Tanis Pre-heater with Engine Analyzer
Old January 24th 04, 04:04 AM
O. Sami Saydjari
Default Tanis Pre-heater with Engine Analyzer
Does anyone out there have experience with having installed a tanis
heater when a engine analyzer is already in place. I have a JPI Classic
Scanner (EGT/CHT) that had bayonnet-type probee for CHT. Tanis has a
kit designed for this sitation, but after we installed the kit, none of
the CHT readings worked at all. The installer called Tanis and JPI and
did get very useful advice on what may be going wrong. Has anyone out
there faced this problem (and successfully overcome it)?
-Sami
Piper Arrow III N2057M
Old January 24th 04, 04:15 AM
Pilot Bob \(I am just a great guy!!\)
The bayonet probe showed 40-50F higher than the other probes on my airplane.
It was very annoying. JPI could fix it quite easily by modifying their
software to adjust the reading for bayonets, but they do not. That is my
opinion.
"O. Sami Saydjari" wrote in message
-Sami
Old January 24th 04, 04:19 AM
O. Sami Saydjari
On mine, the Tanis kit had us swap out the bayonet probes for some sort
of rings that fit around the inserts that go into the CHT probe slots on
the underside of the engine. Now all of my probes read non-sensical
numbers like 980 degrees F and they fluctuate wildly.
-Sami
opinion.
-Sami
Old January 24th 04, 04:30 AM
980F is obviously not right. In my previous e-mail I said "bayonet" but I
actually meant the spark plug adapter type. The spark plug adapter type were
way off. Did you check you have JPI compatible probes?
-Sami
airplane.
opinion.
-Sami
Old January 24th 04, 04:33 AM
O. Sami Saydjari
The installer supposedly called Tanis and JPI so I assumed they check
for compatibility. I am not sure how I would independently check this
myself. -sami
-Sami
airplane.
opinion.
-Sami
Old January 24th 04, 04:38 AM
Get the part number off one of the probes (follow the wire to find the
label) and call JPI tech support.
myself. -sami
I
were
-Sami
airplane.
my
opinion.
Classic
of
and
-Sami
Old January 24th 04, 06:18 PM
Tom Sixkiller
-Sami
Should have gne this route, not the Tanis route.
http://www.reiffpreheat.com/product.htm#Turbo%20System
Old January 25th 04, 05:53 AM
Victor J. Osborne, Jr.
Amen. Ben' there, done that!
Reif is a LOT easier to add.
Thx, {|;-)
Victor J. (Jim) Osborne, Jr.
take off my shoes to reply
Old January 24th 04, 05:42 PM
Jon Woellhaf
I have a Tanis heater and a JPI EDM-700 on my 182Q.
The JPI CHT probes are bayonet style except for cylinder 3. Cylinder 3 has a
JPI washer-type thermocouple under the top spark plug. Consequently, it
reads lower than the others. The bayonet socket for cylinder 3 is occupied
by the original Cessna CHT probe. JPI makes a dual bayonet adapter which I
intend to install sometime.
The Tanis has a pad heater on the top of the block and on the bottom of the
oil pan. Each cylinder has a Tanis heater/gasket under the rocker arm cover.
The system works very well.
Jon
-Sami
Old January 29th 04, 12:50 PM
: The JPI CHT probes are bayonet style except for cylinder 3. Cylinder 3 has a
: JPI washer-type thermocouple under the top spark plug. Consequently, it
: reads lower than the others. The bayonet socket for cylinder 3 is occupied
: by the original Cessna CHT probe. JPI makes a dual bayonet adapter which I
: intend to install sometime.
Just FYI, I went through CHT-probe hell awhile back and ended up with four
spark-plug probes on the cylinders. In the summer, I have a bayonet probe that I swap out
for the heater on #3 (4-banger). The bayonet (the official place to measure CHT, BTW)
reads at least 60 degrees *colder* than the spark-plug probe. I've seen two posts here
that tend to imply the opposite.
It's an issue for me, since in cruise I typically see about 400 degrees on the
spark plug type... a bit too hot if it were true. Since it's actually 350 or less on the
"real" probe, I'm not concerned about it.
-Cory
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 03:03 PM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
Objective Engine Discussion Rick Maddy Home Built 26 October 14th 03 04:46 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
