Buying a used COMM
Old January 22nd 04, 08:09 AM
res
Default Buying a used COMM
I want to buy a used COMM that is working (with all the accesories needed)
It is not going to be mounted i n a plane, itīs only for my home. Iīd prefer
a better price than a newer one, so an old COMM could be accepted.
Thanks
Iņaki
Old January 22nd 04, 02:35 PM
Mark Astley
Do you mean a handheld or panel-mount unit? Do you actually need to
transmit or do you just want to hear ATC? Generally speaking, a good used
handheld will be easier to deal with than an old panel-mount. Yes you could
probably pick up an old Narco MK12 on e-bay for $5 but you'll need to track
down an antenna, rig up a power supply, etc. But if all you want to do is
listen in on traffic, the cheapest solution is to go to RadioShack and pick
up an air band radio. You can get a decent one for about $20. Note: unless
you're close to a ground station or have line of sight, you're only going to
hear one side of the conversation.
cheers,
mark
"res" wrote in message
prefer
Thanks
Iņaki
Old January 22nd 04, 03:48 PM
On Thu, 22 Jan 2004 09:35:18 -0500, "Mark Astley"
If it's just for listening, the antenna can be just a bit of wire. Radio
Shack sells a couple of nice little 12V power supplies for running auto
accessories. Any 8-ohm speaker should work. You'll need the pinout for
the radio. You might be able to get by without a rack, if you can solder
wires directly to the radio connector.
I did this with my Narco Escort 110, back when the frequency standards were
tightened and I had to replace it. Just a nice evening's project, unless
you want to build an enclosure so it looks purty.
Mark's right, though, if your sole reason for it is to listen to traffic,
buy a cheap airband radio. Mine was an addition to an collection of old
instruments in my office, so it was just an added fillip to get it running.
Rarely turn it on, unless we have visitors with kids. I live with
line-of-sight to a nearby uncontrolled field, with the downwind traffic
about a quarter-mile away and 500 feet above me.
Got an old Mark IV coffee-grinder I'm half interested in firing up, but now
we're getting into some high voltage....
Old January 23rd 04, 04:07 PM
Andrew Boyd
the trick is to cut it to the right length.
Might I suggest a "marconi antenna"? Do a google on it,
it's just a vertical piece of wire, cut to 1/4 wavelength,
with a horizontal ground plane underneath.
What's 1/4 wavelength? Well, from high school physics we
fundamentally we know that
V = F * Lambda
Where V = velocity, F = frequency, Lambda = wavelength
Using grade 8 algebra, divide both sides of the equation
by (non-zero) F to isolate Lambda gives:
Lambda = V / F
Assuming that radio waves move at the speed of light,
We know that V = 3 x 10^8 meters per second, and let's
use a nominal F = 120 Mhz or 120 x 10^6 = 1.2 x 10^8
Therefore Lamda = 3 / 1.2 = 2.5 meters. Therefore
1/4 wavelength would be 0.625 meters or around 24.4 inches.
Keep in mind, though, I'm just a dumb airshow pilot -
check with Jim about this. He builds these in his sleep
from welding rod.
ATP http://www.pittspecials.com/images/oz_inv.jpg
Old January 23rd 04, 05:05 PM
G.R. Patterson III
Andrew Boyd wrote:
He builds these in his sleep from welding rod.
He only uses welding rod for the deluxe models. Coat hangers are fine for the
bottom of the line. :-)
George Patterson
Great discoveries are not announced with "Eureka!". What's usually said is
"Hummmmm... That's interesting...."
Old January 24th 04, 01:54 AM
Jim Weir
Did an April article back when I was writing for Private Pilot on the advantages
of the "co-tanger antenna".
"G.R. Patterson III"
-He only uses welding rod for the deluxe models. Coat hangers are fine for the
-bottom of the line. :-)
http://www.rst-engr.com
Old January 24th 04, 01:53 AM
Jim Weir
Which is the theoretical length of an infinitely small diameter wire antenna.
For antennas made out of REAL materials (like brass welding rod) you wind up
with a Finagle Factor that approximates somewhere between 90 and 95% for rod
between 1/8" and 1/4". In general, I recommend somewhere around 22.5 inches for
the bottom end of the band (around 120 MHz.) or so, and an inch shorter for the
dead center of the band at 127.5 MHz.
-Therefore Lamda = 3 / 1.2 = 2.5 meters. Therefore
-1/4 wavelength would be 0.625 meters or around 24.4 inches.
-Keep in mind, though, I'm just a dumb airshow pilot -
-check with Jim about this. He builds these in his sleep
-from welding rod.
Tips on buying a cessna 182 Matteucci Aviation Marketplace 4 September 15th 04 08:42 AM
Retractable Comm Antenna Ron Wanttaja Home Built 11 September 6th 04 06:59 PM
Lost comm altitude? Roy Smith Instrument Flight Rules 12 January 11th 04 12:29 AM
FS: Soft Comm ATC-4Y 4 place portable intercom Jaysen Underhill General Aviation 0 December 11th 03 09:42 PM
FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 Jaysen Underhill Instrument Flight Rules 0 September 4th 03 04:41 AM
Copyright Đ2004-2025 AviationBanter.
