old January 16th 04, 04:45 PM
Thoughts?
If it is just the suck that has to be tiny and not the pump, how about
a toilet paper roll and some duct tape to make an adapter to your shop
vac?
Jim Pennino
Remove -spam-sux to reply.
Old January 16th 04, 05:25 PM
Jim Weir
Because the pump has to fit on a bench that is already overcrowded. If I was
going to use a shopvac, btw, it would be with a pvc waterpipe fitting glued to a
barbed fitting with plastic tubing. I thought of that and then the hassle for
each part of reaching down to turn the vacuum on for each part you want to seal.
-If it is just the suck that has to be tiny and not the pump, how about
-a toilet paper roll and some duct tape to make an adapter to your shop
-vac?
Old January 16th 04, 04:46 PM
Ron Natalie
"Jim Weir" wrote in message ...
Why don't you just get a foodsaver? (www.foodsaver.com). It will do the
vacuum pack as well as sealing the bag (and you can make arbitrary sized bag
as long as it's narrower than the roll of "bag stock." I've got one in the kitchen.
If that's too pricey for you, then there's always this one $14.94, not sold in stores....
http://www.pump-n-seal.com/
Old January 16th 04, 05:26 PM
Jim Weir
Because Foodsaver requires you to use their special bags. Besides being WAY
overpriced, the bags ain't cheap either. Yeah I knew about pump'n'seal, but
that seems to be a kluge way of doing it. I was looking for elegant.
"Ron Natalie"
-Why don't you just get a foodsaver? (www.foodsaver.com). It will do the
-vacuum pack as well as sealing the bag (and you can make arbitrary sized bag
-as long as it's narrower than the roll of "bag stock." I've got one in the
kitchen.
-If that's too pricey for you, then there's always this one $14.94, not sold in
stores....
-http://www.pump-n-seal.com/
Old January 16th 04, 10:52 PM
Blueskies
The foodsaver thing we have has a fitting for a small hose that you can hook up to whatever you want - would be just
right for what you are doing...
Dan D.
"Ron Natalie"
kitchen.
stores....
Old January 16th 04, 05:21 PM
Ben Jackson
You just need a surplus dental spit sucker. Perfect for removing air
from the corner of a plastic bag.
Ben Jackson
http://www.ben.com/
Old January 17th 04, 08:07 AM
David Pincus
Thoughts?
Jim Weir
-Ben Jackson wrote:
-You just need a surplus dental spit sucker. Perfect for removing air
-from the corner of a plastic bag.
PERFECT. Where do I find one? Are there boneyards for dental equipment?
Jim,
What you want is a Gomco. They make most all the dental/medical suction
equipment. Any of them will consist of the vacuum pump and a glass bell
jar to pull the fluid into. We used these in our portable dental clinics
in the Army.
I did a quick search on Google for "gomco suction used" and the first
hit was for a used machine for $109:
http://websites.medmatrix.com/detail.CFM?LineItemID=630.
The whole list is at:
http://www.google.com/search?hl=en&l...o+suction+used
There is another solution to your problem. You said it yourself,
baggies, but not the old kind. They make new ones with a plastic zipper
and they seal absolutely air and water tight, and you can get them in
any size up to 3 ft in size, what are called "game bags" for deer meat,
etc. for your larger engine parts.
With whatever size you put in your part, as much preservative oil as you
want, seal it up, shake the bag to coat the part, then vent the zipper a
bit and flatten the bag out as much as possible and zip the last bit
shut. What little oxygen is in there shouldn't harm your oil-coated
parts. If you really want to got all the O2 out, rent a tank of CO2 or
Nitrogen and crack the valve just enough to blow low-pressure gas into
the bag as you seal it to drive out any room air. Then whatever air is
left inside is inert.
Regards,
David Pincus, DDS
Major, USAR (RET)
Old January 16th 04, 05:28 PM
John Mireley
If you have a compressor, use a venturi vacuum generator.
Harbor freight has them for about $10 from time to time.
Wet vs Dry Vacuum Pump Fastglasair Home Built 1 December 15th 04 05:17 PM
Windmilling Prop & Vacuum Pump Matt Young Instrument Flight Rules 14 October 14th 04 08:08 PM
Remove oil seal from vacuum pump adapter on Lycoming IO320 HOW????? Ron Home Built 2 February 24th 04 04:34 PM
Tiny vacuum pump Jim Weir Home Built 41 January 24th 04 05:42 AM
Battery and Vacuum pump PaulaJay1 Owning 3 January 16th 04 04:22 PM
